Go to Post The bulk of the hardest fun you'll ever have is opening up that box in early january, and the six week of chaos that that box of parts puts you through. - Joe G. [more]
Unread 20-03-2005, 16:41
JIN's Avatar
JIN JIN is offline
JIN
AKA: Wouldn't you like to know...
#1015 (Pi Hi Samurai)
Team Role: Driver
JIN is an unknown quantity at this point
Need help with gear box bearings
I posted this in the technical section, but it appears that no one is there to see it at the moment. So I greatly apologize if this thread is out of place, but I need an answer quick.
We're trying to make a second drivetrain to practice piloting. We have everything for the gearbox, except for the bearings, which don't come with the kit. I need to know the thickness and dimensions of the bearings so we can get them ourselves. Can anyone help please?
Thanks!
Jazz... TRANSFORM and ROLL OUT!
Unread 20-03-2005, 16:55
Swampdude's Avatar
Swampdude Swampdude is offline
AKA: Dan Quiggle
FRC #0179 (Children of the Swamp)
Swampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond repute
Re: Need help with gear box bearings
I think you're referring to grey container item 1 in the KOP list
www.179swampthing.org
Unread 20-03-2005, 17:02
JIN's Avatar
JIN JIN is offline
JIN
Team Role: Driver
Yes, we have that list and we have the item number, but we couldn't order it from FIRST and we searched around with that info. given to us and could not find anything at any of the hardware shops. So we need the the diameter of the bearings and their holes, and the thickness dimensions so we can go find the bearings ourselves.
Unread 20-03-2005, 17:14
JIN's Avatar
JIN JIN is offline
JIN
Team Role: Driver
Can anyone please assist?
thanx
[edit]or if anyone has any bearings with them, could they measure them and give us the dimensions? All of our bearings are currently on the robot, which we don't have access to till the competition, of course . If anyone could do that it would be greatly appreciated.
Unread 20-03-2005, 17:43
JIN's Avatar
JIN JIN is offline
JIN
Team Role: Driver
*bump*
Unread 20-03-2005, 17:58
Babyhueyhnx's Avatar
Babyhueyhnx Babyhueyhnx is offline
Jack of all trades
AKA: Phil
FRC #0486 (The Positronic Panthers)
Babyhueyhnx is a jewel in the roughBabyhueyhnx is a jewel in the roughBabyhueyhnx is a jewel in the rough
Send a message via AIM to Babyhueyhnx
i believe you will need to order them from MSC.
FIRST Topsite
Got Robot? - Team486.com
There is much pleasure to be gained from useless knowledge.
He who asks is a fool for five minutes, but he who does not ask remains a fool forever.
Not everything that can be counted counts, and not everything that counts can be counted.
Every day is a present. After all is a called "the present," and live every day like its your last.
Get Firefox!
Reclaim Your Inbox!
Unread 20-03-2005, 18:07
JIN's Avatar
JIN JIN is offline
JIN
Team Role: Driver
Argh , it says the part number can't be found (39KDD and 9103KDD) . Thanks for all your help, but I think the only way to get the part is to get the actual dimensions. Anybody have bearings on them?
Unread 20-03-2005, 18:39
NoodleKnight's Avatar
NoodleKnight NoodleKnight is offline
24 Hours of LeMons?
FRC #0100 (WHS&CHS Robotics)
NoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud of
Send a message via AIM to NoodleKnight
I found this on IFI's site, on their FAQ forums for the transmissions -- Paul Copioli posted this:
What are the transmission bearing specs?
There are two types of bearings used in the transmission. Below is a list of the bearings and various supplier's part numbers:
1. 17mm I.D. x 35mm O.D. x 10mm thick deep groove ball bearing.
- SKF part # 6003-2Z (with shields)
- TIMKEN (FAFNIR) part # 9103KDD (with shields)
2. 9mm I.D. x 26mm O.D. x 8mm thick deep groove ball bearing.
- SKF part # 629-2Z (with shields)
- TIMKEN (FAFNIR) part # 39KDD (with shields)
Please reference pages 1-6 and 5-3 in the "2005 FIRST Robotics Competition Kit Transmission Manual."
Original Thread
WHS/CHS Robotics - Team 100 (2003-2006):
2006- Delphi's Driving Tommorow's Technology @ Davis | Imagery Award @ SVR | 2004- SVR Finalists (w/ 691 and 1280)| 2003- Delphi's Driving Tommorow's Technology @ Sac
Unread 20-03-2005, 19:38
Biff Biff is offline
AKA: Tom Cooper
#1227 (Techno Gremlins)
Biff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the rough
Original Thread
Google turned up this referance for the first SKF part number,
http://www.kartingdirect.co.nz/catalog.php?cat=BEARING
Unread 21-03-2005, 20:10
JIN's Avatar
JIN JIN is offline
JIN
Team Role: Driver
Thank you so much, that's exactly what I was looking for!
Need help with gear box bearings JIN Kit & Additional Hardware 1 21-03-2005 12:46
Given Gear box shematics rcubes85 Technical Discussion 2 14-01-2005 23:35
Drill motor in a Dual Motor gear box MBosompra Technical Discussion 3 16-01-2004 21:37
Please help! Grease in the drill motor gear box? archiver 2000 2 23-06-2002 23:07
power of globe motor with gear box? Ken Leung Motors 5 21-11-2001 13:43
