Go to Post As we were lying the robot down to work on it "CAD me like one of your french robots" - 1uan [more]
Go Back   Chief Delphi > Competition > Regional Competitions
Unread 04-03-2005, 23:30
fire chaser 134's Avatar
fire chaser 134 fire chaser 134 is offline
AKA: Tyrel
#0134 (Team Discovery)
fire chaser 134 is an unknown quantity at this point
Send a message via AIM to fire chaser 134
Re: VCU NASA Regional
Originally Posted by Collmandoman
is anynody else kind of disappointed with the game?
i am. i havent been able to watch any matches but just by how ive heard the rules and how the feild is set up i think i like last years game better.
if you can't fix it with duck tape it aint worth fixin at all
Unread 05-03-2005, 03:05
Wetzel's Avatar
Wetzel Wetzel is offline
DC Robotics
FRC #2914 (Tiger Pride)
Wetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond repute
Send a message via AIM to Wetzel
If you havn't seen any matches, then on what are you basing your opinion?
Wetzel
Viva Olancho!
Unread 05-03-2005, 09:59
AKA: Tyrel
Wetzel
well last year there was alot more things happening with the small balls, the 2x large balls, hanging... there was just som many things happening were this year you look at all the robots and many look the same. like were as last year there were so many different deigns because of the many different ways to score.
Unread 05-03-2005, 12:18
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
By the rankings on the webcast, it seems as if the #1 seed got 9 matches while the rest of the teams got 8 matches. I was expecting at least one or two more matches overall, but it is a big regional.
Unread 05-03-2005, 12:20
Goobergunch Goobergunch is offline
FRC #1168 (Malvern Robotics)
Goobergunch is a name known to allGoobergunch is a name known to allGoobergunch is a name known to allGoobergunch is a name known to allGoobergunch is a name known to allGoobergunch is a name known to all
The top of the seedings at VCU:
1 - 1279
2 - 1095
3 - 401
4 - 435
5 - 165
6 - 1610
7 - 1541
8 - 345
9 - 616
10 - 540
Time for alliance selections....
Unread 05-03-2005, 12:46
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
I think there's a bit of a problem with the alliance selection process at VCU: the announcer just stated that a top-8 team must accept an invitiaton, or withdraw. This is not supported by the rules, unless a Q&A response changed this since Revison A was posted.
Each of the Alliance Leads will designate a student to be the Alliance Captain. Each remaining team will choose a student to act as Team Representative. Each Alliance Captain and Team Representative will proceed to the Playing Field at the designated time to represent her or his team. In descending order, each Alliance Captain will invite to join them, a team ranked below them in the standings, which has not already accepted or declined an invitation, to join an Alliance. The invited Team Representative will step forward and either accept or decline the invitation. If the team accepts, it is moved into that Alliance. If the team declines, it is not eligible to be picked again and the Alliance Captain extends another invitation to a different team. If an invitation from a top eight alliance team to another top eight alliance team is accepted, the team currently ranked ninth will move up to become the number eight alliance. The process continues until Alliance Eight makes a successful invitation. The same method is used for each Alliance Captain’s second choice. This process will lead to eight alliances of three teams.
The relevant point: "it is not eligible to be picked again", with nothing about that team itself picking. Also, note the sentence that follows above--that would be redundant if the declining top-8 team had to withdraw. This may turn out badly, because of the apparent misunderstanding.
Of course, we won't actually see the results of this, because a team in this position will probably just accept, rather than face (incorrect) withdrawal.
Unread 05-03-2005, 12:54
Elgin Clock's Avatar
FRC #0237 (Black Magic)
<off topic>
Why is alliance selections always a problem?? Grr.. I think while striving to make the game viewer friendly as a spectator, FIRST should strive to make the Alliance selection process as easy to understand as possible too.
</off topic>
Unread 05-03-2005, 12:59
Alliances
Seed...Captain...First Round...Second Round
#1......1279......384.............1545
#2......1095......1541............975
#3......401........435.............122
#4......165........345.............422
#5......1610.......616............510
#6......540........388.............619
#7......837........1086...........1093
#8......339........447.............539
Standby Teams
1469, 1172, 1137, 1623, 587, 1054, 1598, 1417
Unread 05-03-2005, 14:05
Kyle Love's Avatar
Kyle Love Kyle Love is offline
Support STEM Education
FRC #3301 (Jay County Robotics)
Kyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond repute
Quater Final Matches:
QF1-1 Red 49 Blue 00 (1-0-0)
QF2-1 Red 29 Blue 53 (0-1-0)
QF1-2 Red 31 Blue 31 (1-0-1)
QF2-2 Red 31 Blue 43 (#5 seed moves on, defeats #4 seed)
QF1-3 Red 26 Blue 32 (1-1-1)
QF1-4 Red 03 Blue 49 (#8 seed moves on, defeats #1 seed)
QF3-1 Red 15 Blue 24 (0-1-0)
QF4-1 Red 38 Blue 39 (0-1-0)
QF3-2 Red 24 Blue 00 (1-1-0)
QF4-2 Red 76 Blue 15 (1-1-0)
QF3-3 Red 58 Blue 00 (#2 seed moves on, defeats #7 seed)
QF4-3 Red 51 Blue 29 (#3 seed moves on, defeats #6 seed)
Kyle Love
Teams I've been on:
Team 45 - The TechnoKats - Student/Leader/Driver 2004-2007
Team 1646 - Boiler Precision Guessworks - Mentor 2007-2011
Team 3301 - Jay County Robotics - Teacher 2011-Present
Sacramento Regional Cory Regional Competitions 71 30-03-2004 20:48
pic: 843 @ VCU regional CD47-Bot Robot Showcase 2 16-03-2004 11:23
Anyone have pictures from the VCU Regional? Munkaboo Regional Competitions 17 26-03-2003 12:02
KSC Results archiver 2000 2 23-06-2002 22:19
