Go to Post FIRST's awesomeness cannot be described in numbers. - Shinglei [more]
Unread 03-03-2005, 23:25
amateurrobotguy's Avatar
amateurrobotguy amateurrobotguy is offline
Lead Programmer/Senior Engineer
amateurrobotguy is infamous around these partsamateurrobotguy is infamous around these partsamateurrobotguy is infamous around these partsamateurrobotguy is infamous around these partsamateurrobotguy is infamous around these partsamateurrobotguy is infamous around these parts
A PimpBot
What is the maximum height that a pneumatic tube(In the stadard kit) can go? I ask, because I want to try and see if I can hook up 4 pnematic tubes to the frame and be able to elevate the bot. Possible bounce it up and down. Can I rig all 4 cylinders to 1 compressor?
I quit FRC over 2 years ago (more if you're reading this past 2010).
Unread 03-03-2005, 23:29
BoyWithCape195 BoyWithCape195 is offline
AKA: Ben Gagne
FRC #0195
BoyWithCape195 has a brilliant futureBoyWithCape195 has a brilliant futureBoyWithCape195 has a brilliant futureBoyWithCape195 has a brilliant futureBoyWithCape195 has a brilliant futureBoyWithCape195 has a brilliant futureBoyWithCape195 has a brilliant futureBoyWithCape195 has a brilliant futureBoyWithCape195 has a brilliant futureBoyWithCape195 has a brilliant futureBoyWithCape195 has a brilliant future
Send a message via AIM to BoyWithCape195
Re: A PimpBot
They have 8 inch stroke (ones in kit). And you can run them off one compressor, but you would run out of air REALLY quick. As well as make sure, even if it is for fun, you have the compressor auto shut off.
2007 UTC New England Regional Champions (1124 and 558)
2007 UTC GM Industrial Design
2006 International Championship Finalist (25 and 968)
2006 Newton Division Champions (25 and 968)
2006 Championship Innovation in Control Award
2006 UTC Quarterfinalist (236 and 230)
2006 UTC Innovation in Control Award
2005 Curie Division Quarterfinalists (703 and 234)
2005 UTC Semifinalist (228 and 236)
2004 UTC Entrepreneurship Award
2004 New Jersey Semifinalists (173 and 11)
2004 New Jersey Sportsmanship Award
Unread 03-03-2005, 23:53
Billfred's Avatar
Billfred Billfred is online now
Re: A PimpBot
Funny you should mention that...1293 was planning on building a robot in the off-season for similar show-offy purposes.
(Something tells me we'll be borrowing a page from 2004 to get the basis for the bounce.)
Unread 20-03-2005, 16:06
Mike's Avatar
Mike Mike is offline
has common ground with Matt Krass
AKA: Mike Sorrenti
FRC #0237 (Sie-H2O-Bots (See-Hoe-Bots) [T.R.I.B.E.])
Mike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond repute
Re: A PimpBot
We run two pneumatics off one compressor and its fine on air, it's used a LOT (for our grabber) so I'm not sure what you guys mean by it not being able to handle it. (We have 2 storage tanks... if that matters)
http://www.mikesorrenti.com/
Unread 20-03-2005, 16:28
henryBsick's Avatar
henryBsick henryBsick is offline
Why wait for the last 20?
AKA: Henry B. Sick
FRC #0125 (NUTRONS)
henryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond repute
Send a message via AIM to henryBsick
Re: A PimpBot
The bore of the cylinder matters, along with the length for air consupmtion. The ones for your gripper not being very large I am assuming should not draw hardly any air at all.
We run two small shifting cylinders also, and we run a maximum allowed (2 in"?) bore 8 inch long cylinder. I can shift all I want and we can tilt the arm when necessary and we are fairly ok. If you want to run 4 large bore cylinders at a decent lenght, make sure you have a lot of accumulators.
Mechanical Engineer
Digital Lumens
NU ME: 2011
Unread 20-03-2005, 16:33
Bcahn836's Avatar
Bcahn836 Bcahn836 is offline
Iraq is fun.
AKA: Brad Cahn
no team (Robobees 836)
Bcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond repute
Send a message via AIM to Bcahn836 Send a message via Yahoo to Bcahn836
Re: A PimpBot
We used three 24" pneumatic cylinders two in one motion to lift the arm and one to extend. Lifting those two 24" cylinders took 60 psi. And the single 24" took a little less than 30psi and took the tanks about 8 secs to refill. however our 6" cylinder on our claw took like 5 psi.
I don't think you would want to use 24" cylinders but with 4 smaller ones you could run off of one compressor and 2 air tanks but i would add a 3rd tank and you should be fine.
Unread 20-03-2005, 16:45
abeD's Avatar
abeD abeD is offline
FRC #4707 (Mentor FRC#4707 Alumni FRC#710)
abeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to behold
Re: A PimpBot
last year we used a pnematic cylinder per wheel to raise and lower them to go up and down the steps...we could do up down and up somewhat without having to wait to fill the airtanks again (we used 4 8" stroke 2 or 1.5 " bore)
Penn Class 08
