Go to Post We are different, on purpose, for a reason. No one in FIRST should EVER forget that. - Rich Kressly [more]
Unread 10-03-2005, 13:27
Collmandoman Collmandoman is offline
Post-A-Holic
Collmandoman has a spectacular aura aboutCollmandoman has a spectacular aura aboutCollmandoman has a spectacular aura about
Question about human disable
Would I PID controlled arm still function when the pressurepad is deactivated?
Unread 10-03-2005, 13:41
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Question about human disable
I doubt it. I believe the robot controller is put into disabe mode which makes it so nothing can operate.
Unread 10-03-2005, 14:32
Dave Scheck's Avatar
Dave Scheck Dave Scheck is offline
Dave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond repute
My understanding was that when the pressure pad was deactivated, the disabled bit gets set. When that is set, the robot is disabled which causes the outputs of the RC are held at neutral (127). Your PID loop will continue to run, however, there will be no output to your motors. Be careful that your integral component doesn't wind up while you're disabled...that could make for some interesting results when the pad was reactivated
Unread 10-03-2005, 14:46
When the robot is disabled, Victors will go to neutral, and Spikes will turn off (both FWD and REV outputs go to ground). Note that this can easily cause undesired actions if you're using any Festo valves in your pneumatics!
Unread 10-03-2005, 16:53
ConKbot of Doom ConKbot of Doom is offline
Team Alumni
FRC #1184 (Cobra Robotics)
ConKbot of Doom has a spectacular aura aboutConKbot of Doom has a spectacular aura aboutConKbot of Doom has a spectacular aura about
When it is disabled, is it really outputing neutral (127) to the victors, or is there no signal?
I know that with motor controllers it isn't really that big of a deal, but if there were say, a servo controlled latch for an arm. That could make for an interesting situation. Or servos for shifting transmissions...
Unread 10-03-2005, 20:20
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
It actually sets it to 127.
And to answer the original question:
The program continues to function, meaning your PID will still be working. However, any output is ignored by the RC. This should be fine though, because the errors will just accumulate and be corrected for when the disable is turned off.
If you're asking if you can still move the arm, the answer is no. Sorry.
Unread 10-03-2005, 23:30
Anthony Kesich's Avatar
Anthony Kesich Anthony Kesich is offline
Programmer Turned Engineer
AKA: SonKenshin
#1097 (Site 3 Engineernig)
Anthony Kesich has a spectacular aura aboutAnthony Kesich has a spectacular aura about
Send a message via AIM to Anthony Kesich
If you're worried about the PID building up, you can disable your algorithm while the robot is disabled.
There is a bit called disabled_mode that is 0 of the robot is running and 1 if its disabled. If you want, you can tell the PID only to run if disabled_mode == 0, other wise, just leave it. This will keep your integral term from building up and making the arm be crazy.
Hope this helps.
-Tony K
C is screwing up my English--I'm ending all my sentences in semi-colons;
Horray for most things! -George Carlin
"Sure, I'll play rugby. Besides, I have a lot of experience running from really big guys who want to cream me." -Me, Freshman year
What are you going to do to your Human player? Kyle General Forum 80 20-02-2005 10:58
"Triple Play" Human Player Question xtremedarkness Rules/Strategy 22 21-01-2005 17:32
Question: Missing Tetras in Human Loading Zone? tribotec_ca88 Rules/Strategy 7 15-01-2005 15:26
[FVG]: Human Players Mike Ciance FIRST-related Organizations 6 21-06-2004 21:34
