Go to Post Who needs daytime soaps when one can watch FRC matches? ;) - lkg9999 [more]
Unread 10-03-2005, 16:02
Denman's Avatar
Denman Denman is offline
Tie Wrap-Not Cable Tie or Zip tie
AKA: Stephen Denman
FRC #0759 (Systemetric)
Denman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud of
Send a message via ICQ to Denman Send a message via AIM to Denman Send a message via MSN to Denman Send a message via Yahoo to Denman
Re: homemade speed controlllers (for school project)
Originally Posted by Denman
havn't decided yet, it depends how hard it is to make one go backwards....
ideally yes
having im'ed mike betts, i'm probably going to be starting this in a couple of weeks (given other stuff gets sorted as well...) and there will m/p be a thread about it then
i saw a couple of weeks
i mean a few weeks more from now.... seem to have got overloaded with other stuff ...
I am an ex-member of team 759.
759: regional winners with 522 and 233 NYC (2004)
FIRSTWiki.org - Contribute, learn, inspire.
"Teach the way of the GP and the way of the GP shall teach you" - Me
Unread 10-03-2005, 19:02
occra 23.
AKA: ryo
None #1481
if you know how to use a servo, and understand the concept of resistors and how to read the lines you can make a clumsy mechanical real easy.
Unread 10-03-2005, 19:36
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
The problem with that is that you are not pulsing electricity, you are converting electricity into heat. The lower the voltage (speed) the higher the heat. You are making a constant power draw. The difference is the ratio of heat energy to kinetic energy.
So what I'm basically sayingis generally speaking a mechanical speed control will run down the battery faster than an electronic one, and it will get very hot. Electronic is better.
Unread 11-03-2005, 18:10
occra 23.
AKA: ryo
None #1481
So what I'm basically sayingis generally speaking a mechanical speed control will run down the battery faster than an electronic one, and it will get very hot. Electronic is better.[/quote]
yea i know but its so simple. not sure he said he was going to use a battery actually. if its unlimited power supply and littel heat isnt a problem id just make a mechanical.
PID control loops - closed loop feedback KenWittlief Technical Discussion 56 26-04-2004 21:27
