Go to Post I am a mechanical engineer. I have known since I was about 12 that I wanted to make complicated mechanisms. - Paul Copioli [more]
Unread 14-03-2005, 01:21
AKA: Dr. Brooks
no team (WRRF)
Re: Robot Jumping on Power Up
Originally Posted by Mike Betts
Since we upgraded our RC to the V10 Master Code, we have noticed a problem with all PWM's jumping to full on (254) for a fraction of a second after power up.
Mike
We did not see this problem when we upgraded to V10 at the Sac regional.
If you are not using the custom pwm outputs, and have the default call that sets them up at the end of the main loop, try commenting this code out. We have had strange behavior, in the past, when this call was left in and taking it out is standard procedure at this point.
Another thing for you to check is that you are running the patch that was published by IFI late in the build period last year. Without it, you can get bad effects upon startup. If you started with this year's default code, you would have this patch.
If you resolve the problem, please post the resolution.
Best Robot Ever(again) Corey Balint General Forum 26 04-08-2004 23:03
RoboCup International Competition 2004 - Lisbon, Portugal patrickrd Televised Robotics 21 04-07-2004 05:43
Public apology from myself (Team 830) Don Wright Rules/Strategy 13 14-03-2004 22:02
Kamikaze Robot Strategy... Joe Johnson Rules/Strategy 30 07-04-2002 21:42
Calling all Lawyers... ...Define "all parts" Joe Johnson General Forum 10 13-03-2002 15:12
