Go to Post Thats what makes FIRST so unique how culture and the time is reflected through our bots, but at the same time we all get along...with no problem. - Dan Richardson [more]
Unread 07-03-2005, 23:40
raphael raphael is offline
raphael is an unknown quantity at this point
Penalties
Were penalties given out for teams that attempted to pick up a tetra from the auto-loader , but were not touching the "target" triangle (the autoloader zone) in front of it? If so, how common were these penalties?
Unread 07-03-2005, 23:43
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: Penalties
Yes, they were given one ten point penalty for each instance they occurred.
This situation happened far less than human player zone violations.
2001-2004: Team 100
2006-Present: Team 254
Unread 07-03-2005, 23:55
Michael Corsetto's Avatar
Michael Corsetto Michael Corsetto is offline
Breathe in... Breathe out...
FRC #1678 (Citrus Circuits)
Michael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond repute
Re: Penalties
We found out about this the Thursday of Sacromento. I don't believe FIRST really clarified what being in the auto loader was. Many teams (including us) ended up putting zipties or string that dragged on the ground when we found out about this rule. Otherwise they would be stratling the zone, not touching it, and would recieve a 10 point penalty.
Team 1678: Citrus Circuits - Lead Technical Mentor, Drive Coach **Like Us On Facebook!**
Unread 08-03-2005, 06:50
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Re: Penalties
While we're on the subject, what were some of the most common penalties? I (and I'm sure others) would like to be able to warn our drivers for our regional.
Unread 08-03-2005, 06:53
Bcahn836's Avatar
Bcahn836 Bcahn836 is offline
Iraq is fun.
AKA: Brad Cahn
no team (Robobees 836)
Bcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond repute
Send a message via AIM to Bcahn836 Send a message via Yahoo to Bcahn836
Re: Penalties
Make sure your robot is touching the colored triangle in the human player and or manual loading station. We were over top of the area straddling the triangle but noting was touching because we have a 2.5" ground clearance, but this problem was easily fixed with zip ties. But if the human player doesn't put the tetra on the robot and runs back with the tetra and allows the driver to correct it you won't get a penaltie but it takes up a lot of time to do so, so get it right the first time and you will have no problems. That was the most common penaltie for us.
Unread 08-03-2005, 12:00
melmo's Avatar
melmo melmo is offline
AKA: matt
#0365 (MOE)
Team Role: Driver
melmo is on a distinguished road
Re: Penalties
Are there any rules regarding how far the robot must back away from either the HP or Auto loading zones before re-entering the loading zone to recieve an second tetra? Or is it only necessary to back away far enough so the ref can see that you have left the loading zone?
guess once, cut twice
MOEbius 28-5-2
Unread 08-03-2005, 14:09
AmyPrib's Avatar
AmyPrib AmyPrib is offline
AmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond repute
Re: Penalties
You must move out of the loading zone such that you are clearly and obviously not touching the loading zone. Then you may re-enter.
Co-Chair Boilermaker Regional Planning Committee 2004-2011
2008 St. Louis Regional Finalists and Engineering Inspiration Award
2007 St. Louis Regional Champions - Thanks 1444 & 829! / St. Louis and Boilermaker Quality Award
2006 Boilermaker Chairman's Award
Referee - IRI - 2005, 2006, 2007, 2008
2005 Midwest Regional - Semifinalist, Engineering Inspiration Award, and Safety Award / Boilermaker Regional - Judges Award
2004 Midwest Regional Champions - Thanks 269 and 930! / IRI Runner-Up - Thanks to 234 and 447!!!
2004 Championship: Archimedes Finalist - Thanks 716 and 1272!
"We are going to be praised and criticized more than we deserve. We are not to be affected by either." ~ co-worker
Unread 08-03-2005, 14:50
the_undefined's Avatar
the_undefined the_undefined is offline
German FES
AKA: Felix Geisendörfer
#1648 (Gearbox Gangstas)
the_undefined has a spectacular aura aboutthe_undefined has a spectacular aura about
Re: Penalties
Our alliance recieved a 30 point penality in the final match for interferring with a robot in the Hu Loading Zone. Thinking now about it, complaining to the head ref in the match before where that happend to us maybe wasn't that smart ^^ since she said: "Ok I'm going to watch out for this from now on" which she then did .
Overall the penalities where always justified but unfourtanly not constantly used.
Are The Penalties Too High? AJunx Rules/Strategy 49 06-04-2005 20:37
pic: Oh... the penalties! Rich Wong Extra Discussion 15 12-03-2005 23:47
Bot blocks field with arm in LZ - Penalties? Swampdude Rules/Strategy 8 02-03-2005 15:00
Appropriate penalties for off-the-field ethical/behavioral violations Steve W General Forum 65 08-01-2005 00:17
Did You See this Ruling? Paul Copioli Rules/Strategy 9 17-02-2002 02:06
