Go to Post People are human, refs are human. The refs did the best they could do at the time. - Andy Baker [more]
Unread 21-02-2005, 19:16
roknjohn roknjohn is offline
roknjohn is an unknown quantity at this point
Victors not synchronized - dual motor train
Our bot uses the dual motor kit tranmissions (2 CIMs left, 2 CIMs right, and 4 884s). We noticed some rather loud motor noise (over and above the loud tranny noises) occasionally when accelerating. The sound is best described as a stalled CIM. We tried using Y-cables for the PWM signal to the two victors on each side. The noise still persists, though, like I said, is intermittent.
Funny thing though, if we wire both CIMs to one victor (yeah, I know its not legal) the problem is solved!
So, if the input signal in the same to each victor (via the Y-cable), how are we sure that the output is the same? Is there a way to calibrate two victors so that they behave the same with identical input signals?
John
Unread 21-02-2005, 19:22
Matt Krass's Avatar
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
Re: Victors not synchronized - dual motor train
My team had a similar problem, we solved it by recalibrating both Victors simultaneously. Just use the guide on ifirobotics.com to calibrate, and do both at once.
Go to to the homepage, click Victor 884 on the left side and then get the User Guide PDF, it's in there.
Matt Krass
Unread 21-02-2005, 19:25
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Matt,
Did you try doing them separately and it didn't solve it? I'm asking this because that would mean we have three of them to do at once.
Unread 21-02-2005, 19:35
Matt Krass's Avatar
AKA: Dark Ages
We didn't try them separately no, it didn't seem logical, we want them to be in perfect synchronicity and our joysticks aren't that good with that, so for us the logical solution is simultaneously calibrating them, I've found its very easy to do with multimeter probes in the calibration pinholes. But we only had two, but two people, three probes, not so hard, then just move one joystick forward/backward/etc repeat with the other side. It's not very difficult.
Matt Krass
Unread 21-02-2005, 21:17
jimfortytwo jimfortytwo is offline
AKA: Jim Paulos
#0418 (Purple Haze)
Team Role: Student
jimfortytwo is just really nicejimfortytwo is just really nicejimfortytwo is just really nicejimfortytwo is just really nicejimfortytwo is just really nice
Send a message via ICQ to jimfortytwo Send a message via AIM to jimfortytwo Send a message via Yahoo to jimfortytwo
It seems incredibly unlikely to me that slightly mismatched voltages would make any noise whatsoever. I'm inclined to say you've misdiagnosed your problem, unless you're calibration is ridiculously off. We're on our second year of quad motor drives, and have never experienced such a problem as the result of mismatched voltages. If the voltages are slightly different, all that should happen is perhaps a slightly uneven load sharing-- but that ought to be a silent affair.
Unread 21-02-2005, 22:46
Shu Song's Avatar
Shu Song Shu Song is offline
Melodious Footware
AKA: *Crash!* Shuuuuuuuuuuuu
FRC #0639 (Code Red Robotics)
Shu Song has much to be proud ofShu Song has much to be proud ofShu Song has much to be proud ofShu Song has much to be proud ofShu Song has much to be proud ofShu Song has much to be proud ofShu Song has much to be proud ofShu Song has much to be proud of
Send a message via AIM to Shu Song
That noise might just be due to very unlubricated gears and causing a lot of friction and thus causing the motor to stall. Trying lubricating the gears with something and it should lessen the stalling of the motors. I seems very unlikely that the victors are reacting differently to the same data sent to them, at least in my 2 years of electronic experience.
Code Red Robotics - Team 639
Ithaca High School| Ithaca | New York | USA | Earth | Sol System | Milky Way | Universe | Some Alien's Locker
WINNER of the 2005 Finger Lakes Regional, thanks to teams 191 and 494.
WINNER of the 2004 Canadian Regional, thanks to teams 33 and 1112
WINNER of Delphi: Driving Tomorrow's Technology Award at the 2007 Finger Lakes Regional.
Unread 22-02-2005, 00:52
We were getting really bad buzzing. Part of this is due to the Fisher Price being combined with the two Chias. At startup, I assume they are "fighting" (not spinning opposite directions, but not spining at the same speed) a little bit. Anyhow, I'm not exactly sure what we did, but we either calibrated the Victors or switched the motor polarity (and pwm values) or both. Anyhow, the buzzing is almost completely gone, only very minimal (due to drag and the FP). It was an electrical, not mechanical induced sound.
Unread 22-02-2005, 09:19
A simple way to get everything calibrated is to remove all the breakers but the one you want to calibrate. Go through the calibration procedure. (remember the values are not stored until you release the button.) Then swap breakers and repeat until all the controllers are calibrated. It is not unusual to have a little "chatter" at dead stick but if you think it is a problem, increase the deadband and see if that fixes it. When you have two different motor types running in the same transmission, you are likely to get noises that are combinations of the two that you never heard before. Just be sure that each motor is adding to the overall output, that no motor is drawing more than expected currents and that all motors are running in the same direction for the same input. (removing breakers helps on this test as well.)
Unread 22-02-2005, 11:09
Mr. Lim Mr. Lim is online now
AKA: Mr. Lim
Adding to Al's suggestion:
When first energizing everything, program, test and check one motor at a time. Even if it is a dirt simple arrangement.
Pull all the breakers. P
Put in a breaker for only one motor.
Program it, test, and note the direction it spins in vs joystick motion.
Pull the breaker out.
Put one in for the next motor.
etc.
From a team who has built quite a few 6-motor drivetrains, we can safely say that motors running in opposing directions is a VERY bad thing. Avoid it at all costs through just a little bit of patience and care.
-SlimBoJones...
Unread 07-03-2005, 18:51
Umm Errr...
Somwhere i read a claim that the speed controllers are perfectly calibrated to work with ifi controllers and that the calibration is only for using victors with rc systems that lack trim. I don't remember where i heard this, but it is very wrong. On one of our 4 motor drive prototypes, the speed controllers were soo off that it was impossible to trim the joystick such that at least one motor was not trying to move at all times. The problem was easily fixed by calibrating the speed controllers.
1139 Alumni
24Vs and victors greencactus3 Control System 13 05-02-2005 14:22
Dual monitor Display setup.... BrianJennings Inventor 6 12-01-2005 20:35
Calibrating Victors SpaceOsc Control System 27 19-11-2004 07:59
Flakey Victors archiver 1999 4 23-06-2002 21:58
DON'T Recalibrate Victors! Joe Johnson Off-Season Events 0 12-11-2001 22:58
