Go to Post I don't miss the manufactured magic of Disney because Championships creates magic in itself; wherever the event may be held. - Erin Rapacki [more]
  #31   Spotlight this post!
Unread 07-03-2005, 06:35
JohnnyB's Avatar
JohnnyB JohnnyB is offline
JVN thinks I scream like a girl
AKA: John Barton
FRC #0217 (ThunderChickens)
Team Role: Operator
JohnnyB is a glorious beacon of lightJohnnyB is a glorious beacon of lightJohnnyB is a glorious beacon of lightJohnnyB is a glorious beacon of lightJohnnyB is a glorious beacon of lightJohnnyB is a glorious beacon of light
Send a message via AIM to JohnnyB
Re: cap high or fast
Its really tough to say.
They kind of need each other. If you can go high, thats good but it means nothing if you cant get the volume of tetras needed to even have to go high. If you're fast, thats good but if you can't get high enough, you have to stop after only a few tetras.
If I could only choose one, fast seems better to me. At least once you hit max height you can defend or something.
Both would be the real way to go. I dont have video to back it up, but I do have the classic pic of us and 229 stacking. Both of us are fast and high cappers (utilizing the same shuttle and fourbar), as this goal was stacked by 229 and 217 back and fourth
  #32   Spotlight this post!
Unread 07-03-2005, 07:12
Bcahn836's Avatar
Bcahn836 Bcahn836 is offline
Iraq is fun.
AKA: Brad Cahn
no team (Robobees 836)
Bcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond repute
Send a message via AIM to Bcahn836 Send a message via Yahoo to Bcahn836
Originally Posted by Bcahn836
We can do both, but if I had to choose I would say fast. Because I have a feeling it will be difficult to cap a goal if someone else is messing around with you. So the quicker the better
I said this before I went to the BAE Systems regional. After seeing that event and competing in that event I saw robots that could cap high and other robots that could cap fast and a few that could do both. I found that my team can cap either fast or high but not both in one match, for the most part we capped the back row in less than 45 secs each match, but were able to put a 5th tetra on the center goal. It isn't that important to be able to do both just do one well and your robot can be successful.
  #33   Spotlight this post!
Unread 07-03-2005, 09:09
Matt Goulart's Avatar
Matt Goulart Matt Goulart is offline
#0121 (Rhode Warriors)
Matt Goulart is on a distinguished road
Send a message via AIM to Matt Goulart
Thumbs up Re: cap high or fast
From what I saw at BAE being able to cap quickly and reliably on many goals was much more important than taking the last 30 sec. of a match trying to put the 6th tetra on the center goal.
  #34   Spotlight this post!
Unread 07-03-2005, 14:48
lupjohn's Avatar
lupjohn lupjohn is offline
AKA: Larry Upjohn
FRC #0692 (FemBots)
lupjohn is an unknown quantity at this point
I would second this observation. At the Sacramento Regional passive end effectors(tetra grabbers) won out over grippers or powered grabbers. Time to locate top of tetra, pick up and maneuver to goal highly favored aim and drive systems vs. locate, grasp and then capping systems. Team 692 had a nice pneumatic gripper but getting it located in three dimensions across the field was too much time. The team ended up not using the arm and mostly defending in the semi's. Next year.....
  #35   Spotlight this post!
Unread 07-03-2005, 17:33
team1611's Avatar
team1611 team1611 is offline
Team Captain
AKA: andrew
FRC #1611 (Mustangs)
Team Role: Driver
team1611 is an unknown quantity at this point
i think it is not only important to stack fast, but also consistently each match. strategy is also important, so no matter what the strategy is, doing your job during each match should be first on the list. personally, i think stacking fast is better because more goals can be covered. but the high goal can also be the difference between winning and losing because the center goal can be used to connect a lot of rows.
Team 1611
  • 2005 Peachtree Regional- Highest Seeded Rookie Award (5th place after qualifying, 4th place overall)
  • 2005 Peachtree Regional- Semifinalists (along with teams 1345 and 1553)
ECDU - East Coast Drivers Union
Team 1611's website
  #36   Spotlight this post!
Unread 07-03-2005, 21:09
Koko Ed's Avatar
Koko Ed Koko Ed is offline
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
I'd rather cap fast. You might need to get a tetra down fast to win the match late and high stacks can fall off the goal.
  #37   Spotlight this post!
Unread 07-03-2005, 21:23
-matt- -matt- is offline
Paul Copioli is the man!
AKA: Matt Gill
#0217 (Thunder Chickens)
Team Role: Student
-matt- is an unknown quantity at this point
I'm gonna have to go with fast. if you can cap high, but its slow, its going to matter because another robot is just going to come and push you out of the way. Also, I dont have a video, but check out the pic of 217 and 229 at FLR and you can decide for yourself if they we capping high and fast.
2005 Detroit Champs!!
  #38   Spotlight this post!
Unread 09-03-2005, 10:05
Tim Delles's Avatar
Tim Delles Tim Delles is offline
Since 2001.
FRC #0078
Tim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond repute
After watching the matches unfold at FLR, and watching the finals from VCU i would say that capping fast or capping high have nothing to do with it. yes it is good to be able to go high, and yes it is good to be able to do it fast, but the most important thing is accuracy. if you can cap really fast, but they aren't all stacked right, then you don't get the points. i think the average amount of tetra's on a goal at FLR was aout 5 or 6, that was in a good match, normally it was only 2 or 3. SO as long as you can cap, as far as i've seen, your going to do a decent job.
Timothy Delles - Clarkson University
2011 - Present: FRC Team 78 - AIR Strike
2011 - Present: VEX Team 78 - AIR Strike
2010 - 2011: FRC Team 3280 - Rhode Rebels
2001 - 2009: FRC Team 229 - Division By Zero
  #39   Spotlight this post!
Unread 09-03-2005, 15:01
JohnnyB's Avatar
AKA: John Barton
Team Role: Operator
Going along with what Tim Delles said, I also think its important to have an arm that doesnt require insane amounts of precision to pick up and cap a tetra. Many arms Ive seen require a lot of circumstances to be optimal, and require too much precision to even get the tetra. Our arm (along with 229s) is just a 1" wide stick, which is incredibly easy to put into the opening of a tetra. This makes us both fast accurate cappers.
I support the cloning of Paul Copioli
2005 ARCHIMEDES Division Champions
(muchos gracias to 245 and 766)
2005 National Championship Semi-Finalist
2005 Detroit Regional Champions
  #40   Spotlight this post!
Unread 09-03-2005, 15:25
Brandon Holley's Avatar
The faster you stack, the higher you must go.....so of course you would want to stack fast FIRST, but stacking high would help you SECOND
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
  #41   Spotlight this post!
Unread 12-03-2005, 14:22
Chris_Elston's Avatar
Chris_Elston Chris_Elston is offline
Controls Engineer
AKA: chakorules
FRC #1501 (Team THRUST)
Chris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond repute
I am going with FAST capping. The more you can get out and stack for a chance at tic-tac-toe the better th e scores will be. Also a low end gear to be able to push around other robots. Or hold your own if you get pushed.
We stack pretty fast:
Video Here 1501-capping
Team T.H.R.U.S.T. 1501
Download all of our past robot's source code here:Repository
Favorite CD quote:
"That can't be their 'bot. not nearly enough (if any) rivets to be a 1501 machine." ~RogerR: Team #1369
  #42   Spotlight this post!
Unread 12-03-2005, 14:44
JohnnyB's Avatar
AKA: John Barton
Team Role: Operator
chako brings up a good point... since its obviously more points to play tic-tac-toe than to just stack on the same goals over and over, then capping fast is easily more important, until the center goal gets like 4 tetra's on it and you need to put one over it.
  #43   Spotlight this post!
Unread 17-03-2005, 14:35
Mike Norton's Avatar
Mike Norton Mike Norton is offline
FRC #0061
Rookie Year: 1995
Mike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to all
What was the highest stack you have seen on the middle goal during competition?
Building FIRST robots since 1995
BVT Robotics
  #44   Spotlight this post!
Unread 17-03-2005, 22:55
JohnnyB's Avatar
AKA: John Barton
Team Role: Operator
six or so. Im sure there has been higher.
  #45   Spotlight this post!
Unread 17-03-2005, 23:19
meaubry meaubry is offline
volunteer helper
FRC #6099 (Knights)
meaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond repute
Just an observation - capping smart beats both fast and high
Indiana FIRST 2005 line up Kyle Love Regional Competitions 4 04-11-2004 00:04
What does the Chairman’s Award have to do with a robot contest? Ed Sparks Chairman's Award 32 15-02-2004 13:39
Sacramento Regionals Hermione692 Regional Competitions 57 03-04-2003 02:29
St. Louis anyone? Jeremy_Mc Regional Competitions 8 07-02-2003 12:06
