Go to Post No, nothing secret unless you include the following: will it work?, can it be driven and will it release the balls. - twolf [more]
  #31   Spotlight this post!
Unread 05-03-2005, 02:33
Wayne Doenges's Avatar
Wayne Doenges Wayne Doenges is offline
We Build Robots......and Careers
AKA: Warthog
FRC #1501 (Team T.H.R.U.S.T.)
Wayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond repute
Re: pic: 1501 Final Robot - see you at BoilerMaker!
The conveyor belt material, I think, was donated by the company of one of our parents. He works for a cardboard, I mean corrugated box manufacturer
With our 110 pound robot, TWO (2) wheel drive, we were able to push a 300+ pound man, sitting on a metal chair across the carpeting Can you say massive traction, I knew you could
Our bot will turn on a dime and give $.09 change
Wayne Doenges
Lemmings non sumus
We Build Robots and Careers
World's - #1 seeded in Archimedes, WON Archimedes and made it to Einstein
2016 NC District - Guilford County. #13 seeded, Finalist. Won Quality award.
IN District - Tippecanoe. #4 seeded. Won Innovation in Control award.
IN District - Perry Meridian. #3 seeded. Finalist. Won Excellence in Engineering award.
IN District - State Championship. #1 seeded. Finalist. Won Excellence inn Engineering award.
  #32   Spotlight this post!
Unread 05-03-2005, 02:52
Katy's Avatar
Katy Katy is offline
Quis custodiet ipsos custodes?
Katy has a reputation beyond reputeKaty has a reputation beyond reputeKaty has a reputation beyond reputeKaty has a reputation beyond reputeKaty has a reputation beyond reputeKaty has a reputation beyond reputeKaty has a reputation beyond reputeKaty has a reputation beyond reputeKaty has a reputation beyond reputeKaty has a reputation beyond reputeKaty has a reputation beyond repute
Send a message via AIM to Katy Send a message via MSN to Katy
that is fantastic...
...what is your "shell" made of...can you tell us some more how it works?
  #33   Spotlight this post!
Unread 05-03-2005, 18:42
AKA: Warthog
The entire body and arms are .040" aluminum. The rear trunk lid is .090". There are two 1/8" steel plates that our uprights are bolted to. The uprights themselves are also .040" aluminum. There are NO bolts holding any of it together, only rivets.
When you bend aluminum around a form or into c-channels you increase the rigidity of the aluminum. You than rivet the pieces to each other or to sheets to get the maximum strength. I'm just the CAD mentor so I don't know the whole theory of monocoque assembly. I do know that the arm can withstand tremendous twisting or bending forces.
Hope this helps.
Wayne Doenges
Lemmings non sumus
  #34   Spotlight this post!
Unread 06-03-2005, 07:33
Gasperini's Avatar
Gasperini Gasperini is offline
Mechanical Engineering Student
AKA: Kevin
#0968 (RAWC)
Gasperini is a jewel in the roughGasperini is a jewel in the roughGasperini is a jewel in the roughGasperini is a jewel in the rough
Send a message via AIM to Gasperini
It's like a cross between a bird, a jet engine, and a toaster from the 1960's.
Well done. That is a sweet robot.
  #35   Spotlight this post!
Unread 07-03-2005, 00:55
Katy's Avatar
The real thing I am not understanding is for that to work does it have to be always latched on to the frame? How do you get to things like electronics and to the battery? Do you have to drill out all those rivets and put new ones in?
  #36   Spotlight this post!
Unread 07-03-2005, 02:21
AKA: Warthog
If you look at the front of the robot you will see a piece of polycarbonate. This covers our electronics, compressor and air tanks.
In the center, between the two uprights, you will see our air bleeder and 12v on/off switch.
At the back you will see two black knobs. You remove the knobs and you can open our trunk That's where our battery is. We have plenty of trunk space to add weight if we need to
The lower chassis is made up of former, bulkheads and sheeting with rivets holding it all together.
Wayne Doenges
Lemmings non sumus
  #37   Spotlight this post!
Unread 07-03-2005, 02:26
MrToast's Avatar
MrToast MrToast is offline
I named Greg Needel's cat!
AKA: Dave DeLong
no team (Rhode Warriors)
MrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud of
Send a message via AIM to MrToast
A few words came to mind when I saw that picture:
"Wow"
"Beautiful"
"Elegant"
"Simple"
It looks like you guys had the same attention to detail and functionality that I aim for when designing software interfaces. Incredible! That's a fantastic robot, and I hope I get the chance to see it in person!
Dave
(#121, 2004) Archimedes semi-finalists with 237 and 386! I had an awesome time guys, and thanks for the hat!
(#121, 2004) BC5 semi-finalists with 190 and 1027! Awesome time! We went further than I thought we could! Thanks for all your help w/ our transmission!
(#121, 2005) Galileo quarter-finalists with 47 and 203! Thanks for all your support through the stress!
If it moves and it shouldn't, use duct tape.
If it doesn't move and it should, use WD-40
"It'll all work out in the end, and if it doesn't, it's not the end." - Jeff Bullock
  #38   Spotlight this post!
Unread 10-03-2005, 16:01
AKA: Warthog
You are correct.
The bird is a Hawk. We prey on little tetras
The jet engine look was taken from the SR-71. We are strong.
And if you look close enough you will see two slots for bread. We are still trying to debug the auto-butterer
Wayne Doenges
Lemmings non sumus
  #39   Spotlight this post!
Unread 20-03-2005, 08:41
AKA: Warthog
The final rivet count was...........1794.5
We didn't win any awards at the Boilermaker
Wayne Doenges
Lemmings non sumus
  #40   Spotlight this post!
Unread 20-03-2005, 13:35
Goober!!!'s Avatar
Goober!!! Goober!!! is offline
I am The Goober!!!
AKA: Steve
FRC #1501 (Team Thrust)
Goober!!! is a jewel in the roughGoober!!! is a jewel in the roughGoober!!! is a jewel in the rough
Send a message via MSN to Goober!!! Send a message via Yahoo to Goober!!!
Arrow Re: pic: 1501 Final Robot - see you at BoilerMaker!
Wayne Doenges
Lemmings non sumus
We did win 2 awards one from the cybearcats for the best button award and we won the professional grade award!!!
  #41   Spotlight this post!
Unread 20-03-2005, 15:45
roboticsguy1988's Avatar
roboticsguy1988 roboticsguy1988 is offline
Larry Johnston
AKA: Larry Boy
FRC #1501 (Team THRUST)
Team Role: Electrical
roboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud of
Send a message via ICQ to roboticsguy1988 Send a message via AIM to roboticsguy1988 Send a message via MSN to roboticsguy1988 Send a message via Yahoo to roboticsguy1988
Yes that is true, although we didn't win any during the award ceramonies. The professional grade award is an official FIRST award voted on by all the other teams attending the event. Which we are glad that the teams attending the event thought our team and robot was "professional grade".
However its not about awards and winning, its about learning and having fun, and thats exactly what we did!!!
See you all at IRI, and if not there i will see the rest of you next year at the Boilermaker Regional.
Larry Johnston, Team THRUST, Team #1501, Team THRUST webpage
2005 IRI - Imagery and Design Award
2005 - 2006 BMR - Professional Grade Award
2006 BMR - Delphi Driving Tomorrow's Technology Award
"That can't be their 'bot. not nearly enough (if any) rivets to be a 1501 machine." ~ RogerR
~Da team that uses all tha rivets, Team #1501~
The FIRST Software Repository ~ Chief Admin
openFIRST ~ Project Supporter (Former editor)
DMOZ.org - FIRST - US Teams Section ~ Chief Editor
pic: Robot? What Robot? CD47-Bot Robot Showcase 13 10-04-2004 07:08
pic: Closeup of the robot hanging on robot CD47-Bot Extra Discussion 16 09-03-2004 18:27
pic: Team 1073 Presents Scorpius CD47-Bot Robot Showcase 1 07-03-2004 18:30
team 25 robot pic nuggetsyl Robot Showcase 12 21-02-2004 00:57
about how Drive Train push the robot... shouldn't the force accelerate the robot? Ken Leung Technical Discussion 12 26-11-2001 09:39
