Go to Post Suggesting change is one thing, implementing it is another. - JaneYoung [more]
Go Back   Chief Delphi > Technical > IT / Communications
Unread 20-03-2005, 00:36
JulieB's Avatar
JulieB JulieB is offline
well........
AKA: Just Julie!
FRC #0538
JulieB is a glorious beacon of lightJulieB is a glorious beacon of lightJulieB is a glorious beacon of lightJulieB is a glorious beacon of lightJulieB is a glorious beacon of lightJulieB is a glorious beacon of light
Send a message via MSN to JulieB
Webpage software?
Can anyone think of some good webpage maker software?
Unread 20-03-2005, 00:43
Joshua May's Avatar
Joshua May Joshua May is offline
Go Bears!
FRC #1110 (Binary Bulldogs)
Joshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond repute
Send a message via AIM to Joshua May
Re: Webpage software?
I've always been partial to Notepad, but you may also check out Microsoft FrontPage and Macromedia Dreamweaver.
The FIRST Wiki - openFIRST - Ultimate Robot Challenge - URC Wiki
I currently have 50 GMail invites, PM or email me for one.
UC Berkeley Class of 2009
2005 Las Vegas Regional Autodesk Visualization Award
2005 Las Vegas Regional #8 Seeded Alliance with 988 and 1505
2006 Southern California Regional #15 seed
Unread 20-03-2005, 00:44
MrToast's Avatar
MrToast MrToast is offline
I named Greg Needel's cat!
AKA: Dave DeLong
no team (Rhode Warriors)
MrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud of
Send a message via AIM to MrToast
If you're on a Mac, check out these titles:
RapidWeaver
BBEdit or TextWrangler
I've surfed around a lot for web page software (I'm a site designer), and these are the best one's I've found. Here are some other miscellaneous links:
WordPress, an open source weblog
Transmit 3 (FTP client)
HTH!
Dave
(#121, 2004) Archimedes semi-finalists with 237 and 386! I had an awesome time guys, and thanks for the hat!
(#121, 2004) BC5 semi-finalists with 190 and 1027! Awesome time! We went further than I thought we could! Thanks for all your help w/ our transmission!
(#121, 2005) Galileo quarter-finalists with 47 and 203! Thanks for all your support through the stress!
If it moves and it shouldn't, use duct tape.
If it doesn't move and it should, use WD-40
"It'll all work out in the end, and if it doesn't, it's not the end." - Jeff Bullock
Unread 20-03-2005, 00:47
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Back in the day when I did my team's web site, I used www.coffeecup.com They make some pretty good software that is easy to get started and to learn with. It can make some good looking pages without too much trouble. Also, if I remember correctly a 30 day trial is free and the full version is only like $40.
As for frontpage, I'll tell you that I absolutely hate it. As for Dreamweaver, I have only watched someone use it but it seems pretty good.
Unread 20-03-2005, 06:27
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Dreamweaver is great. They have a thirty day trial, but you'll get hooked....
Macromedia Homesite is basically stripped down Dreamweaver. It's also very good and the full version is much cheaper.
Other than that, I'd say go to a place like http://www.download.com and look in their editor section for something you like. (Direct link: http://www.download.com/Editors/3150...0.html?tag=dir)
Unread 20-03-2005, 09:38
JonBell JonBell is offline
None #0546 (Technotics)
JonBell is just really niceJonBell is just really niceJonBell is just really niceJonBell is just really niceJonBell is just really nice
Send a message via AIM to JonBell
I'm just setting up our website (for team 546), and I use the Mambo CMS, and BBEdit for customizing templates and writing modules. I was going to write it all out by hand, but then I realized that this way it will be much easier for other people on the team to update it, seeing as it's in a CMS.
What about openFirst?
Unread 20-03-2005, 10:42
theory6's Avatar
theory6 theory6 is offline
FRC #1241 (theory 6 - team hansen experience of robotic youth)
theory6 is just really nicetheory6 is just really nicetheory6 is just really nicetheory6 is just really nicetheory6 is just really nice
Simple HTML can do wonders. I'd recommend Dreamweaver like many others above me, because its simple to use after the first few tries and VERY powerful in terms of productivity and efficiency. However the only drawback is that to use the full potential of Dreamweaver you will need to know a bit of coding (PHP or Javascript) to give your webpage an extra edge.
There are tons of free D-I-Y webbuilders. One that I used to use when I first started is Arachnophobia. Very basic yet very effective.
Visit Our GTR Winning Website: theory6 - Team 1241
Unread 20-03-2005, 10:57
DeepBluSomethin DeepBluSomethin is offline
Webmaster
AKA: Matt Blumenthal
None #1168 (Malvern Robotics)
DeepBluSomethin is an unknown quantity at this point
I just code everything by hand in Editpad Pro, but you can't go wrong with Dreamweaver.
Unread 20-03-2005, 11:27
Ashley Weed Ashley Weed is offline
Rookie Year: 1995
Ashley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond repute
If you want to do JAVA, Borland has packages out to download in previous versions, and newer trial versions available.
The Developer and Foundation will be what you are looking for in a JBuilder Environment.
check JBuilder downloads
Attention engineers...What type are you and why? Paul H Career 95 05-04-2007 14:38
Software Development Process? tcj103 Programming 5 08-02-2005 15:46
software software software archiver 2001 5 24-06-2002 00:21
