Go to Post More inspired students, more community involvement, less drain on the mentors... Sounds pretty swell to me! - Karthik [more]
Unread 15-03-2005, 20:02
Validius's Avatar
Validius Validius is offline
There is a shadow following me.....
AKA: Mark Ratering
FRC #1549 (Washtenuts)
Validius will become famous soon enoughValidius will become famous soon enough
Send a message via AIM to Validius
A poximity sensor that works with IFI gear
Does anyone know of a 5 volt proc sensor that will work on the 5 volts that the robot controller supplies? I wanna detect steel.
When a sociaty comes to believe that human life is not inherently worth living, it is a slippery slope to the gas chamber. You wind up on a low road that twists past Columbine and leads toward Auschwitz.
-Peggy Noonan
Unread 15-03-2005, 20:16
Matt Krass's Avatar
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
Re: A poximity sensor that works with IFI gear
The hall effect gear tooth sensors could do that, but they're a bit tiny, if this is going to be external on the robot, you might want something a little more formidable.
And be careful not to barbecue the little sucker like we did.
Matt Krass
Unread 15-03-2005, 22:05
seanwitte seanwitte is offline
None #0116
seanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant future
Send a message via AIM to seanwitte
Re: A proximity sensor that works with IFI gear
The Sharp IR proximity sensors work great. The connectors and sensors are available at acroname.com. You can also buy them from digi-key, but I don't think they sell the JST connectors. Parts with 0-5V analog outputs:
1) GP2D120, range 1.5" - 12"
2) GP2Y0A02YK, range 8" - 60"
Unread 15-03-2005, 22:59
Validius's Avatar
AKA: Mark Ratering
hmmm, i was hoping for digital but perhaps i can work it out
-Peggy Noonan
Unread 15-03-2005, 23:03
Validius's Avatar
AKA: Mark Ratering
those wownt work. I need a sensor that can tell the differance between steel and renbord
-Peggy Noonan
Unread 16-03-2005, 08:51
None #0116
Sorry, should have paid more attention to the question! What you want is an inductive proximity sensor. I've never used them, but I know they have a very short range (< 10mm). If you explain what you're trying to do maybe someone can help you come up with a suitable alternative.
Unread 16-03-2005, 09:14
coreyjon's Avatar
coreyjon coreyjon is offline
Flight Engineer
FRC #0250 (Team 250 Dynamos)
coreyjon is just really nicecoreyjon is just really nicecoreyjon is just really nicecoreyjon is just really nicecoreyjon is just really nice
Send a message via AIM to coreyjon
Could you make a setup similar to a metal detector? On the front of your robot you could have a coil and send a pulsing current though it, when you get close to the steel, the induction of eddy currents can be detected using various methods, and you could set it up to go toward the source inducing the eddy currents..maybe. This is just an idea to help create others. I'm sure this can be done, just would take some experimenting. Good luck on your project.
"Jack of all trades, master of none, though offtimes better than master of one".
Unread 16-03-2005, 19:41
sven sven is offline
sven will become famous soon enoughsven will become famous soon enough
My team used a 12v prox sensor I think. We just choped up a pwm cable and spliced in some 12v power from the breaker planel.
Unread 16-03-2005, 21:18
Validius's Avatar
AKA: Mark Ratering
OK, here is that i wanna do:
The winch on our but is made out of renboard (a plastic composite). We have no way of sensing its position. there is no way to do a pot, we already tried.
We have 2 options, both involve drilling 4 really small holes at 90 degree intervalls in the center of the winch (the cable never gets that far, the drum is threaded). Ofter that we either glue 4 magnets or screw in 4 screws. If we have screws we would have proximity sensors that cound every screw going by (4 counts=1 turn). If we used magnets then we would use reed switches to count.
I like the proc switches better then reed switches and we may be able to use the hall effect gear tooth sensors if we can find them.
-Peggy Noonan
Unread 16-03-2005, 21:51
scitobor 617's Avatar
scitobor 617 scitobor 617 is offline
More nerd than you can handle!
AKA: Alan Meekins
FRC #0617 (HSHS 617 "DUKE")
scitobor 617 will become famous soon enoughscitobor 617 will become famous soon enough
Send a message via AIM to scitobor 617
May I suggest Banner sensors and black paint.
Beta testers needed!
http://www.nullagent.no-ip.com
Your kidding, there are other operating systems besides Linux?!
Unread 16-03-2005, 21:56
None #0116
I think the gear tooth sensors are the way to go based on what you've described. Read through the data sheets carefully because they do more than just detect a gear tooth.
pic: 6 speed?? Great in theory - lets see how it works! CD47-Bot Extra Discussion 63 28-10-2008 02:13
Gear pitch preference Andy Baker Technical Discussion 15 04-10-2004 09:51
gears Michael Leicht Inventor 12 16-09-2004 10:52
Reverse Gear FizMan Technical Discussion 12 26-04-2004 01:29
Thunder Chicken CCT Simon G Motors 4 03-01-2003 13:18
