Go to Post And let's face it their junk is our robot! - jrgrim12 [more]
Unread 06-03-2005, 19:00
BillyJ BillyJ is offline
BillyJ is an unknown quantity at this point
Autonomous loop speed
How quickly does the code in the autonomous section execute? this is in user_routines_fast.c so does that mean it executes as fast as possible? If so, is there some way to limit it so it only executes once every 26.2ms?
thanks
Unread 06-03-2005, 19:07
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Re: Autonomous loop speed
Though the autonomous function is in user_routines_fast.c, it is only called every 26.2ms by main.c.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 06-03-2005, 20:33
Mike's Avatar
Mike Mike is offline
has common ground with Matt Krass
AKA: Mike Sorrenti
FRC #0237 (Sie-H2O-Bots (See-Hoe-Bots) [T.R.I.B.E.])
Mike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond repute
I thought autonomous is called every 17 ms, and regular was every 26.2
http://www.mikesorrenti.com/
Unread 06-03-2005, 20:37
CmptrGk's Avatar
CmptrGk CmptrGk is offline
Programming Mentor
AKA: Dillon
FRC #0716 (Who'sCTEKS)
CmptrGk has much to be proud ofCmptrGk has much to be proud ofCmptrGk has much to be proud ofCmptrGk has much to be proud ofCmptrGk has much to be proud ofCmptrGk has much to be proud ofCmptrGk has much to be proud ofCmptrGk has much to be proud of
according to the comments in user_routines_fast.c in the User_Autonomus_Code function. it states that it is a 26.2 millisecond loop
while (autonomous_mode)   /* DO NOT CHANGE! */
 	if (statusflag.NEW_SPI_DATA)	  /* 26.2ms loop area */
 	    Getdata(&rxdata);   /* DO NOT DELETE, or you will be stuck here forever! */
 		/* Add your own autonomous code here. */
 		Generate_Pwms(pwm13,pwm14,pwm15,pwm16);
 	    Putdata(&txdata);   /* DO NOT DELETE, or you will get no PWM outputs! */
"Great autonomous mode Dillon."," It hasn't been written yet"
after an Archimedes match
Unread 06-03-2005, 22:01
In the User_Autonomous() function is a while loop that runs as fast as it can. Inside that is an if that is satisfied every time data is available each 26 ms. So you can place code inside the if to run it at the same rate as the normal user_routine, or you can place it outside the if (but still inside the while) to run it as fast as possible (like the normal user_routine_fast).
Unread 07-03-2005, 22:32
ldeffenb ldeffenb is offline
AKA: Lynn Deffenbaugh (Mr)
None #0386 (Team Voltage 386)
ldeffenb has a spectacular aura aboutldeffenb has a spectacular aura aboutldeffenb has a spectacular aura about
Send a message via ICQ to ldeffenb Send a message via AIM to ldeffenb Send a message via Yahoo to ldeffenb
17msec is the loop speed on the EduBot. The Full Robot Controller (FRC) gets new OI data every 26.2msec.
Lynn (D) - Team Voltage 386 Software
Unread 08-03-2005, 14:10
Mike's Avatar
AKA: Mike Sorrenti
Ahh, thats where that little number got put into my head. I knew it was from somewhere just wasn't sure where. Thanks!
Loop execution time for Autonomous code Transporter08 Programming 2 13-02-2005 16:17
Rewriting main loop Max Lobovsky Programming 4 04-01-2005 18:35
Despite what IFI says, you can configure autonomous from OI... TedP Programming 19 31-03-2004 10:09
autonomous mode problem on field Chris_C Programming 17 26-03-2003 19:11
