Go to Post Probably planning on milling the bumpers out of solid pool noodle stock, too. Ever wonder how they drill that hole down the middle of pool noodles? ;) - Bill_B [more]
Unread 15-03-2005, 08:18
Validius's Avatar
Validius Validius is offline
There is a shadow following me.....
AKA: Mark Ratering
FRC #1549 (Washtenuts)
Validius will become famous soon enoughValidius will become famous soon enough
Send a message via AIM to Validius
Pressure sensative Joysticks
I'm looking for a good pair of pressure sensitive joysticks. they have to be able to interface with the OI. For those who dont know, pressure sensitive joysticks dont actually move (noticeably) they feel how hard they are being pushed (using coils of wire and measuring changes in capacitance). I find it much more natural to drive with pressure sensitive sticks then normal joysticks. Does anyone know were i can find a pair?
When a sociaty comes to believe that human life is not inherently worth living, it is a slippery slope to the gas chamber. You wind up on a low road that twists past Columbine and leads toward Auschwitz.
-Peggy Noonan
Unread 15-03-2005, 13:59
Re: Pressure sensative Joysticks
I don't think you'll find any that can connect directly to an IFI Operator Interface. It's pretty specific in wanting to read a 100k variable resistor.
You might manage to come up with a circuit that can be powered by the OI, connect to a force-sensitive joystick, and provide a voltage that will satisfy a joystick input pin. Unless you're an accomplished circuit designer, however, I suggest you learn to drive FRC robots using your wrists instead of your fingers.
PRESSURE SWITCH Mr. Steve Pneumatics 20 01-12-2005 10:20
[ECDU]: pressure Michael Leicht FIRST-related Organizations 1 02-12-2004 16:38
Translating pressure sensor readout into actual pressure Mercutio Pneumatics 0 13-02-2004 16:29
Auto Air Pump Code zorro Programming 25 05-01-2003 16:50
Need help with 255 Variable Joseph F Programming 18 26-02-2002 14:49
