Go to Post A quote from the Southern California Regional Visitors guide: "If you are having problems the FIRST thing to do is ask your neighbor for help" - ChrisH [more]
Unread 07-03-2005, 20:09
jdiwnab's Avatar
jdiwnab jdiwnab is offline
Really the Inventor Guy
AKA: Bryan Hartley
FRC #0617
jdiwnab is a jewel in the roughjdiwnab is a jewel in the roughjdiwnab is a jewel in the rough
617's Inventor Bot
I don't know I I am going to be able to submit this or not, but I thought I would ask anyway: Is there anything glaringly wrong with this? I need to finish the wiring, but I think that is about it. I would appreciate your feedback
ID:	3076  Click image for larger version
Name:	close up bot.JPG
Proof that Macs will win the platform war: How did Scotty know how to use MacDraft in Star Trek IV?
// random()
I have 100 gmail invites. PM me if you want one.
If they want us to think outside of the box, why do they make us fit in a 38x28x60 inch box?
Beware of Geeks bearing GIFs
Help me test my server software
Unread 07-03-2005, 20:21
Daniel Brim's Avatar
Daniel Brim Daniel Brim is offline
It's hard hat time here in Boston
AKA: DFB
FRC #0125 (NUTRONS)
Daniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond repute
Send a message via AIM to Daniel Brim
Re: 617's Inventor Bot
Looks great to me. You have wiring and chain, so you're miles ahead of our one man Inventor team (me), and it looks extremely detailed. Great job!
-Daniel
2003 (2002) - 2006 -- Team 294, Beach Cities Robotics
2007 (2006) - Present -- Team 125, NUTRONS
Unread 07-03-2005, 20:31
jdiwnab's Avatar
AKA: Bryan Hartley
FRC #0617
-Daniel
Our "team" consists of me and my personal computer. The school system is too cheep to get us better computers (200-333 Mhz doesn't cut it with Inventor). Most of the computers we have take 20 min just to start up. Becuase there arn't any good computers (they try to run Inventor 5), no one but me learned it.
Reguarding chain, it is a band with extruded bumps. Reguarding wires, they are segements becuse I even after I unstalled SP2 (which helped) I couldn't route wires. Luckly the segments worked OK and look like wiring
// random()
Unread 07-03-2005, 23:38
Garth1388 Garth1388 is offline
AKA: Garrett
FRC #1388 (Eagle Robotics)
Garth1388 is an unknown quantity at this point
Awesome dude (I'm from California, leave me alone). You guys are years ahead of me, the only one on our team with enough initiative to do a model right. Or try to anyway.
How did you do those wire? Did you use cable/harness? If so, how do you use cable/harness? All I know, is what I learned from the tutorials!
My model is a good week from completion so, props for completing it.
"I know not with what means World War III will be fought, but World War IV will be fought with sticks and stones."
-Albert Einstein
Unread 08-03-2005, 11:02
jdiwnab's Avatar
AKA: Bryan Hartley
FRC #0617
I used cables and harnesses, but I don't think I did it the way that I was suppost to. I made a harness part in my main assembly. I selected Segment. I clicked on the first part for the wire and then on the other end for the wire. Finish. Right click on teh segment and select "add point" Add points that you cna move to shape the wire. Finish. Right click on points and select "3D move/rotate". move the points until they look right. Right click on the segment and select "harness properties" and set the color and the diameter so it looks right. When you exit the harness part, the wires will slit color (not transparent)
I'm the only one on our team that knows Inventor, And I don't even know how or when I learned it. I think I heard about it last year, But I just knew what I was doing this year.
// random()
Unread 08-03-2005, 11:42
oljomo's Avatar
oljomo oljomo is offline
Cambridge United Fan
#0759 (Systemetric)
oljomo is on a distinguished road
Hi
My inventor "team" is just me too. I think the problem you may have had with routing the wires is that it wont let you route if the segment starts at the pin the wire should connct to, but i did it more or less the same way as you; one difference though i tried to add points that were on corners of parts. (try moving your assembly and you will see why), and btw the wires are just lines, with no thickness to them, the only effect the thickness has is on the thickness of the segment it will go through.
Oljomo
Unread 08-03-2005, 11:52
jdiwnab's Avatar
AKA: Bryan Hartley
FRC #0617
Originally Posted by oljomo
Hi
Oljomo
I noticed that when I drove my arm, but You couldn't reallky see the segment so I got rid of it.
Wires do have thickness as do segments. There is a feature "Display as Render" that shows a wire or segment as a thick piece.
// random()
Unread 08-03-2005, 12:06
oljomo's Avatar
#0759 (Systemetric)
Hi
I thought id already got that on, would triy it now but inventors trying to do a 400000 occurance array ($@#$@#$@#$@# decimal point whyd i have to delete it with preview on), but segments also work for pneumatic tube, so used them.
Oljomo
Unread 08-03-2005, 12:14
jdiwnab's Avatar
AKA: Bryan Hartley
FRC #0617
What do you have four hundred thousand array of?! I thought I tried too much with 190 occurance array for my tread.
// random()
Unread 08-03-2005, 13:18
oljomo's Avatar
#0759 (Systemetric)
hi
read the rest of my post, i was trying to do a 40 occurence, but accidently deleted the decimal point (and put another digit in, as inventor puts three 0s after the point by default it thought i wanted 400000. it crashed it. i would have just quit but i hadnt saved my work (lesson: save frequently)
oljomo
Unread 08-03-2005, 13:24
jdiwnab's Avatar
AKA: Bryan Hartley
FRC #0617
hi
oljomo
Sorry, I didn't follow what you were trying to say. i thought the "decimal point" was part of "$@#$@#$@#$@#"
Yes, I had to redo some crazy wiring becuase I didin't save and Inventor crashed. Hope it still looks good.
// random()
Team 617's Suggestions For Things To Do In Between "Fix-It" Window & Your Regional The Broox Chit-Chat 14 02-03-2005 20:17
