Go to Post If the pattern holds, it's a bizarro year. - GeeTwo [more]
Go Back   Chief Delphi > Technical > IT / Communications
Unread 11-03-2005, 18:08
davelu davelu is offline
AKA: fffff
#0123 (fff)
davelu is infamous around these partsdavelu is infamous around these parts
how do you writeaboot disk?
I being searching everywhere on how to write a boot disk but all my results ended up with how ot make them not how to write them. I want to write a boot disk that boots up and runs dos then automatically copys a file then restarts the computer. ANy HELP would be appreciated.
Unread 11-03-2005, 18:54
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Re: how do you writeaboot disk?
Unless you actually want to write the boot disk by collecting and/or writing from scratch the necessary files, try this:
  1. Go here and read about MS-DOS 7.10, which is effectively the back-end of Windows 98.
  2. Download this, which contains the necessary files. (Their server was very slow, so you may need to wait longer than you expect while downloading.)
  3. Get WinImage, install it (free trial period).
  4. Create a floppy disk with the image in the .zip file, using WinImage.
  5. Add RESTART.COM to the disk, in the root directory. (Attached to this post, in a .zip file.)
  6. Edit the AUTOEXEC.BAT file to include (at the end of the file) the lines:
    copy filepath.001 filepath.002
    call restart.com
    In the above, substitiute the correct path and file names that you wish to affect.
  7. Now boot the computer with the floppy. It will do its thing and then restart.
It works; I tested it on a virtual machine. Note that if you have an NTFS drive, you'll likely need a different boot disk instead, available from the same source--but since you refer to DOS specifically, I assume that you've got an computer with a FAT16 or FAT32 file system.
Alternatively, if you have access to a Windows Me or lower computer, you can create the bootdisk directly from there, then follow the same procedure to modify the AUTOEXEC.BAT file.
File Type: zip RESTART.zip (140 Bytes, 45 views)
Unread 11-03-2005, 19:01
bombadier337's Avatar
bombadier337 bombadier337 is offline
1337 U53R
AKA: Shaver
None #1541 (MidloCANics)
bombadier337 is just really nicebombadier337 is just really nicebombadier337 is just really nicebombadier337 is just really nice
Send a message via AIM to bombadier337
All you have to do is make a bootdisk, then modify the autoexec.bat to do what you need it to I believe. You could probably find a minimalist boot disk at www.bootdisk.com and then not have to worry about taking out files to clear up space.
Midlothian High School - Team 1541
2005 Radioshack Innovation in Control - NASA/VCU Regional
2005 Rookie Inspiration - NASA/VCU Regional
Unread 11-03-2005, 19:36
AKA: fffff
#0123 (fff)
Thx!
creating new boot disk Denman IT / Communications 10 31-12-2004 16:44
OCCRA Disk 2004 JoeFryman OCCRA 2 23-10-2004 17:07
Disk Shattered Joshua May Chit-Chat 15 23-09-2004 09:01
