Go to Post My guess is you all are planning on being overweight......interesting strategy.....i like it - Stephen Kowski [more]
Go Back   Chief Delphi > Competition > Regional Competitions
Unread 06-03-2005, 17:43
ThePBoss ThePBoss is offline
157 Head Programmer
#0157 (Aztechs 157)
ThePBoss is an unknown quantity at this point
Re: Autonomous at Regionals
Oh man! One of the reasons our (Aztechs 157) autonomous mode didn't work, was that we didn't have enough time to debug our code for the lighting at BAE.
We wrote the code in assabet (our school - It worked very well!!!), and our calibration values were much too different from the ones at BAE. We also mounted our camera way too low, so our yellow values were very innacurate.
I found out too late!
I guarantee, it will work at UTC!!! See you guys there!
Unread 06-03-2005, 22:00
neilsonster's Avatar
neilsonster neilsonster is offline
AKA: Andrew Neilson
FRC #0772 (Sabre Bytes)
neilsonster is a name known to allneilsonster is a name known to allneilsonster is a name known to allneilsonster is a name known to allneilsonster is a name known to allneilsonster is a name known to all
Send a message via MSN to neilsonster
Team 772 used our camera during most of the qualifying matches since it was consistent at home but every time autonomous started in Rochester it was a few inches off. On top of that the fragile servo kept breaking. Overnight I wrote a different autonomous that went to the auto loaders which worked out much better (but the turning needs to be sped up a ton - if you saw our bot you'll know what I mean!!).
Andrew Neilson - Team 772 Alumnus
University of Waterloo Computer Science, Class of 2010
Unread 06-03-2005, 22:11
kjohnson's Avatar
kjohnson kjohnson is offline
Insert Clever Title Here
AKA: Kyle J.
FRC #1610 (BOT)
kjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond repute
At VCU:
Rookie team and our alliance partner 1610 had a working camera that drove them to the vision tetra and they could pick it up. The lighting at VCU was bad - the lights were mounted on the sides of the field, but none at the back so some teams' cameras would not work properly. Lighting in the pits was better than lighting on the field. Thanks to Gerome the field manager for trying to help.
Unread 12-03-2005, 23:37
mrmummert's Avatar
mrmummert mrmummert is offline
AKA: hank
FRC #1610 (bot)
mrmummert is a splendid one to beholdmrmummert is a splendid one to beholdmrmummert is a splendid one to beholdmrmummert is a splendid one to beholdmrmummert is a splendid one to beholdmrmummert is a splendid one to beholdmrmummert is a splendid one to behold
Send a message via Yahoo to mrmummert
Originally Posted by nukemknight
At VCU:
Hi...Thank you kyle for that note....We plan on improving our auto
mode at national (if we get there,bots already there)....
anyway our two programming engineers,my son william and miles babb...
and maybe oscar have cooked something up for MB....hopefully it
will work better...also we have like seven or eight other programs
we can load into it if we have to change.
during the regionals i think also in the first match it found the tetra,
picked it up and had it over the center goal, but would'nt let it
go. We fixed the release problem during regionals, but had some
problems between the lighting and getting it lined up.
We also bashed our sensors up during competition,so they will
need a little fixing.
Unread 13-03-2005, 22:29
Airforce1000 Airforce1000 is offline
AKA: Ryan
#0987 (EDG ( Engineering Design Group))
Airforce1000 is on a distinguished road
Team 624 could pick up the vision tetras in autonomous. They just had trouble capping. Not just in autonomous, but in general. In the semi-finals, a vision tetra got stuck on their arm in autonomous and they couldn't get it off. Better luck for them in their next matches. :\
We don't have the camera on our robot because of the weight limit. We have it all set up in the script and all. We got the gyro to work on last year's robot, but not this years. I think that the interface was too different. We capped many goals in autonomous. We started to the far left backwards and we turned around, spun our turret and capped. I've been thinking on making a script to start in the center position with the tetra and capping the center goal. I'll have to start working on that at the Vegas regional.
Unread 13-03-2005, 22:34
danield710's Avatar
danield710 danield710 is offline
FRC #0710 (Panthers)
Team Role: Driver
danield710 will become famous soon enoughdanield710 will become famous soon enough
Send a message via AIM to danield710
at ucf probly the team with the best and most flexible autonomous mode was 233
in one mode they could knock down the hanging tetra and then go the autoload station and pick up a tetra from it
a lot of teams could stack a tetra on a side goal if they started out with it and a lot of teams could knock down the hanging tetras as well
Team 710
2005 Newton Divison 6th Seed
Quarter-Finalist (thx 395&345)
2005 UCF Regional Semi-Finalist (thx 1649&312)
2005 UCF Winner of Imagery Award
2004 UCF Regional Quarter Finalist (thx 79 & 168)
2004 UCF Winner of Johnson and Johnson Sportsmanship Award
2004 Newton Division Semi-Finalist (thx 364 &48)
2003 UCF Regional Semi-finalist (thx 267&312)
www.team710.com
Unread 13-03-2005, 23:02
Jeremiah Johnson's Avatar
Jeremiah Johnson Jeremiah Johnson is offline
Go VOLS!!
AKA: Budda648
no team (QC Elite)
Jeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond repute
Send a message via AIM to Jeremiah Johnson Send a message via MSN to Jeremiah Johnson
Our auto mode held a tetra and used it to knock off a hanging tetra then stack that one on top of the corresponding goal. I like to think that we were the roll model at St. Louis for 1288 who did the same thing but that probably isn't the case.
There were no teams with the camera that I know of at St. Louis.
Do The Tyler!
XBOX Live Gamertag = theVelvetLie
Unread 13-03-2005, 23:05
omutton's Avatar
omutton omutton is offline
AKA: Oliver Mutton
FRC #1006 (Port Perry Robotics)
omutton is a name known to allomutton is a name known to allomutton is a name known to allomutton is a name known to allomutton is a name known to allomutton is a name known to all
Send a message via AIM to omutton Send a message via MSN to omutton
We could find the vision tetra every time, and were very close to capping. With a bit of de-bugging we will be able to cap in autonomous at Waterloo!
Unread 14-03-2005, 10:03
tiffany34990 tiffany34990 is offline
tiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond repute
Send a message via AIM to tiffany34990
at ucf...there was a lot of good auto modes going
final rounds bravo to 179, 233..especially 233 able to get to the auto loader was nice
s.p.a.m. finally got ours to work well on saturday to cap and knock off the hanging tetra..i'm soo proud of our software team...auto mode before nationals
great job everyone..there were several more teams that did well too..can't remember numbers right this moment.
Unread 14-03-2005, 16:40
CmptrGk's Avatar
CmptrGk CmptrGk is offline
Programming Mentor
AKA: Dillon
FRC #0716 (Who'sCTEKS)
CmptrGk has much to be proud ofCmptrGk has much to be proud ofCmptrGk has much to be proud ofCmptrGk has much to be proud ofCmptrGk has much to be proud ofCmptrGk has much to be proud ofCmptrGk has much to be proud ofCmptrGk has much to be proud of
in one of our matches, we(716) capped the center goal near the driver station and our partners knocked down the hanging tetras. so we had a triple play during autonomus. has this happend anywhere else?
"Great autonomous mode Dillon."," It hasn't been written yet"
after an Archimedes match
Despite what IFI says, you can configure autonomous from OI... TedP Programming 19 31-03-2004 10:09
Rookie Regionals rachakate Regional Competitions 5 24-03-2004 00:01
Hey FIRST - We're going to need a lot more regionals! Raul Regional Competitions 41 08-11-2003 18:10
autonomous mode problem on field Chris_C Programming 17 26-03-2003 19:11
