Go to Post I feel there really is only one team, and the name of that team is FIRST. - [more]
Unread 06-03-2005, 19:21
BillyJ BillyJ is offline
BillyJ is an unknown quantity at this point
Maximum Variables
How many variables can we declare before reaching the limit in memory?
I seem to remember that you can declare 1000 of type byte. Is this true? Is it possible to "un-declare" them wen ur done?
Unread 06-03-2005, 20:35
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Re: Maximum Variables
I don't remember the specific memory sizes of the control, but I can help you out some. The number of variables you are able to declare will vary with what type you use. Obviously, the smaller a variable you use, the more you can have.
Sizes (in bytes) of the variable types:
char = 1
short int = 2
int = 2 (I think. On most modern PCs this is 4, but I think it's only 2 on the RC)
long int = 4
float = 8
double = 16
For the variables you will be using, there is no way to manually release the memory that your variables take up. If you are using local variables which aren't declared static (a local variable is one which is defined inside a function), then the memory it uses is on the stack, so when your function returns, the space is automatically released. There are ways to do dynamic memory allocation, but they're probably beyond what you'll want to do...
Math.h and Functions and Variables amateurrobotguy Programming 1 26-02-2005 03:19
Need help with Variables ? David Bryan Programming 5 23-02-2004 07:42
To Maximum Oz and Two Train Joe Matt Thanks and/or Congrats 1 09-03-2003 13:03
VB Program to monitor robot variables DanL Programming 7 15-02-2002 22:35
