Go to Post I got to meet Andy Baker, and Grady, and I saw Andy Brockway. Is that like an Andy Triple Play or something?? ;) - Ian Curtis [more]
Unread 22-03-2005, 14:34
Crebb's Avatar
Crebb Crebb is offline
AKA: James M.
FRC #5279 (Bionic Eagles)
Crebb has much to be proud ofCrebb has much to be proud ofCrebb has much to be proud ofCrebb has much to be proud ofCrebb has much to be proud ofCrebb has much to be proud ofCrebb has much to be proud ofCrebb has much to be proud ofCrebb has much to be proud of
pic: 35 MPH Prototype
Shibuya Hoppmann, Mechanical Engineer
VCU School of Engineering 2012
Team 5279 2016-Present
Team 384 2003-2015
Unread 22-03-2005, 14:35
Joe Matt's Avatar
Joe Matt Joe Matt is offline
Reject False Icons
Joe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond repute
Re: pic: 35 MPH Prototype
James! You know 6.5 isn't street legal! Bad robot! Bad! Let's hope our resource officer dosn't find out abou this....
Steal back your future
Unread 22-03-2005, 14:50
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
How did you measure/calculate/verify the actual speed. Also, it must have been kind of scary with that caster wheel huh? Also, what is the big tank for?
Unread 22-03-2005, 14:56
BoyWithCape195 BoyWithCape195 is offline
AKA: Ben Gagne
FRC #0195
BoyWithCape195 has a brilliant futureBoyWithCape195 has a brilliant futureBoyWithCape195 has a brilliant futureBoyWithCape195 has a brilliant futureBoyWithCape195 has a brilliant futureBoyWithCape195 has a brilliant futureBoyWithCape195 has a brilliant futureBoyWithCape195 has a brilliant futureBoyWithCape195 has a brilliant futureBoyWithCape195 has a brilliant futureBoyWithCape195 has a brilliant future
Send a message via AIM to BoyWithCape195
Shifting without a compressor ?! (reason for tank maybe)
2007 UTC New England Regional Champions (1124 and 558)
2007 UTC GM Industrial Design
2006 International Championship Finalist (25 and 968)
2006 Newton Division Champions (25 and 968)
2006 Championship Innovation in Control Award
2006 UTC Quarterfinalist (236 and 230)
2006 UTC Innovation in Control Award
2005 Curie Division Quarterfinalists (703 and 234)
2005 UTC Semifinalist (228 and 236)
2004 UTC Entrepreneurship Award
2004 New Jersey Semifinalists (173 and 11)
2004 New Jersey Sportsmanship Award
Unread 22-03-2005, 14:57
Arefin Bari's Avatar
AKA: Ari
FRC #0108 (SigmaC@T)
I would be guessing that the big tank is the compressor for pneumatics. I can be wrong...
What was the output ratio from transmission output to wheel?
Unread 22-03-2005, 14:58
Crebb's Avatar
AKA: James M.
I calculated the theoretical top speed using the rpm and gear ratios in the transmissions. The big black tank is for the pneumatics to change gears. The tank is so big that we only filled it once for all the time we were playing with it. We didn't officially clock it at 35 MPH, but we were guestimating. And as for the caster in front, at the beginning it was centered. That thing bounced around so much I couldn't control it. But it was FUN!
The gear ratio in the transmission is 4.17:1 which is about 1247 rpm. Then it goes 1:1 from the transmission to the 12" wheel.
Team 384 2003-2015
Unread 22-03-2005, 15:28
Biff Biff is offline
AKA: Tom Cooper
#1227 (Techno Gremlins)
Biff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the rough
If the cims are turning 4379 then output at that ratio is 929.7 rpm, with a 12in tire, 48.68fps which is 33.1 mph (fps * .68) gets you mph. If you are getting more than 4379 out of the cims even faster. Way cool
Unread 22-03-2005, 15:43
Crebb's Avatar
AKA: James M.
The motor specs sheet I have been using has the CIM's going at 5200 rpm. That's what i've been basing my calculations on.
Team 384 2003-2015
Unread 22-03-2005, 15:46
Daniel Brim's Avatar
Daniel Brim Daniel Brim is offline
It's hard hat time here in Boston
AKA: DFB
FRC #0125 (NUTRONS)
Daniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond repute
Send a message via AIM to Daniel Brim
Whatever you do, don't show that design to Swampthing . Next thing you know, they'll come up with a robot that goes 40+ miles/hour reliably. As if their robot wasn't fast enough...
2003 (2002) - 2006 -- Team 294, Beach Cities Robotics
2007 (2006) - Present -- Team 125, NUTRONS
Unread 22-03-2005, 15:47
Madison's Avatar
Madison Madison is online now
Dancing through life...
FRC #0488 (Xbot)
That is approximately the CIM motors free speed. The motors are operating under load, so the actual output RPM is going to be something far lower than that. Additionally, if you're using the FIRST provided circuit breakers, the motors will draw more than 40A under load at a speed considerably lower than 5200 RPM, were they ever to go that fast.
If your robot were traveling 35 MPH, it'd be able to cross a football field in six seconds. Can it?
--Madison--
...down at the Ozdust!
Unread 22-03-2005, 15:48
some young guy's Avatar
some young guy some young guy is offline
i donno...i just build it
AKA: joe
#0810 (the mechanical bulls)
Team Role: Student
some young guy is on a distinguished road
Send a message via AIM to some young guy
o man i thought the black tank was for the Nirtous Oxide...darnet that would have been cool
BRUTE FORCE!!!! its all u need.....o and a BIG hammer is always good
Unread 22-03-2005, 16:16
Crebb's Avatar
AKA: James M.
We did have trouble tripping the breakers. The first time we tried it out we only had one CIM per gearbox, but we added two more. The road we tested on had a slight hill, so if we started off in first gear and shifted into second it did fine. As for the football field in 6 seconds, it would be close. I need to find a radar gun somewhere.
I admit that it isn't practical and we wont use this setup on our robot next year (most likely), but it sure is fun.
Team 384 2003-2015
Unread 22-03-2005, 17:30
tkwetzel's Avatar
tkwetzel tkwetzel is offline
Good Luck Teams!
AKA: Tyler Wetzel
FRC #0116 (Epsilon Delta)
tkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond repute
Send a message via AIM to tkwetzel
Is it FIRST legal? I am assuming not because of the air tank you used.
Electric motors....nitrous oxide? They would get more power out of putting NOS stickers on their bot than actually putting a nitrous tank on it. Because all the NOS tank would do would be weigh down the bot .
See you in DC!
Unread 22-03-2005, 17:34
KTorak's Avatar
KTorak KTorak is offline
Fire Rescue 47
AKA: Kyle Dersch
FRC #1023 (Bedford Express)
Team Role: Driver
KTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond repute
Send a message via AIM to KTorak
This looks like something I would want to do in the summer in my free time. Yay for using math calculations to figure out speed We used the long equations mentioned so we could gear our robot for ~12-15 Ft/S this season But heck, 35 MPH is insane.
Kyle D- Myspace - Facebook
2008 Bedford Express Driver & Build & Design (Team) Co-Leader
2007 Bedford Express Driver & Build & Design (Team) Leader
2006 Bedford Express Driver, Build Team Member, & Board of Directors
2005 Bedford Express Rookie, Build Team Member & Robot Operator
2008 - GLR Quarter Finalist
2007 - GLR Finalist & Boilermaker Finalist & MARC Off Season Event Winner
2006 - GLR Johnson & Johnson Sportsmanship Award & Archimedes 7th Seed Quarter Finalist
2005 - GLR Finalist & Judges Award.
2004 - GLR Semi Finalist.
2003 - GLR/DTR Quarter Finalist & GLR/NAT'L Rookie All Star.
Unread 22-03-2005, 17:38
Conor Ryan Conor Ryan is offline
I'm parking robot yacht club.
FRC #4571 (Robot Yacht Club)
Conor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond repute
try a bigger battery, like 24 volts. That may change some stuff. Also you may want to impliment a cooling system if you haven't already.
pic: Team 1595 Prototype!!! L@@K sgsdragons Robot Showcase 18 10-02-2005 14:27
pic: 1382 Brazil + Prototype Robot tribotec_ca88 Extra Discussion 3 09-02-2005 13:49
pic: Team 1382 Prototype LEGO Robot! tribotec_ca88 Extra Discussion 7 19-01-2005 23:33
pic: Swerve^2 Prototype CD47-Bot Robot Showcase 24 23-01-2004 12:11
pic: Team 857 Prototype Killough 2002 CD47-Bot Extra Discussion 19 13-10-2003 08:12
