Go to Post So many possibilities so many different meanings and soo many different opinions. LOL but i guess this is what FIRST is all about. - Bcahn836 [more]
Unread 11-03-2005, 23:43
Chriszuma's Avatar
Chriszuma Chriszuma is offline
Jack of all trades
AKA: Chris Hammond
FRC #0068 (Truck Town Thunder)
Chriszuma is just really niceChriszuma is just really niceChriszuma is just really niceChriszuma is just really nice
Send a message via AIM to Chriszuma
Question Running a LED on 6v?
I know this isn't exactly related to FIRST, but I don't know of any other place to get the opinion of hundreds of electrical engineers.
I'm going to mod my calculator, and light up the screen with a blue LED and some fiber optic cables. I can get the fibers from a cheapo Ikea lamp of something, but I'm having trouble finding a suitable led; the calc runs off 4 AAAs (6v, in case you're anti-multiplication). I really don't want to pay $3.29 for Radioshaft's 6v-max-rated led, but I can't seem to find any other 6v ones (and i'm beginning to suspect that they are liars). What would you suggest? Possibly only wiring it to 3 of the batteries somehow, or putting a voltage regulator on there? Maybe wiring two leds in parallel (I'm en electronics newb, if you can't tell).
Thanks for your help.
~Chris Hammond
2006 T3 World Tour: Great Lakes - Waterloo - Palmetto - IRI
2006 Awards: Motorola Quality - RadioShack Innovation in Control
My website: http://zuma.phire.org/
Truck Town Thunder's website: http://trucktownthunder.com/
Unread 11-03-2005, 23:59
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Re: Running a LED on 6v?
~Chris Hammond
Use Ohm's law to figure out what size resistor you should put in the circuit. I assume that the LED wants 10mA, and the drop over the LED is somewhere around 2.5V, leaving 3.5V for the resistor. Thus, you need a resistor that is 3.5/.01 = 350 ohms, which you would put in series with the LED. If you have actual ratings for the LED, I would suggest using those, but this should be a good enough approximation. Also, a word of advice from someone fairly involved in the calculator scene: be very careful when you're doing this. The inside of graphing calculators is very delicate, and while you're trying to remove the adhesive foam between the screen and the circuit board, you may very well rip off the ribbon cable that connects the two, and there is no easy way to repair this. Once you get past that stage, removing the reflective backing from the screen is also a pain, and you'll never quite be able to get all of the adhesive off of the screen, so it will always look smeary. I gave up, and ended up buying a backlit TI-86 from someone who knew what he was doing. Nonetheless, good luck with your project.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 12-03-2005, 01:22
LEDs don't exactly run off voltage; they run off current. Being a diode, they have a characteristic voltage drop across them, so you do need to have at least that much voltage supplied. But the important part is a current-limiting resistor.
jgannon's analysis is fine. A blue LED at 2.5 volts and 10 milliamps sounds about right. Red or green LEDs usually have a much lower voltage drop, and often like much less current, though some are perfectly happy at up to 25 milliamps or more. If you can, you should look at the specific ratings for the LED you're using.
Unread 12-03-2005, 22:33
Chriszuma's Avatar
Jack of all trades
AKA: Chris Hammond
Okay, I understood around 80% of that, didn't quite extract what kind of resistor to use (please explain in newb-understandable terms). Also, when you say running it off 3.5v, do you mean altering the voltage with a regulator, or have I completely misconstrued what you were trying to tell me?
Pertaining to the delicacy of internal electronics: I have already cracked it open and examined it. I found a place to mount the led and run the fibers with a minimal of dremeling and wiring. Also, I plan on simply running the fibers up the back of the board and wrapping them around the front of the screen to get a nice front-lighting effect, since backlighting would require a lot more involved and breakage-likely operation.
Unread 12-03-2005, 22:51
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
More information than you ever wanted on LEDS and their usage:
Dan's Data LED Caselight article
Unread 12-03-2005, 23:34
Chriszuma's Avatar
Jack of all trades
AKA: Chris Hammond
thank you, that site was incredibly informative. I worked this out:
i can solve the voltage difference between my calculator batteries and the led rating by putting two in series, but then if i have too much current flowing over them i'll get thermal runaway (because their resistance goes down with temperature increase) and they'll burn up, since i can't fit a resistor in there without lowering the voltage too much.
alternately, i can use 1 led and a resistor (which i calculated to be 96 ohms, or the closest standard size)
The single-led solution seems best, but i don't know if one will be enough to light up the screen very well. Would i have a significant decrease in light if i ran them at lower voltage?
Unread 12-03-2005, 23:40
I'd go with the single LED, but I think you should be able to fit a resistor in there for the double LED.....
Unread 12-03-2005, 23:48
Chriszuma's Avatar
Jack of all trades
AKA: Chris Hammond
will it affect the brightness if its run at, say, 2.5 volts instead of 3.6?
Unread 13-03-2005, 00:11
it's always running at 3.6V. The voltage drop across an LED is a fairly fixed thing. The resistor affects how much current will be passing through the LED. Basically, if it's a 3.6V LED, that means the resistor will HAVE to have 6V-3.6V of voltage across it. So the resistor has 2.4V across it. Then you just use Ohm's law to set the resistance of the resistor to get the desire current through the circuit.
Now, the current is what actually affects the brightness of the LED. there's probably a graph of the LED's brightness vs. current somewhere if you look hard enough.
Unread 13-03-2005, 00:21
Chriszuma's Avatar
Jack of all trades
AKA: Chris Hammond
i already did the ohm's law thing. But if i were to use two leds in series to double the voltage drop to 6 volts, then i wouldnt need a resistor for voltage, but the current would still be too high.
You know what, i just realized that if i wired them in parallel I would just need a resistor to drop to 3.6v and 50mA. duh. I guess that's what the stress of winning a regional does to you.
Unread 13-03-2005, 11:42
...You know what, i just realized that if i wired them in parallel I would just need a resistor to drop to 3.6v and 50mA...
Putting diodes in parallel isn't usually a good idea. If one of them has a slightly lower voltage drop than the other, it will carry the lion's share of the current. If you want the LEDs' brightness to match, give each its own current limiting resistor (or put them in series).
Unread 13-03-2005, 16:31
Chriszuma's Avatar
Jack of all trades
AKA: Chris Hammond
to give each its own resistor, would i split the power supply wire, then put a 100-ohm resistor before each led, or would that not have the desired result?
Unread 13-03-2005, 16:35
that'd be exactly what you'd do. then tie the other end of the LEDs together.
EDIT: And I just noticed you're from team 68. Too bad you couldn't have asked me this while my team was at GLR, it'd have gone a lot quicker. Congrats on the win.
Unread 13-03-2005, 16:48
Chriszuma's Avatar
Jack of all trades
AKA: Chris Hammond
Yeah, I kinda came up with the idea on the car ride back. It was dark and I wanted to write a calculator program.
Unread 13-03-2005, 19:17
Chris,
I would not recommend two LEDs in series for this project. As the batteries discharge it is possible to fall below the voltage at which the LEDs will stay lit (i.e. the forward voltage drop of a two standard LEDs is 2v + 2v=4v.) When the battery falls below the "on" voltage, the LEDs will go out. The calculator will continue running down to maybe 3.5 volts or well below the "on" voltage of a white LED with series resistor.
As a matter of fact, I am not sure you will have satisfactory results with the light pipe idea. Before truly modifying the calculator, try breadboarding your idea to see if it works. The angle of lighting on liquid crystal displays can have a huge effect on viewing. Try a flashlight and fiber optic to test your idea before jumping into the LED wiring. You will also find a huge difference in operating time as the LED will consume much more current than the calculator.
'Program State' LED stays blinking yellow after download clynch Control System 5 18-02-2004 19:34
Making a beacon indicator LED burn its brightest without burning out DanL Electrical 7 26-01-2004 08:05
Help On Coding 2K1 Controller GregTheGreat Programming 9 05-12-2003 18:35
Rookie Programmer has question about the default code DanL Programming 3 26-01-2002 19:59
