Go to Post After all, it's not where you are but the people you're with that make it worth while. - RoboJedi75 [more]
Unread 09-03-2005, 15:50
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
Re: pic: 1097 Direct Drive 01
It looks really pretty, but as SpaceOsc asked, why?
Sanddrag, bevel gears (I believe that is the more common name) have similar efficiency to spur gears (95%+) because they do not have any surfaces sliding across each other (like in a worm gear).
Team 1257
Unread 09-03-2005, 16:33
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
My reason would be there is no possibility of throwing chains or broken chains. Also, my favorite reason for it is no chains to tension. And there's also the "it's really cool and hasn't been done before" aspect.
Unread 09-03-2005, 17:52
Anthony Kesich's Avatar
Anthony Kesich Anthony Kesich is offline
Programmer Turned Engineer
AKA: SonKenshin
#1097 (Site 3 Engineernig)
Anthony Kesich has a spectacular aura aboutAnthony Kesich has a spectacular aura about
Send a message via AIM to Anthony Kesich
Well, to answer the efficiency question, it's very efficient. The miter gears are aligned within .0005" and transfer the power better than chains. We have had chain problems before. Last year we threw Motorcycle (40 gauge) chain many times, so it removes the need to tension or worry about chains. We went through the entire sac regional without damaging it at all. The ony thing we had to do was check the set-screws to be safe.
As for the drive-shafts, they are .049" wall steel tubing.
As for the efficiency on the miter gears, they are just as effieient as straight-cut spur gears.
We lightened all the gears in the gearbox with 6 holes in each, similar to the wheels if you have seen them. Overall, the entire robot weighs 106.8 lbs, so we have no weight concerns.
And, as Sanddrag said, we did it mainly since no one else has done it.
My mechanic told me to tell you that there are 46 bearings and 42 set-screws in the drive-train.
And as for shaft-drive/direct-drive, we've always seen shaft-drive as a sub-set of direct-drive.
-Tony K
C is screwing up my English--I'm ending all my sentences in semi-colons;
Horray for most things! -George Carlin
"Sure, I'll play rugby. Besides, I have a lot of experience running from really big guys who want to cream me." -Me, Freshman year
Unread 09-03-2005, 17:56
How is rotational load transfered to the U-joints? If the driveshaft was solid, I would put a keyway in it but since it is a tube I'm wondering how you did it. Did you put a pin through? .049 is pretty thin, thats awesome.
Unread 09-03-2005, 18:09
AKA: SonKenshin
The OD of the U-Joints were turned down to within .005" of the ID of the steel shaft. We then put set screws all the way through and have had no problems with them. Eventhough, we are still going to replace all 42 set-screws on thursday at SVR.
As for the gearbox, it is about the same ratio as the kit gearbox, but we couldn't use the kit gearbox due to the way we had to lay it out. As you can see, we needed the driveshaft to go straight through the gearbox and the kit version wouldn't allow for this. We therefore also had to put the CIMs across from eachother. This is useful in that neither side will be more powerful since in either direction, you have one motor running forward and one running backward.
-Tony K
Unread 09-03-2005, 18:51
Projectchon's Avatar
Projectchon Projectchon is offline
AKA: William Lei
FRC #1009 (Vainer Robotic)
Projectchon can only hope to improve
where did you guys get the U join?
Team 1009
Unread 09-03-2005, 20:48
The OD of the U-Joints were machined down to within .005" of the ID of the steel shaft. We then put set screws all the way through and have had no problems with them. -Tony K
Oh okay. I was envisioning the tube going into the U joint, not the U joint going into the tube. Very clever! I hope it continues to work out well for you and maybe we'll give it a try next year!
Unread 10-03-2005, 00:07
AKA: SonKenshin
If you want to give it a shot, I'll see if I can get my mechanic to give me all of the blueprints and I'll scan them for you.
Unread 10-03-2005, 00:16
russell's Avatar
russell russell is offline
#1430 (WRONG)
Team Role: Electrical
russell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to all
I am drooling. I hate chains. Just today I had to replace chains four times.... That may have had something to do with the fact that I was riding on the robot, and the wheel mounts really shouldnt even hold 120 pounds, not to mention nearly 300 .
Unread 13-09-2005, 22:33
CJO's Avatar
CJO CJO is offline
Emeritus Pain in the $@#$@#$@#
AKA: Christopher J. O'Connell
None #1097 (Site 3 Engineering)
CJO will become famous soon enoughCJO will become famous soon enough
So, I know it has been quite some time since this discussion was last updated but I thought I would note the followiing:
1) This drivetrain has been absolutely flawless, both in competition and in post-season stuff.
2) It took tremendous time and effort to make it work, but in the long run it was well worth it.
3) I strongly encourage other teams to use this system in the future. (If you ever have any questions, just e-mail me or Kesich).
~ Christopher
Team 1097 -- Site 3 Engineering
2003 Sacramento Rookie All Star
2003 Silicon Valley Rookie All Star
2004 Sacramento Engineering Inspiration Award
2004 Sacramento Visualization Award
2004 Outstanding Volunteer Award (G. Glasser)
2004 Silicon Valley Sportsmanship Award
2004 National Visualization Runner Up
2004 Cal Games Finalist
2005 Sacramento Sportsmanship Award
2005 Sacramento #1 seed
2005 Sacramento Finalist
2005 Silicon Valley Sportsmanship Award
2005 Silicon Valley #1 Seed
2005 Silicon Valley Finalist
Unread 09-03-2005, 17:57
whakojacko's Avatar
whakojacko whakojacko is offline
FRC #1072 (hrt)
whakojacko is on a distinguished road
Send a message via AIM to whakojacko Send a message via MSN to whakojacko
i saw it in your pits, very cool and unique. Congrats on doing something unusual!. And is that the kit gearbox?
Harker Robotics:1072
http://www.harker-robotics.org
pic: kiwi drive wheels CD47-Bot Extra Discussion 3 24-08-2004 21:39
pic: Team 870 Front Drive Train CD47-Bot Robot Showcase 4 27-02-2003 15:23
pic: Team 870 Rear Drive Train CD47-Bot Robot Showcase 2 27-02-2003 00:22
pic: Team 980 "Thunder Bot" drive train CD47-Bot Robot Showcase 12 25-02-2003 14:02
direct Drill motor drive wrong or right rcubes85 General Forum 6 11-02-2003 18:11
