Go to Post we came together, worked our butts off, and eventually looked at failure and decided....its just not our style. - Monochron [more]
Unread 22-03-2005, 19:01
Gusman1188 Gusman1188 is offline
FRC #0870
Rookie Year: 1930
Gusman1188 will become famous soon enoughGusman1188 will become famous soon enough
pic: Rice 870 Robot
Team R.I.C.E. 870
2006 SBPLI Regional Winner
2006 SBPLI Imagery Award
2005 SBPLI Regional Winner
2004 SBPLI Xerox Creativity
2003 SBPLI Regional Winner
2003 CT J&J Sportsmanship
2003 SBPLI KPC&B Entrepenuership
2002 SBPLI Rookie All-Star
Unread 22-03-2005, 19:07
colt527 colt527 is offline
AKA: Ken Colton
FRC #0527
colt527 is a splendid one to beholdcolt527 is a splendid one to beholdcolt527 is a splendid one to beholdcolt527 is a splendid one to beholdcolt527 is a splendid one to beholdcolt527 is a splendid one to beholdcolt527 is a splendid one to behold
Send a message via AIM to colt527
Re: pic: Rice 870 Robot
That is quite an amazing robot you guys have. The degrees of motions on the arm are amazing. It can telescope up, rotate around and rotate up. I didn't have too much time to watch you guys but our scouters during the day definatly relized how good of a robot you guys have and that the rank that you finish in the end of the day has no bearing on how you are going to do on the finals. I love how your robot could realign the tetra on the corner that we half capped (Last Finals Match), our arm just would not have been able to fix that. Your robot was also incredibly solid! It never had any problems during the spit-fire rounds of the finals. While Us and 358 would be making last second fixes, your robot would be in top condition! And your team ready to give a hand to others if in need. Your drive system was also amazing, you had a tremendous amount of traction and a very low center of gravity, which you guys definatly used to your advantage and even pushed some other robots around to keep them off our back while we capped.
So, Thanks for being such great alliance partners!
-Team 527
Mentor, Team 527 -- Plainedge Red Dragons
FIRST Volunteer
SUNY Stony Brook Computer Science 2010
kcolton@gmail.com
Unread 22-03-2005, 19:15
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Overall, it looks like a very lightweight design. While I haven't seen it in action, I am impressed. I'm just curious though, why the large heavy wheels/tires?
Unread 22-03-2005, 19:45
[527]phil's Avatar
[527]phil [527]phil is offline
Alumni
AKA: Phil
FRC #0527 (red dragons)
[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light
Send a message via AIM to [527]phil
Too bad you guys aren't coming to nationals because we made an awesome team
Whats the difference between mechanical engineers and civil engineers?
Mechanical engineers build weapons, civil engineers build targets
Unread 23-03-2005, 12:07
Toolman Toolman is offline
Coach
AKA: Tony
FRC #3171 (WHB/Hurricanes)
Toolman is an unknown quantity at this point
The 870 bot w/out the battery weighed in at 115.7lbs.
The pneumatic tires were the heaviest individual parts of the bot weighing in at appx 7lbs each. This helped to distribute the low center of gravity for the bot.
The transmissions from first were weight reduced and the main drive gear was changed to a smaller # of teeth still using the 4 cims as a power source.
these combined features allowed for a very fast and VERY powerful drive and maneuvering system when needed.
We only needed to use the brute force in two matches for the 3 days. one match was when we scored the highest for the entire event. The other was in one of the final rounds to control the opposing robot.
The low center of gravity was great we never came close to falling over.
However just for giggles we demonstrated we were self righting from any direction if needed. (we wanted to be able to do this because we were knocked out in the semi-finals last year with our Scorpion robot).
As a result of the overall design Team 527 made a great choice to pick our team for their alliance partner. We are a very strong offensive/Defensive bot.
Team Leader
870
pic: Robot? What Robot? CD47-Bot Robot Showcase 13 10-04-2004 07:08
pic: 294's First Inventor Robot (pic 1)... CD47-Bot Robot Showcase 4 10-03-2004 19:34
pic: Closeup of the robot hanging on robot CD47-Bot Extra Discussion 16 09-03-2004 18:27
team 25 robot pic nuggetsyl Robot Showcase 12 21-02-2004 00:57
XCats - robot pic on our website archiver 2001 0 24-06-2002 01:06
