Go to Post The rules also never explicitly say that I can't park a Boeing 747 right in the middle of the play field and use it as an obstacle for the other alliance. But after a little thought, something tells me that I probably should not do it. - dlavery [more]
Unread 01-03-2005, 17:46
amateurrobotguy's Avatar
amateurrobotguy amateurrobotguy is offline
Lead Programmer/Senior Engineer
amateurrobotguy is infamous around these partsamateurrobotguy is infamous around these partsamateurrobotguy is infamous around these partsamateurrobotguy is infamous around these partsamateurrobotguy is infamous around these partsamateurrobotguy is infamous around these parts
What's Under the 'Hood'
How fast of a processor is in the RC(In Mhz). I ask, because I need to know how far I can take my functions. My guess would be that it would have 5-6 mhz. Kinda ironic compared to a 3600 mhz of a pentium 4.
I quit FRC over 2 years ago (more if you're reading this past 2010).
Unread 01-03-2005, 17:59
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
Re: What's Under the 'Hood'
All this info is available at www.ifirobotics.com. The user processor (one of two in the RC), or the processor that you get to program runs at 40mhz and can do 10mips. If you want to estimate how fast you can run your code, there are some other numbers that will definitley matter, like how many instructions each operation takes.
Team 1257
Unread 08-03-2005, 17:01
jdong jdong is offline
Linux Nerd
AKA: John D
#0245 (Adam-Bots)
jdong will become famous soon enoughjdong will become famous soon enough
http://www.chiefdelphi.com/forums/sh...ad.php?t=35961
The setup I presented in the above thread is a very feasible way of using a regular PC to do the processing, communicating/syncing with the RC/OI once per loop.
The rules are sketchy... I was trying to get a clarification.
John Dong
Co-Captain, Webmaster / Programmer
Team 245 -- Rochester Adams Robotics
A word association here Jeff Rodriguez Games/Trivia 5939 26-11-2003 11:38
Ruling Consistancy in Houston Rick Rules/Strategy 22 16-04-2003 00:28
A peak under the hood... archiver 2000 2 23-06-2002 22:48
