Go to Post FIRST is like a big roller coaster, that can only be experianced if one takes a ride which can become a liftime experiance. - activemx [more]
Unread 20-03-2005, 14:10
Mike's Avatar
Mike Mike is offline
has common ground with Matt Krass
AKA: Mike Sorrenti
FRC #0237 (Sie-H2O-Bots (See-Hoe-Bots) [T.R.I.B.E.])
Mike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond repute
Why printf?
Why do we use printf? I started c at the beginning of 6 weeks (minus about a week of c++), but knew PHP before that. In PHP you use the print statement where you just go
<?php
print "The variables value is: $variable";
whereas in c you have to write
printf("The variables value is: %d", variable);
Can you use print() in c? If so why doesn't FIRST?
http://www.mikesorrenti.com/
Unread 20-03-2005, 14:40
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
Re: Why printf?
I am not sure that C has a print() function. If it did, it would be functionally identical to printf, I imagine. PHP is an entirely different language than C, and they have different syntax and commands and functions.
Don't forget, not all computers have the same outputs, so you can 'print' to several different things (a printer, a serial connection, a monitor).
Unread 20-03-2005, 15:08
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Re: Why printf?
PHP is an interpreted language, but C is compiled. In C, everything in between the quotes is stored verbatim in the binary image that gets executed. By the time the program is compiled, your program no longer knows what the variable names were so it could not parse the variables out of the string. Even if it did know the variable names, it would need special knowledge of where the variable was actually stored.
I can't think of any way that it would even be possible to do this in C without doing some pre-processing before it got to the compiler.
Unread 20-03-2005, 15:10
Validius's Avatar
Validius Validius is offline
There is a shadow following me.....
AKA: Mark Ratering
FRC #1549 (Washtenuts)
Validius will become famous soon enoughValidius will become famous soon enough
Send a message via AIM to Validius
Re: Why printf?
printf is print formatted
I know that in perl there is both print and printf but printf is far more powerfull
When a sociaty comes to believe that human life is not inherently worth living, it is a slippery slope to the gas chamber. You wind up on a low road that twists past Columbine and leads toward Auschwitz.
-Peggy Noonan
Unread 20-03-2005, 15:44
jdiwnab's Avatar
jdiwnab jdiwnab is offline
Really the Inventor Guy
AKA: Bryan Hartley
FRC #0617
jdiwnab is a jewel in the roughjdiwnab is a jewel in the roughjdiwnab is a jewel in the rough
Re: Why printf?
<?php
There isn't much of a difference between how the two functions are coded. Print() has the varible listed in the string. Printf() has the varible outside of the string. They work about the same. One difference is the d in %d could also be %f for floats and other things like that. This lets you say the type of varible you think you are going to see. It could truncate a long float if you don't need to see all of it. Or other things like that. Printf() is more powerful, and is coded about the same. Printf() just adds one more step.
Proof that Macs will win the platform war: How did Scotty know how to use MacDraft in Star Trek IV?
// random()
I have 100 gmail invites. PM me if you want one.
If they want us to think outside of the box, why do they make us fit in a 38x28x60 inch box?
Beware of Geeks bearing GIFs
Help me test my server software
Unread 20-03-2005, 15:54
Mike's Avatar
AKA: Mike Sorrenti
Re: Why printf?
Thanks guys, I just wasn't too sure.
Printf Oddity : Programming Challange DarkAlex Programming 7 21-03-2005 08:12
printf statements do not display in autonomous mode PVC Pirates Programming 3 22-02-2005 15:41
Default Code and printf WilsonDJ00 Programming 2 22-01-2005 16:39
Anyone with a replacement Printf? Larry Barello Programming 5 19-03-2004 02:20
Printf warning during compile? actorindp Programming 4 20-02-2004 17:02
