fuses
I am looking for some very low <= 5A auto resetting fuses....I wondered if anyone had any ideas for me....i would greatly prefer a blade type fuse....
thanx.... |
Re: fuses
Is there a specific type you would need, Maxi, Mini-Maxi, ATX, etc... i can prob help you out just get me some more info, like style and voltage load and your price range.
Re: fuses
ATX or Mini-Maxi are desirable.....I will be operating on a 12 V circuit....
Re: fuses
I think it is unlikely to find anything in that low a range in that package. You will find solid state fuses up to a few amps but most are for surface mount. You can always attach leads (need great solder skills) and on rare occasions you may be able to kill a fuse and use the carcass to hold another device. |
Re: fuses
If you are willing to go to a ATO/ATC style fuse they make them in 1,2,3,4,5 amps and larger. The are cheap and you can run them in line with ato/atc fuse holders, similar to the ones found on cars and trucks for aftermarket installations like off-road lights. You could also scope out glass fuses. You can buy the holders and fuses from radio shack for cheap. I know you are probably after the nice auto reset breakers or what not, but they do not come in a package that small. At least I can't find them. You can scope out the site:
http://www.waytekwire.com and this one: http://www.mouser.com I didn't search through the many pages of mouser, but you may find what you need there. Part of what engineering is, is being able to find the information you need in a timely manor. I guess another important thing is to also be able to adapt your design to technology that already exists to keep the cost of the project down. It also helps to keep a folder with important files, and a list of sites in case you need to find something. You can also order catalogs from both of these places. I just received my new mouser catalog the other day. Good luck with your project! |
| Could a magnetic field around CIMs cause fuses to blow? | scitobor 617 | Electrical | 41 | 15-02-2005 08:56 |
| 4A fuses? | Denman | Control System | 6 | 30-09-2004 21:28 |
| 20 amp fuses for Spikes | Andrew Schuetze | Electrical | 8 | 01-04-2003 22:18 |
| Triping Timed Fuses | Joe Canavan | Electrical | 2 | 21-02-2002 09:34 |
| Those 60Amp fuses... | Anton Abaya | Electrical | 5 | 18-01-2002 07:41 |
