Go to Post How many computer programmers does it take to screw in a lightbulb? Woah, no. That's a hardware problem. - jordie228 [more]
Unread 22-03-2005, 22:11
sebas2mil's Avatar
sebas2mil sebas2mil is offline
AKA: Sebastian Acosta
FRC #3966 (STEMpunks)
sebas2mil has a spectacular aura aboutsebas2mil has a spectacular aura about
IFI motor problem
we are trying to figure out what the IFI Multi-Speed Motor wires mean the black red yellow orange wires
we want to know if anybody knows what they are
thanks
sebas
go TechTigers 1251
Unread 22-03-2005, 22:20
Electrical Engineer
Rookie Year: 1995
Re: IFI motor problem
thanks
sebas
go TechTigers 1251
Sebas,
Please be more specific... Are you talking about the Edubot servos?
Regards,
Mike
Mike Betts
As easy as 355/113...
Unread 22-03-2005, 22:24
NoodleKnight's Avatar
NoodleKnight NoodleKnight is offline
24 Hours of LeMons?
FRC #0100 (WHS&CHS Robotics)
NoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud of
Send a message via AIM to NoodleKnight
I think he's talking about these motors
The black red yellow orange wire is the only means to control & power the motor. The EDUBot Controller has special ports for these motors, although you can directly plug the motors into pwm ports and relay ports (they autodetect the port-type) on the FRC Robot Controller.
WHS/CHS Robotics - Team 100 (2003-2006):
2006- Delphi's Driving Tommorow's Technology @ Davis | Imagery Award @ SVR | 2004- SVR Finalists (w/ 691 and 1280)| 2003- Delphi's Driving Tommorow's Technology @ Sac
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
That seemed pretty specific to me. It is no longer called the Edubot and they are not servos. This is what he is talking about http://www.ifirobotics.com/edu-motors.shtml
Typically servos (which these are not) have three wires: positve, ground, and signal. What the 4th is for here, I don't know.
Unread 22-03-2005, 22:25
sebas2mil's Avatar
Originally Posted by Mike Betts
Sebas,
Regards,
Mike
yes we are
sebas
Unread 22-03-2005, 22:29
sebas2mil's Avatar
what we need to know is what the orange wire is four because we are trying adapt it to a bobot
sebas
Unread 22-03-2005, 22:33
24 Hours of LeMons?
The IFI multi-speed motor, which I believe is what you were talking about, is the one with the 4 wired cable (Black, Red, Yellow, Orange). IFI doesn't make servos.
Regardless, I think you're looking for this:
Black - Ground
Red - +Battery
Yellow - PWM Control
Orange - +Battery
Here's the document on the 2004 Mini Robot Controller, look on Page 8, there's the pin-out diagram for the multi-speed motor.
Unread 22-03-2005, 22:35
sebas2mil's Avatar
Black - Ground
Red - +Battery
Orange - +Battery
do you any clue of what the voltage on orange one is please
sebas
Unread 22-03-2005, 22:37
That's odd, I wonder why there are two power + ?
Anyway, why would you adapt this to a BoeBot instead of just using the modified servos that come with it? http://www.parallax.com/detail.asp?product_id=900-00008 Very cheap too. The speed and torque are comparable as well.
Building an arena controller CJO Control System 32 29-03-2005 07:04
IFI Loader and PROG button Dave... Programming 3 20-02-2005 12:03
IFI Loader usually hangs midway thru load gnormhurst Programming 4 04-02-2004 11:40
IFI Loader Problems BrendaB Programming 3 24-01-2004 22:45
Bug in IFI Loader rwaliany Programming 2 06-01-2004 21:26
