Go to Post I, for one, have no particular problem with singing, dancing and sex appeal. Mark Leon combines all that with a career at NASA! - Rick TYler [more]
Unread 15-03-2005, 14:01
Arc736UV Arc736UV is offline
Arc736UV is an unknown quantity at this point
CMU Cam GUI
everything was followed in the user manual for the cmu cam setup but when the gui is started an errror message pops up saying "error reading file config.txt" and then it ask for port and after that nothing works in the gui.any advice?<were pretty sure that the hardware is setup right>
Unread 15-03-2005, 16:06
bombadier337's Avatar
bombadier337 bombadier337 is offline
1337 U53R
AKA: Shaver
None #1541 (MidloCANics)
bombadier337 is just really nicebombadier337 is just really nicebombadier337 is just really nicebombadier337 is just really nice
Send a message via AIM to bombadier337
Re: CMU Cam GUI
Are you trying to use windows to open the zip file without extracting everything? It could very possibly be looking for a config file that hasn't be extracted yet. If that doesn't work redownload the whole thing from www.ifirobotics.com . As far as not connecting, the config file is probably the fault, but also make sure you don't have the rs-232 signal going to the robot plugged in (maybe it was just us but our camera never connected with it plugged in). Hopefully that helps you, if not, I'll do anything i can to help.
Midlothian High School - Team 1541
2005 Radioshack Innovation in Control - NASA/VCU Regional
2005 Rookie Inspiration - NASA/VCU Regional
Unread 15-03-2005, 19:26
Electrical Engineer
Rookie Year: 1995
Re: CMU Cam GUI
Be sure that you are using the files from the "start here" link on this site. There is another zip file floating around named CMUcam2GUI.zip (I think it was from the Carnegie Mellon web site) which does not have all files you require.
Mike Betts
As easy as 355/113...
The *BIG* CMU Howto pi_guy578 Programming 17 21-12-2005 13:24
Grid on CMU Cam Java GUI Leav Programming 0 14-02-2005 17:06
CMU Cam servo jitter adamdb Programming 3 01-02-2005 14:42
CMU cam and Linux? scitobor 617 Programming 2 30-01-2005 23:02
pic: (447) Our CMU CAM BOX rufu5 Extra Discussion 2 17-01-2005 19:10
