Go to Post "Scientists investigate that which already is; Engineers create that which has never been." - Albert Einstein - JamesCH95 [more]
Unread 13-03-2005, 19:34
The Lucas's Avatar
CaMOElot, it is a silly place
A Warning to Human Players During Autonomous
Human Players should stand firmly on their pressure pads and avoid shifting their weight during Autonomous Mode. Any movement could cause the pressure pad to switch off and disable your robot. This could have disastrous effects on your autonomous routine. To test what actions will turn your pressure pad off, watch your green light on the end of the alliance station and shift your weight to see if it turns off.
My team has a very consistent autonomous routine that we ran in every match at the Pittsburg Regional. We did not change this routine on Friday or Saturday of the competition.
During a few matches, our autonomous routine stopped half way through the routine and our robot was disabled (indicated by a solid disabled LED on OI). We talked to the IFI guy about this and he suspected our OI might be faulty. We decided we would replace it if we ever had the problem again.
We did have the problem again in the second quarterfinal match. This time the robot stopped half way through the routine and started running a different routine that got our robot stuck in a goal. Luckily, 869 and 808 won the match for our alliance so we had had time before the semifinals to diagnose the problem.
Our autonomous routine is selected by rotary (analog) switches. The routine that ran our bot into the goal in the second half of the autonomous period is the same routine that would run if our rotary switches were set to 127 and 127 (Note: during the autonomous period, the OI transmits 127's for all analog values and 0's for all digital values). It seems the robot got temporarily disabled and read in 127's into the autonomous selection variables, then ran that routine when it reentered autonomous mode. This leads me to this warning for programmers:
If you use switches on the OI to set autonomous routines, make sure the all 127's or all 0's routine is a "do nothing" routine.
We borrowed an OI from Spare Parts and swapped it with our OI. While we were queuing up for our next match, the IFI guy told us that he thought that our pressure pad might be responsible for the disabling. This makes sense because our human player is very light and might lean toward the field to watch our autonomous routine (especially the "tetra catching" part that is always entertaining). Before the next match, we tested this by watching the green light on the end of the alliance station that indicates the state of the pressure pad (“on” indicates a human player is on the pad). Sure enough, if our human player stood on the pad and leaned toward the field, the light would turn off.
We didn't have this problem again, so I pretty sure that this human player/pressure pad interaction is the cause of our problem. It could have been a faulty OI, since we did change the OI, but that seems unlikely. We will reuse the old suspect OI in future competitions (the other OI was a loaner).
So please warn all human players and programmers out there about this potential problem.
Robot Inspector
Unread 13-03-2005, 20:40
Andy A. Andy A. is offline
Getting old
FRC #0095
Re: A Warning to Human Players During Autonomous
Thanks for the heads up!
I'll pass that along to our programmer.
I've never liked the pressure pads. This just confirms my suspicions: Pressure pads hate robots. It must be some inferiority complex or something.
-Andy A.
Unread 13-03-2005, 20:46
Alex Pelan's Avatar
Alex Pelan Alex Pelan is offline
GO IRISH
FRC #0177 (Bobcat Robotics)
Alex Pelan has a brilliant futureAlex Pelan has a brilliant futureAlex Pelan has a brilliant futureAlex Pelan has a brilliant futureAlex Pelan has a brilliant futureAlex Pelan has a brilliant futureAlex Pelan has a brilliant futureAlex Pelan has a brilliant futureAlex Pelan has a brilliant futureAlex Pelan has a brilliant futureAlex Pelan has a brilliant future
Send a message via AIM to Alex Pelan Send a message via Yahoo to Alex Pelan
Also keep in mind that there is a penalty if you leave the pad during autonomous. I did some testing of my own at UTC in the matches that I human played, and I found, even with one foot in and one foot out of the pressure pad, the green light was still lit. Thus, I got the impression that they were more forgiving than what has been described here. Anyone else notice how much pressure was needed to power on the pressure pads?
Team 177 - Bobcat Robotics (2004-2007)
University of Notre Dame Class of 2011
Unread 13-03-2005, 20:50
dont jump up and down in your excitment :^)
Unread 13-03-2005, 20:53
Wetzel's Avatar
Wetzel Wetzel is offline
DC Robotics
FRC #2914 (Tiger Pride)
Wetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond repute
Send a message via AIM to Wetzel
I saw this at least once durring VCU.
Wetzel
Viva Olancho!
Unread 13-03-2005, 20:57
Jack Jones Jack Jones is offline
Retired
Jack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond repute
It's a 30 point penalty
This message is hidden because Jack Jones is on your ignore list.
Unread 13-03-2005, 21:24
KTorak's Avatar
KTorak KTorak is offline
Fire Rescue 47
AKA: Kyle Dersch
FRC #1023 (Bedford Express)
Team Role: Driver
KTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond repute
Send a message via AIM to KTorak
Human players are also not allowed to touch/grasp/hold a tetra in anyway until the autonomous period has ended.
Kyle D- Myspace - Facebook
2008 Bedford Express Driver & Build & Design (Team) Co-Leader
2007 Bedford Express Driver & Build & Design (Team) Leader
2006 Bedford Express Driver, Build Team Member, & Board of Directors
2005 Bedford Express Rookie, Build Team Member & Robot Operator
2008 - GLR Quarter Finalist
2007 - GLR Finalist & Boilermaker Finalist & MARC Off Season Event Winner
2006 - GLR Johnson & Johnson Sportsmanship Award & Archimedes 7th Seed Quarter Finalist
2005 - GLR Finalist & Judges Award.
2004 - GLR Semi Finalist.
2003 - GLR/DTR Quarter Finalist & GLR/NAT'L Rookie All Star.
Unread 14-03-2005, 00:15
meiv4 meiv4 is offline
The Jimmy
AKA: Jimmy Dolengewicz
FRC #1388
meiv4 is on a distinguished road
Send a message via AIM to meiv4
once at the Sac regional one humal player was running back to the pad and he tripped so as he fell he kinda launched himself at his pad and barly got his hand on it, but it didnt register, it sure was a valient effort though.
pie = 8.53973422
Unread 14-03-2005, 00:34
AKA: Dr. Brooks
no team (WRRF)
Our autonomous routine is selected by rotary (analog) switches. The routine that ran our bot into the goal in the second half of the autonomous period is the same routine that would run if our rotary switches were set to 127 and 127 If you use switches on the OI to set autonomous routines, make sure the all 127's or all 0's routine is a "do nothing" routine.
If you are using the switches on the OI to select the autonomous mode, you should read and save the values while the robot is disabled, and write code that sets a flag to stop saving the value once the robot has been enabled. That way, a spurious disable will not affect the autonomous mode.
It is interesting that the human player on the pad can communicate with the robot by shifting his/her weight on the pad. I am sure that FIRST did not intend this. We use a set of switches on the robot to select the autonomous mode in binary. Values set by these switches are not affected by the disabled state...
Unread 14-03-2005, 02:49
The Lucas's Avatar
Another way to make sure the routine selected on the OI is not changed during a spurious disable (autonomous_mode and disabled_mode both = 1) is to set the auto select variables if not in autonomous mode like such:
if(!autonomous_mode){
//set auto select variables
However, this may result in certain variables (step, gyro, encoder, coordinate, integral, etc..) being reset or incorrectly changed, depending on your code. If that is the case, your robot would likely restart the same routine at a different starting point or go haywire in some another way.
I personally would prefer to just cut bait and sit out the rest of the 15 sec with a "do nothing routine", than risk getting stuck in a goal again. We were lucky to win that quarter final match. We were stuck for nearly the entire match and committed a 10 point penalty, but 869 and 808 overcame all that and won it for the alliance.
Robot Inspector
Unread 14-03-2005, 12:09
AKA: Dr. Brooks
no team (WRRF)
Are you intending that a momentary lift on the human player
pad change the autonomous program that is selected after the
match starts?
Unread 14-03-2005, 12:28
DarMagi DarMagi is offline
DarMagi will become famous soon enoughDarMagi will become famous soon enough
We never had a problem with the pressure pad or our human player on the pressure pad, although we didn't have any purposeful auton modes except go to the human loading zone and fun acress the field into other bots but besides that, the pressure pad fine, we never once lost power to our bot, although an OI at the competiton did give us problems in one of the stations... that's another story... Also be careful to not touch any tetras until the auton period is over, that is when the signal goes off and not when the clock resets to 120. Our human player grabbed a tetra when the clock hit 120 seconds after the 15 second auton, but the signal did not go off until 119 seconds left, with that we got one 10 point penalty for touching a tetra while in auton mode. So my warning to all teams is to not touch tetras until the buzzer goes off and the drivers are able to step forward and drive their bots. Penalties are bad, don't get hit with them for things like that.
Unread 14-03-2005, 22:47
The Lucas's Avatar
match starts?
No, I am not saying you should use this to change your autonomous in order to find a vision tetra or anything like that. I am saying that a momentary disable (from the human player pressure pad) would likely mess up any autonomous routine and may change to a different routine (one selected by all 127s or all 0s coming out of the operator interface) depending on how you select your routine. Most teams who have selector switches have a "do nothing" setting. I am simply suggesting that programmers make this "do nothing" the same as all 127s or all 0s, which is the output during autonomous mode and also the output if the switches fail. Obviously, everyone's autonomous code is different and will react differently to a disable, but it doesn't hurt to make all 127s or all 0s a "do nothing" setting.
I am not saying problems with the pressure pad are at all common. I didn't even figure this one out myself, the IFI guy suggested the pressure pad disable was the cause of our problem and I agree with him. As I said before, our human player is very light, around 110 lbs (Alex you will see him at Philly).
We had this problem and I am trying to warn others about this potential problem. It was a very frustrating problem to diagnose, especially since you can't simulate the controllers and pressure pads on the field with a simple dongle box (it still sends OI data in autonomous, so you could even drive the robot with a joystick if you wanted). If everyone is aware of this potential problem, it doesn't take much to prevent it from ever happening again.
Robot Inspector
Unread 15-03-2005, 07:58
C. Morrison's Avatar
C. Morrison C. Morrison is offline
#0871 (West Islip Robotechs)
Team Role: Student
C. Morrison is on a distinguished road
Send a message via AIM to C. Morrison
Is there a weight requirement for the pressure pads to remain active?
-2002-SBPLI Rookie All Star
-2002-WPI BattleCry3- Rookie All Star-2003- SBPLI Regional Finalists
-2004- SBPLI Semi-finalists-2004- SBPLI- MR. B-Woodie Flowers Award
-2004-SBPLI- Regional Chairman's
-2005 Business Sub-Team leader
Unread 15-03-2005, 08:13
Validius's Avatar
Validius Validius is offline
There is a shadow following me.....
AKA: Mark Ratering
FRC #1549 (Washtenuts)
Validius will become famous soon enoughValidius will become famous soon enough
Send a message via AIM to Validius
i dont know how much wieght you need. all our HPs are 150+ pounds
When a sociaty comes to believe that human life is not inherently worth living, it is a slippery slope to the gas chamber. You wind up on a low road that twists past Columbine and leads toward Auschwitz.
-Peggy Noonan
Are you planning to use your Human Players? Swampdude Rules/Strategy 23 09-02-2005 19:37
Traits of the Drivers, Coaches, and Human Players mhayon General Forum 34 08-02-2005 09:26
[FVG]: Human Players - All AI? Mike Ciance FIRST-related Organizations 4 05-07-2004 20:38
[FVG]: Human Players Mike Ciance FIRST-related Organizations 6 21-06-2004 21:34
