Go to Post Inventions are not built using premade parts. People come up with new ideas, from different angles and with renewed enthusiasm. Playing the game is fun, building and designing is inspirational. - Steve W [more]
Unread 05-03-2005, 15:49
Barth Barth is offline
AKA: Oliver Barth Heinemann
#1156 (Under Control)
Barth is an unknown quantity at this point
digital output frequency
Hello everyone!
Is there any command in C language equivalent to freqout in Pbasic language, or a way to do a digital output oscillate in a 38500 frequency?
Thanks in advance
Unread 05-03-2005, 16:22
Manoel's Avatar
Manoel Manoel is offline
FRC #0383 (Brazilian Machine)
Manoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond repute
Send a message via ICQ to Manoel Send a message via MSN to Manoel
Re: digital output frequency
Oliver,
Take a look at Kevin's last year's beacon code (here), you can modify the EDU-RC code to do what you want. The code has lots of comments and should help you. Any questions, ask!
Manoel Flores da Cunha
Brazilian Machine
Team # 383
Unread 05-03-2005, 20:42
Electrical Engineer
Rookie Year: 1995
Originally Posted by Barth
Hello everyone!
Thanks in advance
"freqout" is not a PBASIC command as far as I know...
Mike Betts
As easy as 355/113...
Unread 06-03-2005, 00:18
ConKbot of Doom ConKbot of Doom is offline
Team Alumni
FRC #1184 (Cobra Robotics)
ConKbot of Doom has a spectacular aura aboutConKbot of Doom has a spectacular aura aboutConKbot of Doom has a spectacular aura about
You can use the CCP module on the PICs to get a signal on pwms 13-16 there is an example of that in the code I believe. If not its in one of the programming .pdf's somwhere. Not 100% sure all what you need to do, but check out some of the programming guides and datasheets on microchip.com about programming it too.
Unread 06-03-2005, 00:40
Manoel's Avatar
As a matter of fact, it is, we just didn't use it to program the robots in the PBasic era (2000-2003). This, and many other commands that weren't used can be found in the Basic Stamp Manual, from Parallax. Oliver probably used freqout with the BOEBots, some really nifty mini-robots that we also use at our school to teach robotics.
Oliver, I was kind of in a hurry (watching two webcasts at the same time ), so here's a bit of clarification from my previous post:
If you don't need to send those pulses at a precise rate, as the beacon code did last year, you can probably just use Kevin's LED Dimmer code to generate PWM signals. Using that file and the PIC18F8520 data sheet (pages 143-144 and 156-157) you can select the frequency you want.
As a matter of fact, I believe the following code (copy'n'paste inside the User_Initialization function in your user_routines.c file) will generate you a nice 38.46 KHz PWM with a 50% duty cycle. I don't have an RC or EDU in front of me right now to test it; if your application involves human safety, wait till someone more knowledgeable (yes, Kevin Watson ) approves this code, otherwise, just test it!
(be aware that using IFI's PWM will 'cause you trouble if using interrupt intensive code, especially Kevin's gyro code - both use Timer2)
         PR2 = 0x40;                 // sets 38461 Hz freq.
         CCPR2L = 0x20;             // sets 50% duty cicle
         T2CONbits.T2CKPS0 = 1;    // sets 1:4 prescale
	 T2CONbits.T2CKPS1 = 0;   // same as above
         T2CONbits.TMR2ON = 1;   // starts timer 2
         Setup_PWM_Output_Type(USER_CCP,IFI_PWM,IFI_PWM,IFI_PWM);
Also, don't forget calling Generate_Pwms(pwm13,pwm14,pwm15,pwm16); to generate the above signal in the PWM 13 output. [EDITED - This step is unnecessary, wrong and will probably give you an error. Disregard it!]
[EDIT] Why not just use last year's IR receivers (am I wrong assuming you want that particular 38500 Hz frequency for that? ), rated at 40 KHz, and use the code that's already available from a much much more reliable source?
Brazilian Machine
Team # 383
Unread 06-03-2005, 00:58
Mike AA's Avatar
Mike AA Mike AA is offline
Programmer and Mentor
AKA: Mike Aalderink
FRC #3458 (Code Blue)
Mike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to behold
Send a message via MSN to Mike AA
actually it is. and if you use the "boe-bot" from Radio shack it uses the freqout command.
-Mike
EDIT: ok, i didn't read ahead, it was already said, but the boe bots were a neat little device.
Unread 06-03-2005, 16:37
Thanks Manoel and Jonathan, I looked the codes with attention and I belive that using signal on pwms 13-16 it will works. Only a question, What does CCP mean?
Yes Manoel, you are right, I want do the same that we do with BOEBots, use IR sensor to detect objects. Don't worry my applications don't involves human safety.
I will try to do it monday and later I tell the results!
Unread 06-03-2005, 21:48
Manoel's Avatar
CCP stands for Capture/Compare/PWM. Again, the data sheet for the PIC is a very useful resource for more advanced programming. Download it here
Brazilian Machine
Team # 383
Unread 06-03-2005, 21:58
Team Alumni
Unfortunately for us though, the PWM outputs are outputs only so we cant use the capture or compare functions :-/ Might be handy for encoders, but oh well, we'll work with what we have.
Digital Caliper as a Digital Readout on Small Mill sanddrag Technical Discussion 9 13-10-2005 22:51
Updated Encoder Code Available Kevin Watson Programming 2 04-01-2005 01:00
Dynamic Input/Output Changing Paolo Control System 6 23-09-2004 19:09
digital inputs not valid just after initialization? WizardOfAz Programming 2 26-01-2004 13:21
