Go to Post Now I'm off to see the wizard, the wonderful wizard of Cogs. - Matt Krass [more]
Unread 15-03-2005, 00:34
AKA: Dr. Brooks
no team (WRRF)
Re: SLU-70 Lugs
Originally Posted by KTorak
We are iffy on this new connector, our robot got hit causing the wire to pull out of the connector in a seeding match (our second of the day). We were very dissappointed that it came out considering we originally had a really good crimped connection.
There is good reason to be iffy on this connector, but it is required by the rules this year. If you do not solder the wire in after you have tightened the screw, it can pull loose as you have experienced. If you solder, you need to use a larger iron and clean the copper well before you assemble the connector. Tin plating helps soldering a great deal if you have means to do this.
Unread 15-03-2005, 00:47
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: SLU-70 Lugs
I've tried every iron and soldering gun I have to solder Anderson Contacts onto 6 ga wire and I just cannot get it anywhere near hot enough. The best thing that I've found is a small butane pencil torch, but mine broke so now I use the big propane torch. It gets hot enough but it is a real pain because the flame is so large.
Unread 15-03-2005, 00:51
activemx's Avatar
activemx activemx is offline
A M X
AKA: Akshay Dodeja
activemx is a glorious beacon of lightactivemx is a glorious beacon of lightactivemx is a glorious beacon of lightactivemx is a glorious beacon of lightactivemx is a glorious beacon of light
Send a message via AIM to activemx Send a message via Yahoo to activemx
Re: SLU-70 Lugs
Yeat I remember when we had the monster cable 4 Guage cable at 115 it was impossible to solder with a iron. The crimp was'nt good enough. We figured a butane torch would be the best and it wourked out. Hahah i can just image use a propane torch that would just burn the cable ends. Try a small torch you can get at home depot or online.
2005 - Present - FIRST Volunteer(Inspector, Ref, Judge)
2000-2004 MVRT 115
Unread 15-03-2005, 01:46
AKA: Dr. Brooks
no team (WRRF)
Re: SLU-70 Lugs
We use a soldering iron that runs a bit hotter than most, and has a large tip, for soldering lugs. Ours is a Hakko unit that is no longer sold, but the Hakko 456-16 iron, 60watts, 1110F, is equivalent. It is important that you do not clamp the lug in a vice, it will draw away needed heat.
If you need to solder lugs in the pits,
please remember that open flames are forbidden there.
Unread 15-03-2005, 01:58
The Lucas's Avatar
CaMOElot, it is a silly place
Re: SLU-70 Lugs
While working with Team 1495, we soldered these with the only soldering iron available, a 25-watt Radio Shack iron. It took about a half an hour per connector. These stupid things make an excellent heatsinks.
Robot Inspector
Unread 15-03-2005, 02:11
Re: SLU-70 Lugs
I'm worried that in this case all you have done is created a "blob" (for lack of a better term) of solder. A good solder joint is a hot one, and hot solder joints happen quickly. You may have just filled in the gaps without providing any increase in mechanical or electrical integrity.
I have a question, assuming you only screw down the lug, do you get a better connection on more finely stranded wire? Like good welding cable as opposed to the junk battery cable they give us?
Unread 15-03-2005, 02:19
activemx's Avatar
A M X
AKA: Akshay Dodeja
Re: SLU-70 Lugs
You will get better conection with the thin stranded copper cable. It is more expensive but it is easier to solder and crimps better then those wires that have barely any flexibility.
2000-2004 MVRT 115
Unread 15-03-2005, 02:35
AKA: Dr. Brooks
no team (WRRF)
Re: SLU-70 Lugs
If the solder flows through the wire and joint you have a good solder connection. Someone practiced at soldering will know what good solder flow looks like. I would not try to solder the SLU-70 lugs with a 25 watt iron, however.
We use #6 welding cable for our power wiring for its flexibility and high quality rubber insulation. The problem with this cable on the SLU-70 lugs is that the wire is fine enough to work its way through gaps in the clamping mechanism. You can end up with a connection that loosens. Solder the connector after clamping the wire it in order to remove this possibility. I would never use the SLU-70 lugs without soldering them.
Unread 15-03-2005, 09:00
The Lucas's Avatar
Re: SLU-70 Lugs
That is a valid concern especially when working with a 25-watt iron. I can confirm it is a good hot solder joint. I had a student hold the iron on the bottom of the lug and I applied the solder directly to the top of the wire. As soon as the whole system heats up, the solder flows through the wire and down to the bottom of the lug. The result is a thoroughly tinned wired and bottom of the lug. We even avoided soldering the screw and clamp so we can still screw that down. It was also a good lesson on what it takes to make a good hot solder joint, and that student's small wire soldering skills improved.
Team 1495 works in a school metal shop and has few electrical tools. Soldering with a 25 watt iron is fairly dangerous, since you have a very hot wire and lug near your hands for about half an hour. However it is possible, so you could do it in a pinch. A micro torch is a better idea and that is what Team 365 is going to use on all the new SLU-70 lugs we had to use after we found out that rule at Pitt.
Robot Inspector
Unread 15-03-2005, 10:47
Doug G's Avatar
Doug G Doug G is offline
Coach / Teacher
FRC #0701 (Robovikes)
Re: SLU-70 Lugs
We over looked that rule as well and this year we thought we're on top of it by soldering all our 6 gauge crimp connections - oh well - we replaced them with the SLU-70 lugs and all was well they held up through 15+ matches. I did notice a couple of rookie teams that had their lug screw pressing onto their wire instead of the screw pressing onto the V shaped clamp and then agaist the wire. Perhaps this might be why some teams had them coming loose.
Unread 15-03-2005, 14:30
Re: SLU-70 Lugs
Originally Posted by Rombus
Since im going to be doing wireing next build year, what about soldered lugs?
Rick,
The electrical rules have changed each year for several years now. You will need to check next year's rules in order to be in compliance for your 2006 robot.
Unread 16-03-2005, 15:10
Daniel Daniel is offline
Daniel Katanski
#0240
Daniel is on a distinguished road
Re: SLU-70 Lugs
Originally Posted by BrianBSL
Although at first I was not a fan of these - they are a large improvement over what most teams were using in the past, particularly now that FIRST no longer includes a crimping tool truly capable of crimping 6 gauge connectors in the kit. I'm pretty picky about electrical connections, and every non-signal connection on our robot is crimped then soldered and heatshrinked, including the SLU-70's. We also put a little bit of solder into the setscrew of the lug to add something to prevent it from loosening. Solder isn't really good at doing mechanical things, but its an improvement over just leaving it. All of this, of course, requires that you have a soldering iron capable of heating up the copper connector and 6 gauge wire.
An important point that you missed is "Strain Relief". That is, tie wrap your wires to a piece of the frame near the SLU70 so that part of the #6 wire will not move. This is the biggest problem with any mechanical connect, and it can be solved so easily. I'm trying to find a lug with strain relief to solve all of out problems.
Unread 05-04-2005, 13:06
Re: SLU-70 Lugs
I thought it important to resurrect this thread and remind everyone that although the rules were relaxed for this last weekend (difficulty in obtaining the parts) SLU 70 connectors will be required at nationals. Home Depot, Menards, Lowes, Ace Hardware and of course Terminal Supply are all sources of this connector. Please watch for changes from FIRST, until then, Be Prepared!
Unread 12-04-2005, 08:40
cbolin's Avatar
cbolin cbolin is offline
Programming & Electrical
FRC #0342 (Burning Magnetos)
cbolin is a splendid one to beholdcbolin is a splendid one to beholdcbolin is a splendid one to beholdcbolin is a splendid one to beholdcbolin is a splendid one to beholdcbolin is a splendid one to beholdcbolin is a splendid one to behold
Re: SLU-70 Lugs
Our team came in last evening and changed out the connectors on all 9 batteries. Our electrician had done a good job crimping and taping (lots of it) so it took us a lot of time to get the battery plugs off of the battery. Whew!
We also connected those Anderson plugs on all four of our battery chargers to make charging easier, safer and less likely to reverse charge the batteries.
Remember...only 9 more days to get this done!!
Regards,
ChuckB
Team 342 Programming & Control Systems
Good luck and have fun!
Unread 12-04-2005, 09:19
Jack Jones Jack Jones is offline
Retired
Jack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond repute
Re: SLU-70 Lugs
Regards,
ChuckB
OMG - Outside the window! Get ready to do-it-again, 21-April?
PS: Does FIRST honor the FIFTH Amendment?
This message is hidden because Jack Jones is on your ignore list.
Anderson Copper 70 Lugs xFlashbacksx Electrical 5 19-02-2005 12:33
Spazing Robot Matthew_H Electrical 15 19-04-2004 07:49
