#16
Re: No CIM Motor in 2006?
The hips are made for FIRST. They are cheap and reliable. They may change the specs a bit to keep us on our toes but they are here to stay (for now).
#17
Personally, i love the FP's They are great for just about everything. I would like to see 12 volt FPs though. 6 volts just isn't enough.
HOWEVER. better then all of that would be a 24 volt system. current is not your friend. low heat, high torque=we all win. I would love to see somthing that deals with sand. it would be quite a challange that most teams have never seen. Perhaps we should have a year where there is alot of manuvering and not much lifting. i would LOVE to see some hovorbots. |
#18
-dave |
#19
It's not as though this transmission could be quickly adapted for use with other motors... I mean... who would ever run a FP, Globe, or Van Door through that gearbox. ![]() 2006 - The Year of the Globe Motor... ![]() |
#20
The thing with the FPs though about being "great for just about everything" is that they aren't. The gearbox that comes with them is all plastic. While this may be good for weight, it isn't for durability. So, lets talk just about the motor. The motor packs a lot of punch in a very small size. This leads to the problem of overheating (when not used like we used them). Also, it spins at a very fast ~20,000 rpm. This requires another stage of reduction compared to match the Chiaphua. Also, the FP is fairly small and fragile. The shaft is only 1/8" where the Chia is over 5/16" Also, the power tabs bend and break off. Also, the internal fan blades are very fragile and they break off. Also, the motor can is not fully sealed so debris can fall inside. Also, I don't think two FPs would be adequately capable of driving a robot where 2 Chias would. Aside from weight and size, I cannot see any advantages to the FP over the Chia. The Chia is a hefty industrial motor that serves us well. I hope it is here to stay. |
#21
Is their any reason to believe that we are not going to be able to use 4 cim's again? We are allowed to use 4 cim's on the base, is their reason to believe that they won't allow that anymore?
GO 1403!!! |
#22
Maybe drill motors are gonna make a comeback. I wouldn't mind =) -- even if the cim's are less finicky, the drill motors packed a lot of power in a fairly small package and could tolerate some abuse (more than the FP's, at least).
| New Regional in Europe in 2006 | unapiedra | Regional Competitions | 49 | 26-05-2005 00:07 |
| Allowed to use CIM motors from last year? | lphan | Motors | 7 | 26-02-2005 16:49 |
| CIM speed in reverse? | colt527 | Motors | 41 | 06-12-2004 19:09 |
| CIM Motors to pull up Robot | Joe P | Motors | 7 | 11-01-2004 22:27 |
| CIM vs. Drill motor | duckshepherd | Motors | 3 | 15-02-2003 18:36 |
