| View Poll Results: You Make The Call | |||
| No Penalty! |
21 | 55.26% |
| Penalty! |
17 | 44.74% |
| Voters: 38. You may not vote on this poll | |||
Re: YMTC: Redabot "Clangs" Tetras Together
Wait wait wait, IS the tetra comming off the autoloader or is it staying on?
If it stays on: no penalty if it comes off: penality |
I'm gonna have to go with penalty. Even if its unintentional, it still happened. Your control of the robot, and the robot itself, is responsible for the "bump" itself
Even if the intent of the robot wasnt to dislodge the tetra from the loader, it is STILL a penalty.
Whether it stays on the loader, or falls off, its the same penalty because the rule specifically states TOUCHES a loading zone tetra. I'd say its just an unfortunate penalty that the team would have to endur. |
If there is no reason to think the team is trying to hit that tetra, and it either falls out of play or stays normally on the autoloader, it should not be a penalty. If the tetra falls into play, it has to be called a penalty. It has consistantly been said that slight accidents will not be punished; a robot got bumped slightly (was not moved at all) while in the loading zone during elim rounds at peachtree, and there was no penalty. There's your precedent.
In any event, here are the rules regarding your situation. See G15 and Update 4. Quote:
| YMTC: Redabot Loads Ten Tetras Without Moving | Natchez | You Make The Call | 21 | 01-03-2005 02:15 |
| YMTC: Descoring Tetras??? | Natchez | You Make The Call | 16 | 10-02-2005 13:00 |
| YMTC: Redabot weighs 129.8? | Natchez | You Make The Call | 73 | 18-12-2004 11:31 |
| YMTC: Bluabot sits on Redabot | Natchez | You Make The Call | 19 | 08-04-2004 16:43 |
| YMTC: Bluabot and Redabot hanging? | Natchez | You Make The Call | 15 | 23-03-2004 01:42 |
