Go to Post Every thing is a hammer except for the screw driver which is a chisel. - BradL [more]
Unread 05-03-2005, 16:22
Manoel's Avatar
Manoel Manoel is offline
FRC #0383 (Brazilian Machine)
Manoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond repute
Send a message via ICQ to Manoel Send a message via MSN to Manoel
Re: digital output frequency
Oliver,
Take a look at Kevin's last year's beacon code (here), you can modify the EDU-RC code to do what you want. The code has lots of comments and should help you. Any questions, ask!
Manoel Flores da Cunha
Brazilian Machine
Team # 383
Digital Caliper as a Digital Readout on Small Mill sanddrag Technical Discussion 9 13-10-2005 22:51
Updated Encoder Code Available Kevin Watson Programming 2 04-01-2005 01:00
Dynamic Input/Output Changing Paolo Control System 6 23-09-2004 19:09
digital inputs not valid just after initialization? WizardOfAz Programming 2 26-01-2004 13:21
