Go to Post If you can't make them fit on the robot, then those features don't really add much value. - Cory [more]
Unread 01-03-2005, 20:25
Mr. Roboto's Avatar
Mr. Roboto Mr. Roboto is offline
President
AKA: Nick
FRC #1474 (Tewksbury Titans)
Mr. Roboto is an unknown quantity at this point
Send a message via AIM to Mr. Roboto
What do you still have to do?
With that practice day a few days away for some regionals.....
What does your team still need to do to the robot?
I know we will be spending this thursday wiring/mounting limit switches, mounting our team numbers, and doing some heavy modifications to the top of our gearbox, not to mention more of that dreaded autonomus.....
not too much compared to last year, but how about you?
President
Tewksbury Titans
www.tewksburyrobotics.org
Unread 01-03-2005, 20:43
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: What do you still have to do?
Make and mount the 4th side team number. Slot the shaft encoder mounts so they slide with the pillow blocks (oversight during build). Tension the chains. Check all fastener tightness and electrical connections. Make sure wiring is clear of chains. Make an attempt to clean up the wiring a little bit. Hopefully get the fisher price cooling fan running again (I'm not really sure why it stopped).
And of course, autonomous mode.
Unread 01-03-2005, 20:48
Bcahn836's Avatar
Bcahn836 Bcahn836 is offline
Iraq is fun.
AKA: Brad Cahn
no team (Robobees 836)
Bcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond repute
Send a message via AIM to Bcahn836 Send a message via Yahoo to Bcahn836
1. Make sure it works
2. Put numbers and sponsor stickers on the robot
3. Put on the vision camera
4. Zip tie the electronics
5. Maybe drill some more speed holes
6. Whatever else I can't think of
Unread 01-03-2005, 20:57
Best Available Data
FRC #1778 (Chill Out!)
We have to mount limit switches, Encoders, hook up encoders, remove encoders, work on autonomous, mount the final sheet of protecting lexan, and most likely other stuff I haven't thought of but will invariably have to be done following the law that everyone calls Murphy's law but is in fact Finneagal's law.
Unread 01-03-2005, 23:06
Ein's Avatar
Ein Ein is offline
I Know John Neun
FRC #0020 (The Rocketeers)
Ein will become famous soon enough
Pick up all the screws that enevitably loosen during shipping and put them back in they proper places.
Oh yeah, "signage". Who needs it anyway.
The blinkers too but they give them out at the regionals.
UTC 2005 GM Industrial Design Award
UTC 2005 Finalist w/ 173 & 230
UTC 2005 Top Seeded team
[ECDU]
Unread 02-03-2005, 12:58
PVCMike PVCMike is offline
AKA: Mike Jr.
FRC #1058 (PVC Pirates)
PVCMike has a spectacular aura aboutPVCMike has a spectacular aura aboutPVCMike has a spectacular aura about
Team Numbers, Sponsor Stickers, Cover the huge holes in our boom (dont want to lose any hands) autonomous testing, mount our new motherboard, make sure we didnt go overweight again...
Coming up on year 15 with the PVC Pirates!: www.team1058.com
https://www.thebluealliance.com/team/1058
Unread 02-03-2005, 13:11
Aside from preventive maintenance and mounting the LED modules, I don't know of anything mechanical or electrical that needs to be done to our robot.
As for software, we need to download the working camera code that got finished the day after shipping. Then we need to type in the autonomous scripts and parameter sets that were developed after the fix-it window closed.
Unread 06-03-2005, 11:14
dman9385 dman9385 is offline
AKA: Dane Meyers
FRC #3098 (The Captains)
dman9385 will become famous soon enough
Send a message via AIM to dman9385 Send a message via Yahoo to dman9385
The team I am working with (1504) has quite a bit to do yet. We have to add on our smoked lexan casing, graphics, finish programming presets for our arm, modify the bottom gripper slightly, gear down the first stage arm more, and plain out have fun doing so. The down side is our one and only regional is West Michigan, so most teams will have there robots running very well by then.
