Go to Post Chuck Norris can be the human player and throw a Poof ball into the 3 point goal and it counts. - Andy Baker [more]
Go Back   Chief Delphi > Other > Math and Science
Unread 13-03-2005, 20:45
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Proving smallest surface area of cylinder is when h=2r
I need to prove that surface area A of a cylinder (of volume V) is smallest when the height, h equals twice the radius, r.
We have two equations
1. V=(pi)(r^2)(h)
2. A=2(pi)(r^2) + 2(pi)(r)(h)
Here's what I think I need to do in order to prove the smallest A occurs when h=2r. I think I need to take equation 1 and solve for h which comes out to h=V/(pi)(r^2). Then I need to substitue that in for h in equation 2. This would make equation 2 become:
A=2(pi)(r^2) + 2(pi)(r)[V/(pi)(r^2)]
Now, I know this can be simplified, but I'm not sure if I'm doing it right. I think it would go to:
A=2(pi)(r^2) + 2V/r
Is this right? If so, what do I need to do now? I know I have to take the derivative to find the absolute minium. This is where I'm having trouble. Can someone please help? Thanks.
Unread 13-03-2005, 20:50
Joshua May's Avatar
Joshua May Joshua May is offline
Go Bears!
FRC #1110 (Binary Bulldogs)
Joshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond repute
Send a message via AIM to Joshua May
Re: Proving smallest surface area of cylinder is when h=2r
1. V=(pi)(r^2)(h)
A=2(pi)(r^2) + 2V/r
Is this right? If so, what do I need to do now? I know I have to take the derivative to find the absolute minium. This is where I'm havign trouble. Can someone please help. Thanks.
I think you've got it so far.
I believe the next step to go is to find the derivative of A=2(pi)(r^2) + 2V/r, set that to zero, solve it, and do a sign test to show that this is a minimum point.
Sorry, but I haven't done optimization problems in a few months, so I might be a little rusty, but this should set you on the right track.
The FIRST Wiki - openFIRST - Ultimate Robot Challenge - URC Wiki
I currently have 50 GMail invites, PM or email me for one.
UC Berkeley Class of 2009
2005 Las Vegas Regional Autodesk Visualization Award
2005 Las Vegas Regional #8 Seeded Alliance with 988 and 1505
2006 Southern California Regional #15 seed
Unread 13-03-2005, 21:02
I thought that's what I do, but I'm not sure how to solve it. Please help, final is tomorrow morning!
Here's what I get for the derivative:
A'=4(pi)(r) +[(2r-2v)/(r^2)]
Is this right? If so, how do I solve it.
Unread 13-03-2005, 21:04
Manoel's Avatar
Manoel Manoel is offline
FRC #0383 (Brazilian Machine)
Manoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond repute
Send a message via ICQ to Manoel Send a message via MSN to Manoel
Sanddrag,
You don't need any volume information at all. Use your second formula and take the partial derivative of A in respect to r, set it to zero and you'll achieve the desired result (except for a nasty negative sign - maybe it's irrelevant, maybe I did something wrong! ). To prove it's a minimum point, take the second partial derivative - you get a positive constant, thus, it is indeed a minimum point.
Manoel Flores da Cunha
Brazilian Machine
Team # 383
Unread 13-03-2005, 21:05
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Josh has the rest of the process right. It looks like you're going to get a 3rd order polynominial when you get dA/dr. So you should get 3 points where it equals zero. After you find the minimum, you'll have an answer for R in terms of V. You'll need to plug this back into your equation for h in terms of V and r to show that h = 2r.
Unread 13-03-2005, 21:11
Originally Posted by Manoel
Sanddrag,
if you try deriving just the second equation, then h is a variable, and you end up with a dh/dr term that you need a value for. substituting from the volume equation gets rid of this term because V is a constant in this case.
sanddrag: V is a constant in this case since you said yourself for a given volume treat it as another number. Thus:
A' = 4*pi*r - 2*V/r^2
Unread 13-03-2005, 21:17
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
Perhaps I'm missing something really obvious here, but...
Wouldn't the smallest surface area occur when h and r are as close to 0 as possible?
I mean, are we talking about in relation to something? In finite terms it'd seem that you can get a smaller surface area when you reduce either of those numbers...
Unread 13-03-2005, 21:21
we're talking about for a fixed volume. so you can't vary things at will.
Unread 13-03-2005, 21:32
Manoel's Avatar
Yes, but I was taking the partial derivative, so you just consider h a constant to take the derivative (that's far from a formal mathematical statement, but I don't know the exact English terms to make it more appropriate ).
I agree that the height and the radius are constrained by the fixed volume, but I don't see how that changes my solution.
It seems Sanddrag is taking Calculus A, or I, or 101, or whatever you call it in the USA. I didn't learn about partial derivatives until Calculus II.
Brazilian Machine
Team # 383
Unread 13-03-2005, 21:33
I can follow you here. The key IS to think of V as something like some random number (has a derivative of 0). Then when I set this equal to zero and solve I get 2V=4*pi*r^3. Then I substitue in pi*r^2*h for V and voila! it reduces down to 2h=r.
Thanks so much everyone!
Unread 13-03-2005, 21:38
The whole point of the problem is that h and r are varying, so you can't use a partial derivative and treat h as constant. At any rate, glad to hear you got it sanddrag. Looks like I forgot about setting A = 0 which makes it much easier to solve than I was thinking. oops.
Mulit-postioning with pnuematics this year? KenWittlief Pneumatics 101 01-02-2005 21:54
Stopping a Piston... Dan 550 Technical Discussion 7 02-02-2002 11:36
