Go to Post Through 30 years of teaching I've heard the same refrain..."I love science, I love math but I can't stand my language classes". Well enough is enough. Get over it. - Mr.B [more]
Unread 10-03-2005, 19:02
occra 23.
AKA: ryo
None #1481
Re: homemade speed controlllers (for school project)
if you know how to use a servo, and understand the concept of resistors and how to read the lines you can make a clumsy mechanical real easy.
Unread 10-03-2005, 19:36
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
The problem with that is that you are not pulsing electricity, you are converting electricity into heat. The lower the voltage (speed) the higher the heat. You are making a constant power draw. The difference is the ratio of heat energy to kinetic energy.
So what I'm basically sayingis generally speaking a mechanical speed control will run down the battery faster than an electronic one, and it will get very hot. Electronic is better.
Unread 11-03-2005, 18:10
occra 23.
AKA: ryo
None #1481
So what I'm basically sayingis generally speaking a mechanical speed control will run down the battery faster than an electronic one, and it will get very hot. Electronic is better.[/quote]
yea i know but its so simple. not sure he said he was going to use a battery actually. if its unlimited power supply and littel heat isnt a problem id just make a mechanical.
PID control loops - closed loop feedback KenWittlief Technical Discussion 56 26-04-2004 21:27
