Go to Post We don't use fancy tools like that, but we might need some wood glue or something :) - MrForbes [more]
Unread 02-03-2005, 23:34
Calvin Calvin is offline
Calvin has a spectacular aura aboutCalvin has a spectacular aura about
Reversing controls?
Ok we shipped the robot, and now our team decided that they want to redefine which side of the robot is the front. I don't have anything to test this.. but would this work:
pwm01 = ((-1 * p2_y) + 255);
pwm02 = ((-1 * p1_y) + 255);
Unread 02-03-2005, 23:40
Electrical Engineer
Rookie Year: 1995
Re: Reversing controls?
I usually do:
pwm01 = 254 - p2y;
et cetera...
255 is usually a reserved value for these types of speed controllers.
Regards,
Mike Betts
As easy as 355/113...
MikeDubreuil's Avatar
Carpe diem
FRC #0125 (Nu-Trons)
You almost have it, add 254 instead. The controls and victors operate on values from 0 to 254. To test whether this works, try your formula in excel; it can be a great tool for determining if your algorithms are correct.
Unread 03-03-2005, 07:20
ldeffenb ldeffenb is offline
AKA: Lynn Deffenbaugh (Mr)
None #0386 (Team Voltage 386)
ldeffenb has a spectacular aura aboutldeffenb has a spectacular aura aboutldeffenb has a spectacular aura about
Send a message via ICQ to ldeffenb Send a message via AIM to ldeffenb Send a message via Yahoo to ldeffenb
Actually, testing in Excel won't fix this one. MPLAB and the IFI environment makes the pwm and joystick values unsigned chars. I'm not sure if the -1* will change this, but the 254-p1_y is certainly a safer way to go and executes faster than a multiply anyway.
Unread 03-03-2005, 21:13
Cody Carey's Avatar
Cody Carey Cody Carey is offline
AKA: C. Carey
FRC #0306 (CRT)
Cody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond repute
Send a message via AIM to Cody Carey Send a message via Yahoo to Cody Carey
Wouldn't you be able to just switch the output wires on the speed controller(s),or would that be illegal?
Unread 03-03-2005, 22:06
EricS-Team180's Avatar
EricS-Team180 EricS-Team180 is offline
SPAM, the lunchmeat of superheroes!
AKA: Eric Schreffler
FRC #0180 (SPAM)
EricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond repute
Not only do you want to reverse the output pwm values, you will also want to swap the left and right side
At the "swamp thing" scrimmage a few weeks ago, we decided to swap front and back in between rounds. After simply reversing the output pwms (255-output pwm), we found out much to our driver's amusement that not only were front and back reversed, but so were left and right
....it is also a good idea to "min/max" the outputs to stay between 1 and 254
eric
Don't PANIC!
S. P. A. M.
Unread 03-03-2005, 23:52
Ok, Thanks
Unread 08-03-2005, 21:26
xchezhd xchezhd is offline
xchezhd is an unknown quantity at this point
[/quote]
eric[/quote]
I'm trying to use the min function on digital_in14 to limit the reverse on PWM11. The motor is activated by the p3_sw_trig.
Exactly how do I use it? just call it every loop in process_data_from_local_io
==> xchezhd
Unread 14-03-2005, 22:05
FRC #0180 (SPAM)
==> xchezhd
...hmmm I suppose you are refering to:
void Limit_Switch_Min(unsigned char switch_state, unsigned char *input_value); ... in UserRoutines.c
so I'd try something like:
/* set up a temp char variable */
unsigned char lnTemp ;
/* with your input switch wired "normally open", rc_dig_in14 is normally pulled hi...ie 1 or the enum OPEN. So, closing the switch will set it 0, or CLOSED. Then if pwm11 is < 127, Limit_Switch_Min will set it back to 127
lnTemp = pwm11 ;
Limit_Switch_Min(rc_dig_in14, &lnTemp) ;
pwm11 = lnTemp ;
We didn't use this function, and, in fact, chose to wire our limit switches, normally closed. That way, they return 0 or false all of the time and 1 or true, when tripped....just a matter of taste, really...
so looking at it our way:
if (rc_dig_in14)
if ( pwm11 < 127)
pwm11 = 127 ;
...hope that helps,
Eric
Don't PANIC!
S. P. A. M.
Unread 14-03-2005, 22:22
Kyle T Kyle T is offline
waiting for next season...
FRC #0810 (Mechanical Bulls)
Kyle T is an unknown quantity at this point
Couldn't you just flip the joysticks around in the controller? :-p
Unread 14-03-2005, 22:46
We did this one round when the driver lost the arm (PWM plug problem) and decided the rear was the better choice for pushing people around. He ripped up the joysticks from the velcro and turned them around during the match.
Reversing the joystick axis JBotAlan Programming 3 09-02-2005 19:47
Controls for a Crab Drive Ein Control System 22 26-01-2005 20:31
1992 Controls Venkatesh Electrical 6 03-10-2004 22:04
[FVG]: Controls Round C1 Mike Ciance FIRST-related Organizations 18 29-07-2004 20:44
[FVG]: Controls Round B1 Mike Ciance FIRST-related Organizations 18 08-07-2004 09:32
