#10
Re: PWM cables: too fragile? what fixes/precautions?
We have had a lot of problems with these connections. So far I have had to replace 3 pwm cables and 1 speed controller. The alignment of the connector is very very difficult, if not impossible. Be careful if you do decide to help the situation by cutting or filing the corners (provide relief) as the plastic may fall into the connector hole. We found some clips that slide in over the connector once they are seated and under the speed controller body - problem is that we have the speed controllers velcro'd down so they won't move around.
Still looking for a better way than hot glue to keep those little buggers from coming out as easily. |
| FYI about using PWM 13-16 with interrupts | cabbagekid2 | Programming | 6 | 22-01-2005 00:54 |
| Using an Operator Interface with the 2004 EDU RC wirelessly | Dave Flowerday | Robotics Education and Curriculum | 34 | 19-04-2004 19:06 |
| In need of PWM Cables! SOON! | Travis Covington | Electrical | 2 | 19-02-2004 20:55 |
| Can we shorten the PWM cables? | RAWdealer59 | Electrical | 3 | 18-02-2003 15:49 |
| Loss of signal in PWM cables. | archiver | 2001 | 6 | 23-06-2002 23:29 |
