Go to Post If you promote not only the growth of your own team but of other teams at other schools you are successful. - Koko Ed [more]
Unread 07-03-2005, 02:48
Collmandoman Collmandoman is offline
Post-A-Holic
Collmandoman has a spectacular aura aboutCollmandoman has a spectacular aura aboutCollmandoman has a spectacular aura about
Cam interupt question
At the kickoff lavery walked around.. and the bot followed... but it stopped when it got close enough.. can someone explain this? I've looked through the entire FIRST code and can't find anything that shows this. I don't even know how it could be done... unless the camera was programmed to stop sending info to the drive system when X amount of area was consumed in its field of view.. or there was a push sensor I didn't see. An explanation or a foward to code I missed would be most helpful - Thanks
Unread 07-03-2005, 03:12
Goldeye Goldeye is offline
AKA: Josh Hecht
FRC #0694 (Stuypulse)
Goldeye has a spectacular aura aboutGoldeye has a spectacular aura aboutGoldeye has a spectacular aura about
Send a message via AIM to Goldeye
Re: Cam interupt question
There are two ways I know of to do it.
A. Stop driving when cam.tilt_servo < x (which is what most teams did, I believe, but wouldn't work for a vertical object like a human)
B. Stop driving when the cam.size > y (as you suggested, which is probably just what they did.)
Unread 07-03-2005, 03:25
Post-A-Holic
do you by chance know if that code was included in the first code? (for area > X) I can't seem to find it
Unread 07-03-2005, 10:53
The kickoff demonstration version of the camera driving code (if it's the version 2.4 FIRST released) looks like it might just have operated by driving at a slow enough speed such that it was stopped when it pushed lightly up against something (a leg, a goal).
It looks like the max forward speed was 150.
user_routines.c:38: const int speed_setting = 150; //forward speed setting (127 to 254)
user_routines_fast.c:31: extern int speed_setting;
user_routines_fast.c:154: if (speed_setting < 128 || speed_control > 254) //Check speed_setting for valid forward speed
user_routines_fast.c:155:	 speed_setting = 150;			//If not valid number set to default
user_routines_fast.c:158:	 speed_control = speed_setting;
Unread 07-03-2005, 14:48
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
It looked like the robot was running in to him. I agree with Mark McLeod.
Unread 08-03-2005, 17:39
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Originally Posted by Mark McLeod
...looks like it might just have operated by driving at a slow enough speed such that it was stopped when it pushed lightly up against something (a leg, a goal)...
A bump switch was installed to keep the 'bot from running over Dave. It may not be in the code because (I believe) it was added just two days before the kick-off.
-Kevin
Kevin Watson
http://kevin.org
Unread 10-03-2005, 12:41
Post-A-Holic
thx kevin =)
Unread 10-03-2005, 12:55
-Kevin
How many times were the testers run over before the touch switch was added?
Unread 24-03-2005, 00:44
djcapelis's Avatar
djcapelis djcapelis is offline
Fried Manic Custard
None #0675 (Geeks with Power Tools)
djcapelis will become famous soon enoughdjcapelis will become famous soon enough
Send a message via ICQ to djcapelis Send a message via AIM to djcapelis Send a message via Yahoo to djcapelis
As many times as it took.
Robotics requires live humans, no one said this sport was going to be easy.
"I have more friends than enemies, I'm working to resolve the issue."
Auton Cam scaning question... Zalumaskov Programming 0 04-02-2005 11:01
Question of the Week!!! (6/14/04) Andy Grady General Forum 23 01-07-2004 15:54
Question of the Week [05-02-04]: The Very Merry Month of May EddieMcD Rumor Mill 10 05-05-2004 14:02
MIM's question of the day on programming. Gene F Programming 3 24-02-2004 16:32
Need interupts help, and another question... Kevin Karan Programming 7 22-02-2004 11:20
