Go to Post when I was a young whippersnapper, we didn't even HAVE Internet access at my high school in my podunk farmer town of Kinsman, OH! - Travis Hoffman [more]
Unread 07-03-2005, 20:41
cdawzrd's Avatar
cdawzrd cdawzrd is offline
Vice-President of Caffine
AKA: Jonathan
#0619 (CA Robotics)
cdawzrd will become famous soon enough
Send a message via AIM to cdawzrd
Re: Building an arena controller
The controller will operate the field the same way the IFI stuff does--keep the robots disabled until the match is started, then enable autonomous mode. Disable does prevent auton mode from doing anything, as it affects the master controller in addition to the user processor, but that won't be an issue.
Also, each individual station will be controllable in terms of disabling robots before or during the game. We will have e-stop buttons and disable switches on the master controller to disable robots for hazards or violations.
You can build floor mats with a little floor mat, a piece of plexi or aluminum to cover the bottom (insulate the metal though) and some strips of metal. Glue one strip to the bottom of the mat, then one stripto the underlying material (wood/plexi/insulated metal). These wires go out to connectors to the RC dig ins on the master controller. Then, you put strips of nonconductive material around the conductive strips, springy stuff like folded pieces of cardboard or something else that is springy but low-profile.
I have tested the mat idea before for use in a haunted house :-D it works. We will probably have overrides in case the mats fail during a match.
Cdawzrd
>> www.cdawzrd.com <<
>> www.carobotics.org <<
IFI Loader and PROG button Dave... Programming 3 20-02-2005 12:03
IFI Loader usually hangs midway thru load gnormhurst Programming 4 04-02-2004 11:40
IFI Loader Problems BrendaB Programming 3 24-01-2004 22:45
IFI Loader Doc's Raven_Writer Programming 0 21-01-2004 17:53
Bug in IFI Loader rwaliany Programming 2 06-01-2004 21:26
