Go to Post We need to celebrate great things because good enough isn't inspiring. - Andrew Schreiber [more]
Unread 07-03-2005, 12:56
Peter Kiers Peter Kiers is offline
Peter Kiers is an unknown quantity at this point
Scrolling through strings in a stringgrid
Hi i am Peter,
I have a litte problem:
I am working on a program that pings servers, so i use
a stringgrid with 30 servernames. The program scrolls
through the stringgrid to check the servers.
Only the program checks empty cells too!
How can i tell my program to only check the cells
that are filled with text.
I thing the change must be made in the following procedure:
procedure TForm1.GridServersDrawCell(Sender: TObject; ACol, ARow: Integer;
Rect: TRect; State: TGridDrawState);
var
Kleur: TColor;
begin
with (Sender as TStringGrid) do
begin
if gdFixed in State then Kleur := FixedColor
else if IsWaiting then Kleur := Color
else if gdFocused in State then Kleur := clYellow
else if gdSelected in State then Kleur := clLime
else Kleur := Color;
with Canvas do
begin
Brush.Color := Kleur;
Font.Color := clBlack;
FillRect(Rect);
if not IsWaiting and (gdFocused in State) then
begin
Draw(Rect.Left, Rect.Top, Image1.Picture.Graphic);
Rect.Left := Rect.Left + Image1.Width +2;
end;
TextOut(Rect.Right - TextWidth(Cells[ACol, ARow]) - 2,
Rect.Top + 2, Cells[ACol, ARow]);
end;
end;
end;
Greetings,
Peter Kiers
Unread 07-03-2005, 13:22
Sachiel7's Avatar
Sachiel7 Sachiel7 is offline
<Yes I managed to flip it
AKA: Shayne Helms
FRC #1132 (RAPTAR Robotics)
Sachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really nice
Send a message via AIM to Sachiel7
Re: Scrolling through strings in a stringgrid
I assume that this post is Non-FIRST related.
Team 1111 is located in Edgewater MD, USA, not in the Netherlands.
This Forum is for FIRST Robotics Related discussion.
More about the competition can be found here:
http://www.usfirst.org/robotics/
As for help with your dilemma, I can offer none.
-=Sachiel7=-
There's no such thing as being too simple!
Look for Team #1132, RAPTAR Robotics at the VCU Regional this year!
Unread 07-03-2005, 13:26
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Well, kinda a duplicate post (because of the above), but...
http://www.chiefdelphi.com/forums/sh...ad.php?t=29944
(I think that's Delphi, anyway... don't know the language... )
Unread 07-03-2005, 13:28
Maybe i made a mistake
Correct me if i'm wrong:
I thought this was a Delphi-forum:
and i could ask a question when i have a problem with my program!
Greetings,
Peter Kiers
