Go to Post However, do not confuse faith in your ability to overcome challenging obstacles, with the difficulty of the obstacles themselves. - Joe G. [more]
Unread 07-03-2005, 20:19
Stephen Kowski's Avatar
BSEE, MSEE, JD
AKA: employed
fuses
I am looking for some very low <= 5A auto resetting fuses....I wondered if anyone had any ideas for me....i would greatly prefer a blade type fuse....
thanx....
Unread 07-03-2005, 20:25
dez250 dez250 is offline
54... What a good number!
dez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond repute
Send a message via AIM to dez250
Re: fuses
Is there a specific type you would need, Maxi, Mini-Maxi, ATX, etc... i can prob help you out just get me some more info, like style and voltage load and your price range.
-Michael Dessingue
Unread 07-03-2005, 21:20
BSEE, MSEE, JD
AKA: employed
Re: fuses
ATX or Mini-Maxi are desirable.....I will be operating on a 12 V circuit....
Unread 08-03-2005, 00:07
Re: fuses
thanx....
Steve,
I think it is unlikely to find anything in that low a range in that package. You will find solid state fuses up to a few amps but most are for surface mount. You can always attach leads (need great solder skills) and on rare occasions you may be able to kill a fuse and use the carcass to hold another device.
Unread 08-03-2005, 12:42
coreyjon's Avatar
coreyjon coreyjon is offline
Flight Engineer
FRC #0250 (Team 250 Dynamos)
coreyjon is just really nicecoreyjon is just really nicecoreyjon is just really nicecoreyjon is just really nicecoreyjon is just really nice
Send a message via AIM to coreyjon
Re: fuses
If you are willing to go to a ATO/ATC style fuse they make them in 1,2,3,4,5 amps and larger. The are cheap and you can run them in line with ato/atc fuse holders, similar to the ones found on cars and trucks for aftermarket installations like off-road lights. You could also scope out glass fuses. You can buy the holders and fuses from radio shack for cheap. I know you are probably after the nice auto reset breakers or what not, but they do not come in a package that small. At least I can't find them. You can scope out the site:
http://www.waytekwire.com
and this one:
http://www.mouser.com
I didn't search through the many pages of mouser, but you may find what you need there. Part of what engineering is, is being able to find the information you need in a timely manor. I guess another important thing is to also be able to adapt your design to technology that already exists to keep the cost of the project down. It also helps to keep a folder with important files, and a list of sites in case you need to find something. You can also order catalogs from both of these places. I just received my new mouser catalog the other day. Good luck with your project!
"Jack of all trades, master of none, though offtimes better than master of one".
Could a magnetic field around CIMs cause fuses to blow? scitobor 617 Electrical 41 15-02-2005 08:56
4A fuses? Denman Control System 6 30-09-2004 21:28
20 amp fuses for Spikes Andrew Schuetze Electrical 8 01-04-2003 22:18
Triping Timed Fuses Joe Canavan Electrical 2 21-02-2002 09:34
Those 60Amp fuses... Anton Abaya Electrical 5 18-01-2002 07:41
