Go to Post If you have time at a competition, stop and thank some of the people wearing the crew shirts. They are working very hard to make sure the competition goes as smoothly as possible. - Greg Young [more]
Unread 13-03-2005, 15:35
Electrical Engineer
Rookie Year: 1995
Robot Jumping on Power Up
Since we upgraded our RC to the V10 Master Code, we have noticed a problem with all PWM's jumping to full on (254) for a fraction of a second after power up.
This problem does not appear with a robot reset while power is on... Just once every power up.
Is anyone else seeing this or, even better, figured out what causes it?
If we are the only ones, we may have a defective controller...
Regards,
Mike
Mike Betts
As easy as 355/113...
Unread 13-03-2005, 16:10
KTorak's Avatar
KTorak KTorak is offline
Fire Rescue 47
AKA: Kyle Dersch
FRC #1023 (Bedford Express)
Team Role: Driver
KTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond repute
Send a message via AIM to KTorak
Re: Robot Jumping on Power Up
Our robot jumps when we reset it after downloading code to it...the only way we have stopped it is to just make sure its disabled when you do it.
Kyle D- Myspace - Facebook
2008 Bedford Express Driver & Build & Design (Team) Co-Leader
2007 Bedford Express Driver & Build & Design (Team) Leader
2006 Bedford Express Driver, Build Team Member, & Board of Directors
2005 Bedford Express Rookie, Build Team Member & Robot Operator
2008 - GLR Quarter Finalist
2007 - GLR Finalist & Boilermaker Finalist & MARC Off Season Event Winner
2006 - GLR Johnson & Johnson Sportsmanship Award & Archimedes 7th Seed Quarter Finalist
2005 - GLR Finalist & Judges Award.
2004 - GLR Semi Finalist.
2003 - GLR/DTR Quarter Finalist & GLR/NAT'L Rookie All Star.
Unread 13-03-2005, 19:03
team222badbrad's Avatar
3D Printing Specialist
AKA: Bradley Rigdon
FRC #0222 (The Tigertrons)
Exclamation Re: Robot Jumping on Power Up
Last year our arm would do this...
On nearly ever start up the robot would jump the drill motors powering our arm and this created a short grinding noise from the sprocket jumping the chain....
I think this only happened though when the IO was being powered from the RC with the tether?
We never really sought out a fix; we just laughed ever time it happened
(We considered the grinding noise to be the tigers ROAR!)
It probably has something to do with the firmware/software in the RC?
Tigertrons are on Facebook!
http://www.printo3d.com
16th FIRST season for me.
Unread 13-03-2005, 19:31
Electrical Engineer
Rookie Year: 1995
The problem is how to disable... If you disconnect a tether or power down the OI at a competition, your radio is active and can/will interfere with robots on the field.
JMHO,
Mike
Mike Betts
Unread 13-03-2005, 19:54
kjohnson's Avatar
kjohnson kjohnson is offline
Insert Clever Title Here
AKA: Kyle J.
FRC #1610 (BOT)
kjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond repute
We had a problem with our robot wanting to launch off of our cart when we turned it on - but as long as someone is just holding it it won't go anywhere. 1610 also had this problem (I helped them with a battery change in finals).
Unread 13-03-2005, 20:04
devicenull devicenull is offline
Robot? We need a robot?
Rookie Year: 1234
devicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nice
We aren't having this problem.. I hear no motors moving unless we tell them to
Unread 13-03-2005, 20:05
CmptrGk's Avatar
CmptrGk CmptrGk is offline
Programming Mentor
AKA: Dillon
FRC #0716 (Who'sCTEKS)
CmptrGk has much to be proud ofCmptrGk has much to be proud ofCmptrGk has much to be proud ofCmptrGk has much to be proud ofCmptrGk has much to be proud ofCmptrGk has much to be proud ofCmptrGk has much to be proud ofCmptrGk has much to be proud of
im glad to hear that this was not just a problem with our robot. but the only differnece is that it has always done it. even with the factory firmware. i thought that it was a problem in my code, that was hiding from me. well mabey there will be a fix by nationals, even though this is not a big problem it is still a problem.
"Great autonomous mode Dillon."," It hasn't been written yet"
after an Archimedes match
Unread 13-03-2005, 20:44
If you have a competition port adapter connected you should power up in 'disabled' mode
I would have someone look at your code. It sounds like maybe you are using some motion smoothing algorythm, and one of the variables gets cleared to zero on powerup (instead of the last commanded or last output value)
in otherwords, you may have variables in your code that are not correctly initialized, so the first time through the loop you get an unexpected output.
PID control can be especially tricky to initialize, there may be several variables that would have to be initalized to the right value to get a 127 output on the first pass through the loop.
Unread 13-03-2005, 20:48
kjohnson's Avatar
AKA: Kyle J.
FRC #1610 (BOT)
We do have one, so this may be the problem. It is not a "critical" problem that really needs to be fixed - its more of a nuisance.
Unread 13-03-2005, 22:11
bombadier337's Avatar
bombadier337 bombadier337 is offline
1337 U53R
AKA: Shaver
None #1541 (MidloCANics)
bombadier337 is just really nicebombadier337 is just really nicebombadier337 is just really nicebombadier337 is just really nice
Send a message via AIM to bombadier337
We only had this problem when tethering the bot. It never happened when using our radio modems during practice, but every time we plugged in the tether it jumped. I figure that's just what happens when the PWM signal generator is initialized or something.
Midlothian High School - Team 1541
2005 Radioshack Innovation in Control - NASA/VCU Regional
2005 Rookie Inspiration - NASA/VCU Regional
Unread 13-03-2005, 22:19
probizzle's Avatar
probizzle probizzle is offline
AKA: Prabhas Pokharel
#0639 (Code Red)
probizzle will become famous soon enoughprobizzle will become famous soon enough
Send a message via AIM to probizzle
Hmm,
I'm surprised so many people have the same problem.
I only had it once, and that was when I forgot to initialize all my pwms to 127. Because as unsigned chars, everything was initialized to 0, and that means that that motor was moving.
I would urge you to make absolutely sure that you initialize your pwms, because (most of the time), the robot does only what you tell it to do.
Code Red Team 639 Winners of the 2005 FingerLakes Regional with 191 and 494.
http://pset.deu83.com << my baby
http://www.setgame.com/set/ << it's mother
Unread 13-03-2005, 23:43
Electrical Engineer
Rookie Year: 1995
Ken,
I have this problem on PWMs which I do not use... If I attach a servo to them they jump after power up and then go to the "initialized" value of 127. My code (other than initialization) does not reference them but they will jump upon the next power up just the same...
Mike Betts
Unread 14-03-2005, 00:22
Dan9874123's Avatar
Dan9874123 Dan9874123 is offline
FRC #0236 (Techno Ticks)
Dan9874123 can only hope to improve
Send a message via AIM to Dan9874123
hmm, either A: it's a problem in user initialization and you need to check those values, or
B: it's a bad RC and you need to send it in for repairs, contact US FIRST about it. Although it doesn't prevent the RC from functioning properly it can be a serious safety hazard, or potentially damaging the robot.
"Better to remain silent and be thought a fool, than to speak out and erase all doubt"
Abraham Lincoln
Unread 14-03-2005, 00:39
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Mike, are you certain that all of your output variables have been initialized before you first call putdata()?
I imagine you've tried this already, but have you checked to make sure that the data you're getting from the OI is OK on the first loop? I vaguely recall someone saying that on the first loop the data they got from the OI was junk and that they had to ignore it to get rid of the problem.
Unread 14-03-2005, 01:21
AKA: Dr. Brooks
no team (WRRF)
Mike
We did not see this problem when we upgraded to V10 at the Sac regional.
If you are not using the custom pwm outputs, and have the default call that sets them up at the end of the main loop, try commenting this code out. We have had strange behavior, in the past, when this call was left in and taking it out is standard procedure at this point.
Another thing for you to check is that you are running the patch that was published by IFI late in the build period last year. Without it, you can get bad effects upon startup. If you started with this year's default code, you would have this patch.
If you resolve the problem, please post the resolution.
Best Robot Ever(again) Corey Balint General Forum 26 04-08-2004 23:03
RoboCup International Competition 2004 - Lisbon, Portugal patrickrd Televised Robotics 21 04-07-2004 05:43
Public apology from myself (Team 830) Don Wright Rules/Strategy 13 14-03-2004 22:02
Kamikaze Robot Strategy... Joe Johnson Rules/Strategy 30 07-04-2002 21:42
Calling all Lawyers... ...Define "all parts" Joe Johnson General Forum 10 13-03-2002 15:12
