Go to Post A wet noodle of a chassis won't matter how much drop you have. - Andrew Schreiber [more]
Unread 10-03-2005, 18:22
doyler doyler is offline
Rookie / Programmer
#0900 (Infinity)
doyler is an unknown quantity at this point
Spike Problems
If I have a spike hooked up to a relay and an arm hooked into the spike how would I make the spike start at 0 volts and then go to 12 votes when a button is pushed and then back when it is pushed again
Unread 10-03-2005, 18:42
occra 23.
AKA: ryo
None #1481
Re: Spike Problems
a spike is a relay so a spike hooked to another spike? and an arm? a motor for the arm? or solenoid? button where? on the oi? or is this completely unrelated to a robot? please be specific.
Unread 10-03-2005, 20:20
Re: Spike Problems
Searching is good:
http://www.chiefdelphi.com/forums/sh...ghlight=toggle
It's verbose, and probably overkill for any specific need, but it shows the concept very well.
compessor spike fuse blows Nitroxextreme Control System 14 20-02-2005 12:38
Victor and Spike in same circuit? phillutz Electrical 4 18-02-2005 16:57
Spike (relay) module pin out coreyjon Electrical 14 05-04-2004 07:05
Spike RED Pinout Venkatesh Electrical 3 31-03-2003 21:42
Joystick problems archiver 2001 3 24-06-2002 02:40
