Go to Post Nothing beats the local hardware store :). - Mike Martus [more]
Go Back   Chief Delphi > Competition > Rules/Strategy > You Make The Call
Unread 12-03-2005, 08:20
Matt Reiland's Avatar
'The' drive behind the drive
YMTC: Defensive Strategies
OK so we are all aware that there is going to be lots of interaction this year and pushing, bumping, etc.. is to be expected and you should have had your robot designed to be able to take a good amount of abuse.
Now the question: at what point does playing defense go past what was intended by the game creators and at what point level should it be penalized. After watching the webcasts for the past 2 weeks I have seen many times where a robot goes out and defends the opposite side of the field while the partners score on the opposite end of the field. Works pretty well I must say, definitely a valid strategy.
But what about teams that go out and back up and hit a robot then back up and hit a robot at high speed even continuing after getting repeated penalties for excessive ramming, a tactic that must be intended to do damage to the other robots. What should be the rule if they do it every match and continue to get similar penalties.
I would think at some point FIRST should give them a final warning then if the condition persists disqualify the team. Remember, this is different from interaction with other robots, this is backing up and ramming repeatedly.
Say your the head ref, you make the call.
Robonaut Next Generation Control System Development
2003 GLR Champions (302,67,226)
2003 Buckeye Semi-Finalists(902,494,226)
2002 Nationals QuarterFinalists
2001 West MI QuarterFinalists
2000 GLR Semi-Finalists
Extent on Defensive Game Jeff K. Rules/Strategy 1 18-02-2005 00:21
YMTC: Your Thoughts Natchez You Make The Call 16 07-01-2005 02:16
YMTC: Should YMTC have a future Natchez You Make The Call 13 21-04-2004 00:46
YMTC: Redabot accidentally breaks goal Natchez You Make The Call 9 10-04-2004 12:11
YMTC: Bluabot sits on Redabot Natchez You Make The Call 19 08-04-2004 16:43
