Go to Post A good measure of Integrity is what you do when nobody's watching. - DonRotolo [more]
Go Back   Chief Delphi > Technical > IT / Communications
Unread 07-12-2004, 00:03
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Motherboard Monitor
Does anyone here use motherboard monitor? I got it today because my computer was lagging while playing a game and was generally slow. This software is awesome. I found out that my CPU was over 100 degrees hot! Also, my power supply shows only like -7.6V for the -12V supply and only like -3.7 for the -5V supply so I think it is dying. Also, my chipset fan is varying in speed between 2000 and 7000 rpm.
I opened up the case and since it had been a while it was filled with dust. I blew it out and now the temperature is only 89 degrees. But my power supply is still low, and my fan is still varying in RPM (and is kind of loud). So, I'll replace the power supply, and then see if that pesky little fan is any happier and finally see if my game runs better.
So anyway, if you don't have it, Motherboard Monitor is a really cool little program.
So if you've got it, post your stats.
Also, I should probably get off CD and shut this beast down for the night. I don't want low voltages to cause harm to any components.
Unread 07-12-2004, 00:24
Re: Motherboard Monitor
Sanddrag,
Don't take any chances, the power supply should not be that low. I might not trust the monitor so I would get in there with a meter but since both of the negative supplies are low, you are about to cause some disk overwrites that you may not recover from. I would, disconnect the drive, power on and measure the motherboard input connector while connected to the board. If it reads the same as the monitor within a few tenths of a volt then the supply is toast. Replacements are pretty cheap, like about $50. If you are lucky enough to live near a FRY they are probably cheapest. You can try MCM or a computer mail order for replacement in your case style. Don't wait!
Unread 07-12-2004, 01:03
NoodleKnight's Avatar
NoodleKnight NoodleKnight is offline
24 Hours of LeMons?
FRC #0100 (WHS&CHS Robotics)
NoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud of
Send a message via AIM to NoodleKnight
Motherboard monitor doesn't support the PC's I'm using, but I use other software. My laptop averages around 60*C, plus I get to control how fast the fan spins. As for my other computer, I have no idea, it's a prebuilt so it shouldn't overheat, theoretically.
WHS/CHS Robotics - Team 100 (2003-2006):
2006- Delphi's Driving Tommorow's Technology @ Davis | Imagery Award @ SVR | 2004- SVR Finalists (w/ 691 and 1280)| 2003- Delphi's Driving Tommorow's Technology @ Sac
Unread 07-12-2004, 01:09
gobeavs's Avatar
gobeavs gobeavs is offline
linux advocate
AKA: Ross
None #1425 (Wilsonville Robotics)
gobeavs will become famous soon enoughgobeavs will become famous soon enough
Send a message via AIM to gobeavs
I just use an nVIDIA utility that is compatible with my nFORCE 3. That shows me most of what I need, then in video card settings it shows me the temps for my video card...between those two that is all I really need.
"Never in the face of human conflict has so much been owed by so many to so few."
- Winston Churchill on the RAF in WWII
Unread 07-12-2004, 02:59
evulish's Avatar
evulish evulish is offline
1010100
AKA: Grant Harding
#0084 (WATTNESS (bot: Chuck))
evulish is just really niceevulish is just really niceevulish is just really niceevulish is just really nice
Send a message via AIM to evulish
My G4 is running at 121F with no fans running.
I'm a professional web developer. I'm good with PHP, Perl, Java/JSP, some RoR, XML, Javascript (AJAX as well), (x)HTML, CSS, etc.. Validated code is good; fully cross-browser code is better (you comply to your users and the software they use, not the other way around. Sorry!)
Unread 07-12-2004, 08:33
100+o is probably nothing to worry about on the CPU.
I have a p4 3.0ghz cpu stock that runs at about 85 degrees. I usually run it at 3.2ghz and the normal temp is about 100. Its been very stable and as long as you dont neglect your case, you should be fine.
Unread 07-12-2004, 11:07
I don't know if this is a glitch but I just saw my chipset fan dip as low as 430 and go as high as 10,000. But at every update (10 second intervals) the rpm of this fan is very different. Anyway, I'm getting a new PS tomorrow so for now, the beast sleeps.
Unread 07-12-2004, 13:20
Marc P. Marc P. is offline
I fix stuff.
AKA: βetamarc
Marc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond repute
Send a message via AIM to Marc P.
I'd hope that's in Fahrenheit. Make sure you know what units the temperature is reporting in. It's alright for a CPU to run up to 130-135o Fahrenheit, but that's only about 55-57o Celsius. If your CPU is running over 60-70o Celsius, there's a cooling problem. Most CPU dies are only rated to 80-85oC, any hotter than that and they'll burn out pretty quickly.
Unread 17-12-2004, 18:13
kcy88's Avatar
kcy88 kcy88 is offline
Animator
AKA: Kevin
FRC #0075 (Roboraiders)
kcy88 is a jewel in the roughkcy88 is a jewel in the roughkcy88 is a jewel in the rough
Send a message via ICQ to kcy88 Send a message via AIM to kcy88
I recently built my own PC. The only problem I had was the CPU temp; like most people. I also have a p4 3.0ghz cpu. However, I found that the stock heatsink is not really that good. CPU temp was between 57-70 degrees C. I immediately changed the stock heatsink to one i bought,an Artic Cooling Super Silent Pro 4. This brought my CPU temperature to 36-41 (idle) and 60-64 (100%) when rendering. I would recommend you get a better heatsink.
Team 75 - Roboraiders
Hillsborough High School Robotics
2006 Boston Regional Autodesk Visualization Award
2006 Boston Regional Engineering Inspiration Award
2006 New Jersey Regional Engineering Inspiration Award
2005 New Jersey Regional Autodesk Visualization Award
2005 Duel on the Delware champions
2005 Brunswick Eruption 4 champions
Unread 06-03-2005, 21:44
davelu davelu is offline
AKA: fffff
#0123 (fff)
davelu is infamous around these partsdavelu is infamous around these parts
How about Cpu running at around 64C to 70C on a laptop at 100%?
Amd 2500 + M processor
hd around 45-53 C
Unread 07-03-2005, 08:20
DarkJedi613's Avatar
DarkJedi613 DarkJedi613 is offline
Running Riot
AKA: Patrick Cloke
FRC #0358 (Hauppauge Robotic Eagles) FRC #1493 (RPI/Albany High School)
DarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to behold
Send a message via AIM to DarkJedi613 Send a message via MSN to DarkJedi613 Send a message via Yahoo to DarkJedi613
I know AMD XP's die temperature are 90 degrees Celsisus. Pentiums are lower (around 80).
2003 - 2006 President, Coach, Webmaster Team358.org
2008 Mentor, Team 1493
Team Search | (Updated: 1-16-08)
FIRSTsearch
Unread 07-03-2005, 08:30
jdiwnab's Avatar
jdiwnab jdiwnab is offline
Really the Inventor Guy
AKA: Bryan Hartley
FRC #0617
jdiwnab is a jewel in the roughjdiwnab is a jewel in the roughjdiwnab is a jewel in the rough
I tried Motherboard Monitor, but was getting very odd info. BIOS was telling me that the processor was about 55C. MBM told me that it was 67C and peaked at 150C (very fast spike). It also told me the case temp was 9C (but the readout on the case said 73F, 40C, nowere near what MBM said) I knew my processor was hot, but I wanted to monitor the temp in windows. But MBM didn't work right for me.
Proof that Macs will win the platform war: How did Scotty know how to use MacDraft in Star Trek IV?
// random()
I have 100 gmail invites. PM me if you want one.
If they want us to think outside of the box, why do they make us fit in a 38x28x60 inch box?
Beware of Geeks bearing GIFs
Help me test my server software
Unread 07-03-2005, 08:35
It is possible you do not have all the optional temp sensors installed. If that is the case, the software makes a feel good reading out of thin air. Most motherboards come with a temp sensor installed on the board but the proc is optional.
Computers monitor going funny Denman Chit-Chat 10 05-12-2004 18:38
What size monitor do you use? Elgin Clock IT / Communications 30 10-03-2004 16:53
What resolution do you use on your monitor? Elgin Clock IT / Communications 29 17-02-2004 22:10
Downloading Problem to EDU Motherboard Jankenpoe Programming 0 16-02-2003 14:29
VB Program to monitor robot variables DanL Programming 7 15-02-2002 22:35
