Go to Post hiring a monkey may not be a good idea i used that method once and it cost me a fried motherboard... - Cuog [more]
Go Back   Chief Delphi > Competition > Rules/Strategy > You Make The Call
View Poll Results: DQ or no DQ
Yes, they should be disqualified for this action 23 47.92%
No, they should not be disqualified for this action 25 52.08%
Voters: 48. You may not vote on this poll
Unread 15-03-2005, 00:24
D.J. Fluck
Posts: n/a
Re: YMTC: worthy of DQ?
I think it depends on the referees....
Ive seen referees call just the joysticks and controls as the "controls" yet then again ive seen some referees say that the entire control pannel (casing surrounding your controls and joysticks included) count....
I think its safer (and best) to just not touch anything at all that would even remotely consider the referees to DQ you.....and in your case, I think the refs were probably right to DQ you. Im sure your mentor didnt intentionally do what they did, but the refs did what they had to do, and if I were in that position, I would have done the same thing.
YMTC: Your Thoughts Natchez You Make The Call 16 07-01-2005 02:16
YMTC: Should YMTC have a future Natchez You Make The Call 13 21-04-2004 00:46
YMTC: Is it goaltending? Natchez You Make The Call 43 12-04-2004 18:03
YMTC: Redabot accidentally breaks goal Natchez You Make The Call 9 10-04-2004 12:11
YMTC: Bluabot and Redabot hanging? Natchez You Make The Call 15 23-03-2004 01:42
