Go to Post we would all build robots to play "rock-paper-scissors" if FIRST told us to, cause it is just so freakin' much fun to build a robot until 2:30am every night for six weeks! - dlavery [more]
Unread 14-03-2005, 14:30
meaubry meaubry is offline
volunteer helper
FRC #6099 (Knights)
meaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond repute
Re: PWM cables: too fragile? what fixes/precautions?
We have had a lot of problems with these connections. So far I have had to replace 3 pwm cables and 1 speed controller. The alignment of the connector is very very difficult, if not impossible. Be careful if you do decide to help the situation by cutting or filing the corners (provide relief) as the plastic may fall into the connector hole. We found some clips that slide in over the connector once they are seated and under the speed controller body - problem is that we have the speed controllers velcro'd down so they won't move around.
Still looking for a better way than hot glue to keep those little buggers from coming out as easily.
Unread 14-03-2005, 14:57
Originally Posted by Rick TYler
We had so much trouble with the PWM cables plugging into the Victors that we now have a team member who is the designated Cable Guy. He plays the piano and has long, thing fingers. First time every time. We'll be glad to rent him out for tournaments for a modest donation to our '06 campaign fund...
Replying to my own post. How lame is that...?
We had our arm not operate TWICE during the tournament when someone other than our Designated Electronics Guru and Cable Guy tried to plug in a PWM cable. We lost both of these rounds, but found out that we could really play defense. It was kind of fun watching our modest little wooden bot keep a 12-foot topper from scoring a single tetra, even if we still lost the match.
Of course, the real failure was that we did not detect the bad connection before the match. We bad, the 'bot was sent out to the field without a complete systems check first. This will NOT happen again next year. Note to self: if anyone is working on the robot, the electronics Guru will be the only one allowed to touch the hardware.
A team at Portland (I forget the number, but it was Santiam Christian School's team) said that they put a tiny dot of silicone adhesive on the connector after it is seated. They say the silicone is easy to remove, but grips just enough to prevent accidents.
Unread 14-03-2005, 15:09
Biff Biff is offline
AKA: Tom Cooper
#1227 (Techno Gremlins)
Biff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the rough
We have had problems with pwm cables before, especially last year with the current sensor. It was wired to keep the globe the drives our "fingers" from snapping it's sprockets and the 5/16" fiberglass rod that made up the fingers.
The connection would get noisy and finger movement became very intermittent and unpredictable. The fix for us was a can of ProGold G5 contact treatment. Sprayed on the free ends of cables and then gently run in and out of the sockets or pins a few times. This seemed to cure all of our PWM and current limiter issues. This year we will be treating all pwm cables before driving as a Standard op.
We will be at Buckeye and West Michigan if you need some I will lend you the use of a can. BTW if your on the west side of michigan you can get it at SF electroncs. Not cheap but good stuff.
Tom Cooper
Unread 14-03-2005, 17:34
Shu Song's Avatar
Shu Song Shu Song is offline
Melodious Footware
AKA: *Crash!* Shuuuuuuuuuuuu
FRC #0639 (Code Red Robotics)
Shu Song has much to be proud ofShu Song has much to be proud ofShu Song has much to be proud ofShu Song has much to be proud ofShu Song has much to be proud ofShu Song has much to be proud ofShu Song has much to be proud ofShu Song has much to be proud of
Send a message via AIM to Shu Song
Our pwm cables never failed us. The little burs on the side of the pwm insert on the victors are for keeping the pwm cables inside so it doesn't move. If you give the cable some wiggle room and keep it out of moving parts, the cable should be fine.
But when pwm cables do come out, its NOT a good thing, because those wires are live and if it touches metal, you're creating a short that goes right back to the RC, which is terrible. A fried RC is about as bad as it gets electronics-wise.
Code Red Robotics - Team 639
Ithaca High School| Ithaca | New York | USA | Earth | Sol System | Milky Way | Universe | Some Alien's Locker
WINNER of the 2005 Finger Lakes Regional, thanks to teams 191 and 494.
WINNER of the 2004 Canadian Regional, thanks to teams 33 and 1112
WINNER of Delphi: Driving Tomorrow's Technology Award at the 2007 Finger Lakes Regional.
FYI about using PWM 13-16 with interrupts cabbagekid2 Programming 6 22-01-2005 00:54
Using an Operator Interface with the 2004 EDU RC wirelessly Dave Flowerday Robotics Education and Curriculum 34 19-04-2004 19:06
In need of PWM Cables! SOON! Travis Covington Electrical 2 19-02-2004 20:55
Can we shorten the PWM cables? RAWdealer59 Electrical 3 18-02-2003 15:49
Loss of signal in PWM cables. archiver 2001 6 23-06-2002 23:29
