Go to Post knowing 'my breath stinks' has helped me far more than any thanks and praise I've ever received.. - DonRotolo [more]
Go Back   Chief Delphi > Competition > Regional Competitions
Unread 13-03-2005, 19:52
abeD's Avatar
abeD abeD is offline
FRC #4707 (Mentor FRC#4707 Alumni FRC#710)
abeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to behold
Lightbulb Questions about certain calls at UCF
Ok at UCF this weekend there were somethings I have questions about:
1. If any of you saw 179 coasting back after time was called and thought it counted, well I'm pretty sure it doesn't (I was told by a referee). Why not? I thought in past years it was allowed to coast back (I think?)
2. The rule for the loading zone infractions (the 30 point one) is only if the robot that is the victim "has the intent of getting a tetra" which I can see makes sense but is subjective to interpretation. I was manning the autoload station and I thought I saw some uncalled contact.
3. This year if you come down and touch a tetra after the match is over it counts and if your arm comes down and stacks a tetra it doesn't count. I remember from last year that if you came down after time was called from hanging it didn't count (yea different years I know but alot of people were confused on the changing standard so to speak).
These arn't complaints just some observations I made during UCF this weekend. The referees were always consistent with calls and did a very good job. The first one is the one that kinda bothered me the most.
Penn Class 08
Unread 13-03-2005, 20:05
Swampdude's Avatar
Swampdude Swampdude is offline
AKA: Dan Quiggle
FRC #0179 (Children of the Swamp)
Swampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond repute
Re: Questions about certain calls at UCF
I agree about the coasting. After we did that 386 (our ally in that match) argued your same point with the ref. I stayed out of it cuz I wanted to stay on their good side
We won that match anyway and it never mattered if it counted. But I think they should reverse that ruling and allow it. It's too inconsistent with the past and actually makes it easier to score the field after it's settled. Instead of counting on the ref's to have photo finish memory.
www.179swampthing.org
Unread 13-03-2005, 20:07
Is the arm still touching the tetra when it sags and stacks? If so, that's your answer.
Unread 13-03-2005, 20:09
abeD's Avatar
No Joe I don't think so. I think i remember a match where a team was perfectly positioned over a goal and their arm dropped the tetra on after time expired and was not touching. It did not count.
Penn Class 08
Unread 13-03-2005, 20:11
igrowrobots igrowrobots is offline
igrowrobots is an unknown quantity at this point
actually if your arm or some part of your robot is touching an already scored tetra it de-scores it. that happened to us at our regional. when the drivers rushed back to get the 10 point bonus for being behind the line our arm was up so we didn't receive points for a tetra we touched even though it already had others stacked on it. it was sad
2005 5th seed Pacific Northwest Regional
2005 Highest Rookie Seed award PNR
2005 Semi-Finalist PNR (thanks 1087, 1510)
Unread 13-03-2005, 20:14
abeD's Avatar
Yes you're right. Your case is different from this though because your bot ran into the tetra during the match (right before it ended).
Penn Class 08
Unread 13-03-2005, 20:28
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Any kind of interference in a loading zone is a 30 pt penalty. FIRST removed the section that said "with intent to load a tetra"
You should be able to coast back.
And if your robot is touching a tetra of it's own color, all tetras of that color above the one touching are not counted either.
2001-2004: Team 100
2006-Present: Team 254
Unread 13-03-2005, 20:33
Ianworld's Avatar
Ianworld Ianworld is offline
AKA Ian Ferguson
AKA: Ian Ferguson
FRC #0694 (StuyPulse)
Ianworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud of
Send a message via AIM to Ianworld
I think the field should be scored after everything has stopped moving. Thats the way it always has been. If that wasn't the case, then last year hanging robots wouldn't need locking mechanisms or anything else of the sort. I remember a team that had all their pneumatics on single solienoids that defaulted to pulling the robot up and hanging. That was always counted. In 2002 robot after robot would coast into the endzone and it would be counted.
I don't know why it has been changed this year. It doesn't make sense. Its much harder to score the game right when it ends than the field at rest. The robot which caps a tetra after the match ends should get the point as long as it isn't touching it at the end.
Now as for touching a tetra that was already capped when the match ends probably means it shouldn't be capped. That was the way it has been. It doesn't make sense in terms of what counts, but it does for ease of scoring in the same way that the judges should be scoring the match after all the robots stop moving.
Team Website
Unread 13-03-2005, 20:37
Cory's Avatar
AKA: Cory McBride
I dont know about regionals you've been to, but I've never seen refs jump out onto the field while robots were still moving, so I don't know how you would score the match before everything has come to rest.
2001-2004: Team 100
Unread 13-03-2005, 20:41
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
This is wrong. As of Update #15, G15 still says that the 30 point penalty applies only to a robot recieving/retreiving a tetra. The only change in wording is to clarify that this recieving process does not end until the robot has left the loading zone. Thus, G15 still protects the introduction of tetras and is not intended to create a perpetual safe zone.
Unread 13-03-2005, 20:54
Cory's Avatar
AKA: Cory McBride
I gues you're right. I invented that section of the rules.
I am almost 100% sure that during the drivers meeting Aidan said that FIRST had made a rule change to state that any interference in the loading zone is now a 30 pt penalty regardless of intent.
2001-2004: Team 100
Unread 13-03-2005, 21:22
UlTiMaTeP UlTiMaTeP is offline
UlTiMaTeP will become famous soon enoughUlTiMaTeP will become famous soon enough
Oddly enough the same thing happened for with us, but it counted, i was in the middle of the field with 10 seconds left and went full throttle into the wall to get back in time, i did get back over the buzzer but at about 2 seconds left i was touching the stacked tetra on our goal, and yet they still counted it as stacked, so it depends on refs calls....
Hows my searching? Call 1-800-Green-Dots
47 Questions! Matt Krass Games/Trivia 52 19-04-2006 00:58
Q/A questions so far.. AmyPrib Rules/Strategy 49 28-01-2005 08:39
**FIRST EMAIL**/Autodesk Inventor Training and Technical Questions Information Rich Wong FIRST E-Mail Blast Archive 0 07-12-2004 17:22
UCF Students Etbitmydog General Forum 0 25-05-2003 02:16
Robotics at UCF Etbitmydog General Forum 0 11-04-2003 00:34
