| View Poll Results: You Make The Call | |||
| Bluateam "owns" the center goal |
27 | 93.10% |
| Redateam "owns" the center goal |
2 | 6.90% |
| Voters: 29. You may not vote on this poll | |||
Re: YMTC: Bluabot "Slinkys" Tetras
If I understand the situation description correctly, then this one is simple. Blue owns the goal. The key is Question 1253, answered on Jan 24. As Blueabot recovers and restores the stack while still in the process of placing their original blue tetra on the stack (i.e. they have not left the stacked tetras in the precarious positions, and the tetras have not fallen to the floor), then they are OK.
-dave |
![]() One out and Casey is up to bat, Lucien |
I do - 10:00 AM ![]() -dave |
![]() *yawns and goes to bed anyway* |
![]() i'm in class before most of you go to bed the night before lol.... |
So say the blue team descores some stacked red tetras and they fall to the ground. The 3-points for each red descored tetra now belong to the red team, along with ownership of the goal. Are the fallen red tetras now fair game for the red team to stack and score elsewhere? If so, I assume, then, that if they place them on the same goal they were stacked on originally, each tetra now represents 6 points each - 3 for being part of the original descored stack, and 3 for being a part of the new one - weird concept. Who is responsible for making a mental note of of the snapshot of how many red tetras were stacked before they were descored? Unless there were refs dedicated to watching one or a small group of the goals all the time (which may be the case), it seems like it would be difficult for the refs given the fast pace of the match to accurately document the stack conditions prior to descoring so they can take them into account during the final score tally. One final thing. If the refs aren't certain of those conditions at match end, would this be a situation where instant replay could be put to good use? Last edited by Travis Hoffman : 08-03-2005 at 06:26. |
#7
A: If you displace a tetra from a stacked position to a "precarious" position, you have de-scored the tetra and will be penalized "if" you leave the tetra in this position. If you return the tetra to a stacked position in the process of stacking your own tetra, you will not be penalized. If the tetra falls completely off the goal, you will be penalized.
I hate to nitpick but this happened. In the final match of the finals at FLR a robot was speeding PAST the center goal his arm hit the tetras and descored some of them. The robot was not in the act of trying to score a tetra he was just quickly moving across the field. If he had time could he have turned around (by now he is 15 feet away from the goal) driven back to the goal reseated the tetras and not lost ownership of the goal? Would the robot have to go get one of his tetras and use it to rescore the descored tetras, so he would be " in the process of stacking your own tetra"? The Referees took what has been called "the longest time in FIRST" to make the call. We all sat with our cameras in hand knowing what the proper call should be. In this case the proper call was finally made. It sure seems like the use of a replay would be helpful to the referees. Last edited by Pat Major : 08-03-2005 at 07:19. |
#8
Just to defend my rules-reading honor, I voted for red because I thought the YMTC scenario said the tetras fell off completely. If I could change my vote I would...
#11
So extending that Q&A question, what would happen if a team entirely knocks some opponent tetras off a goal, then picks them up (or some other opponnents' tetras) and replaces them on the goal, then proceeds to cap with their own tetra? It's not very likely, but I think its important enough to consider.
#12
-dave |
#13
Oh Dave you are sooo smart. It helps when you are the rule maker. At least we getcorrect answers.
| YMTC: Descoring Tetras??? | Natchez | You Make The Call | 16 | 10-02-2005 13:00 |
| YMTC: Bluabot sits on Redabot | Natchez | You Make The Call | 19 | 08-04-2004 16:43 |
| YMTC: Bluabot and Redabot hanging? | Natchez | You Make The Call | 15 | 23-03-2004 01:42 |
| YMTC: Bluabot dies while pinning | Natchez | You Make The Call | 17 | 21-03-2004 11:33 |
